Question about Tablets & eReaders
I need to charge my tablet to start but it will not charge
    Problem Solver:
  • 13 Answers
Could be the charger cable.
Try borrowing an identical charger from someone you know. If not you can try what it says here.
http://www.pcmag.com/article2/0,2817,2404104,00.asp
although some steps might not be applicable but step is definitively worth a try.
Posted on Dec 14, 2014
  • 784 Answers
Some Tablet PCs ships only to their original chargers , some can also be charged through your computer 's USB connection . Are you using the original charger ?
My tablet won't even charge or turn on
it's a factory thing, all You need to do, is open your tab, remove the battery cable for about 10 mins and plug it back again, unplug the screen from the motherboard, and charge it for about, two hours, then plug back the screen connector, and turn it on, if you see it works, turn off the tablet again, and plug in the power cord again, you'll see the charging animation starts, leave it charging for the time you think it's necessary to reach 100%, unplug the cable and turn it on, your tablet is alive, the only problem I've found about this, is that you'll need to turn the tablet completely off whenever you want to charge it, and finally this, VERY IMPORTANT! When your tablet is below 15 or 10% battery, charge it, because if you let the battery die, probably you'll have to do all the steps again.
You need more help give me a call at 1800-204-4427...
Sep 13, 2017 | Tablets & eReaders
Why is my tablet saying it's charging but it's still draining the battery while charging
If it is doing that, you need a new one or it needs repairing. Put it onto charge and then power it down. Batteries do start to fail after 3 or 4 years and are reasonably cheap to replace.
tablet battery - Google Search
Apr 23, 2017 | Tablets & eReaders
My kindle don't want to charge do kindle needs new batterry
  • Sometimes yes they need a new battery. Start by using a different charging block, they a new charging cable. Could also be the charging port in the tablet. What model do you have? Does it show it is charging?
Mar 02, 2017 | Amazon Tablets & eReaders
My tablet was in use, needed charging, it shut off. Now it won't charge or come on
It sounds like there's a problem with the charger. The wire on the charger is rather delicate. So is the port on your tablet where the wire plugs in. There may be a break inside the wire. If you dropped your tablet while the wire was plugged in and it hit the floor on the charger plug, the charger plug could have damaged the charging port in the tablet or the wire itself could be damaged.
Find someone else who has the same tablet and ask to switch chargers to see if either of them still work on the other tablet. If your friend's charger starts charging your tablet without a problem, then the problem is a a broken wire in your charger. If neither charger will charge your tablet but both chargers charge your friends tablet without a problem, then the problem is with the charging port on your tablet.
Mar 17, 2015 | Tablets & eReaders
Googe nexus 7 will nt charge
If you feel comfortable you could take it apart and re-solder the charge port. Most tablets are not that hard to take apart. You really just need some plastic pry bars and small screw drivers
Nov 20, 2013 | ASUS 32GB Google Nexus 7" Tablet with...
Will not turn on
If tablet keeps burning out charges it is due to the fact that an internal short in the tablet is making the charging unit exceed its parameters and allowing it to burn itself out. The issue is with the tablet, not the chargers.
Mar 13, 2017 | Ainol 10" Novo 10 Hero 16GB Dual Core IPS...
My Nextbook 7 won't turn on
Every tablet has a button sequence, the reason being for a fresh restart. Either you unplugged it before full recharge, or didn't use proper charging adapter or cable.
There is a solution to avoiding this but first get tablet started by:
Hold power button and volume up button for eight seconds, release and hold power button again, tablet should turn on.
If not, do the opposite hold power button, volume down for eight seconds, then power button. You need to do this with proper adapter and charger you tablet came with plugged in. You may also need to do this more than once.
Once your tablet has started up, the way to avoid this is to swipe right on screen until you see settings app, should be round looking similar to a sprocket, or clock gear.
Open settings / display / sleep. I set mine for 30 mins.
Now you no longer need to power off you tablet manually, thus skipping the button sequence process.After unplugging from charge adapter you will still need to press power button to start.
Hope this helps I have yet to have this problem again, and remember to always let your tablet fully charge before disconnecting.
Jan 11, 2012 | Tablets & eReaders
Tablets & eReaders Logo
50 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
