Question about Sewing Machines
What does error code F04 mean something with foot pedal? It is really hard to plug in. Could I put WD40?
  • Sewing Machines Master
  • 1,860 Answers
The receiving plug would have something wrong with the pins in it or the foot pedal plug could have something wrong with the pins in it,, it would be better to have a sewing technican look at the machine.. don't use wd 40 on the plug
Posted on Dec 15, 2014
My Brother SE-270D shows error F04 in screen
http://www.sewingmachinesplus.com/brother-sewing-machine-error-codes.php
Sep 11, 2016 | Brother SE-270D Computerized Sewing...
Brother NX-400. Never used. Error F04. I've looked for a model # for the foot for NX-400 to no avail. The foot that came in the box is Model T/FC-322. I can't help but think this is the wrong foot.
If you mean the foot controller, then the T/FC-322 is a substitute that should work. It's listed as a replacement here: http://www.sewingmachinesplus.com/234522001.php . The manual for the NX400 gives the foot controller as XC1154-051 . Brother changes the part number often but the wiring remains the same. Another substitute controller is available here: http://www.sewingpartsonline.com/foot-control-w-cord-brother-xc6651121.aspx .
The F04 message may mean there is an internal failure. This probably needs to be fixed by a Brother authorized repair person.
I wish that I had better news for you.
Mar 13, 2016 | Brother Sewing Machines
F04 comes up when i plug my foot pedal in
either the computer part of the machine is messed up or
there's something wrong with the foot pedal
Feb 23, 2012 | Brother SE-270D Computerized Sewing...
Nx400 error message F04?
I had the problem with the error code F04 and found out that it is your foot pedal for the machine. Unplug it and it should start right up as ours did.You will need to fix or buy a new foot pedal. When they repair and or clean your machine they don't use your foot pedal but they use their own so they will miss the broken foot pedal.
I hope this helps you.
Bob
Jan 19, 2011 | Brother NX-400
I am getting error message E4 when foot pedal is plugged in. Unplug the foot pedal and the machine goes back to normal with the exception that you really can't sew without the foot pedal.
Your reverse reinforcement stitch button was pushed or needle position was pushed while bobbin winder was moved to the right. You can download a free manual brother-usa.com and you will see all of the troubleshooting and error messages there
Sep 10, 2010 | Brother CE4000 Computerized Sewing Machine
What is err code F04
It most likely is your foot pedal. Unplug your foot pedal and start the machine without it. If it works properly without the foot pedal plugged in then your foot pedal needs repaired or replaced. This worked for us with the NX400 machine and I am sure the NX450 is closely similar. Don't bother to buy a Manual if you didn't already get one with the machine. A Service manual and parts manual is best; But just so you know they don't show the error codes unless you are a qualified and authorized repair person for the machines. I got my info from the repair man where my wife buys and repairs her machines. I am an electronic technician and mechanic so I understand how this system works. I will be repairing my wife's machines from now on.
Aug 21, 2010 | Brother NX-400
What does error E1 mean on a brother CS6000i
hello,the E1 code simply means the machine is working so hard,you can follow the information below to help you fix the problem,
The instructions for bobbin winding tell you to click the start button for the bobbin to wind. When you do that you get that E1 with a beeping. What they don't explain is that in order to press that "UP" arrow button to get the bobbin to wind..........you need to UNPLUG the foot control. So, in other words it to be used for sewing w/o a foot pedal. Now instead of doing as per instructions, assuming you've plugged everything in (foot pedal), after winding is finished just press the foot pedal and your off and running or sewing as the case may be. BTW, look it up in the TROUBLESHOOTING SECTION OF YOUR MANUAL.
please kindly rate the solution if it;s helpful,
take care.
Jun 06, 2010 | Brother CS6000i Computerized Sewing...
Fo4--What does it mean and where do I find the translations?
F04 is foot control error. It is probably a bad foot control, but it may be the plug in on the machine or a circuit board.
You can run the machine without a foot control for now; just unplug the foot control from the machine and use the Start/Stop button like you would when embroidering.
Before replacing the foot control, you should bring the machine to a Brother shop and try a new control. If the new one works, then the control was the problem.
Aug 03, 2008 | Brother SE-270D Computerized Sewing...
Singer 7462 sewing machine
There is two seperate cords on this machine. A power cord and a pedal cord. If you put the power cord in and switch the machine on, and then remove the pedal cord it should give you a beeping sound, which shows you the connection does work.
Please give me feedback in order to help you
Dec 08, 2007 | Singer 7462 Mechanical Sewing Machine
Sewing Machines Logo
75 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
