Question about Alba DVD-108 DVD Player
How do I connect to tv there is nothing on the screen from the DVDs player
Tried linking but there is no connection between tv and DVD player both are working but no together
  • Alba Master
  • 5,342 Answers
It depends on your connections for one thing. I did find this piece of information on the DVD player:
"One thing they do not state (in the manual) is that if you are playing it through your Scart socket to your TV. Your TV's Scart socket must be PAL60 compliant".
If they both have HDMI sockets I would get a HDMI cable and connect via that. You will also get a better picture than a scart.
If you are using a scart the connector can also become faulty either inside or a faulty pin so check that too.
Posted on Dec 29, 2014
No Video Error on TV Screen
Select SOURCE on tv to dvd or component or dvi or auxilary etc
Aug 24, 2014 | Sony DVP-SR210P Progressive Scan DVD...
Cannott get a picture on my tv from my DVD/VHS COMBO
Your DVD player should be connected to either the Yellow White Red connections on your TV set (same color to same color -- dvd OUT to tv IN )
OR it should be connected using the RF cables and connected inline AFTER the Direct TV Box....the box would block the DVD; and possibly the Direct TV Master box would apply 19 Volts to the DVD modulator....destroying the modulator.
Always OUTput to INput on the connections...
Also try with a new set of connections. make sure all the ports are ok.
Hope It's resolve all Problem,
Or
Still having Problem Then follow Us For
Tech support
Feb 07, 2014 | Televison & Video
Samsung DVD-V3650 DVD Player / VCR Combo no sound when connected via component cable
Component connections between your DVD player and TV (they will be colored red, blue, and green) carry video only. You will need to connect two more cables for left and right audio channels. The connectors for these audio cables will be colored white and red for left and white respectively.
Nov 04, 2017 | Samsung DVD-V3650 DVD Player/VCR
Dvd pplayer will not play but vcr is fine
If both connect at same exact place on set the player itself may be bad--you get sound from the DVD unit?
Dec 12, 2012 | Televison & Video
Dvd screen comes up on TV but dvd player says "disc error".
unplug the pwr cord from dvd for 5-10 min..plug back into outlet..make sure the av cable is connected white-white yellow-yellow red-red...now press play on the dvd
feel free to rate help
Jul 04, 2010 | Toshiba SD-2800 DVD Player
Dvd player not reading dvds
si reviso bin las conecciones prueve el dvd en otro tv
Aug 24, 2009 | Cyberhome CH-DVD 300 DVD Player
Why is my screen blank while audio is fine?
These are the possibilities:-
1.Check the connections. you need to connect yellow cable to yellow jack(I assume you are using AV cable to connect)
2.Change settings of your DVD player accordings to your TV, like NTSC, PAL etc.
Please rate me if you are satisfied with my answer,in case, if you want any clarification please get back to me.
Dec 20, 2008 | GoVideo Go Video DVD/VCR Combo
DMR-ES10....no image on tv screen
Try connecting the recorder with the yellow composite connector and make sure your tv is set to that input it may be that your tv says "dvd" but it is trying to use a different input then you are connected to. Some tv's have multiple video connections for one input, they should but not always detect which you are connected to. Make sure the input you are trying to use has only one connection in use.
May 24, 2008 | Panasonic DMR-ES10 DVD Recorder
Alba DVD-108 DVD Player Logo
94 people viewed this question
Top Alba Televison & Video Experts
Demonic-2011
Demonic-2011
Michael Galve
Michael Galve
Are you an Alba Televison and Video Expert? Answer questions, earn points and help others
