What is the cause of white line across middle of TV. The picture is normal
Unplugging .i has a digital box connected to tv g" />
    Sergeant:
  • 263 Answers
Bad screen.
Posted on Dec 15, 2014
LG 32LH30 LCD TV Problem
IMO Seriously for $119 it's not worth it.
However, it does sound like a capacitor problem
If you are "Serious" about fixing I'd find a TV repair Forum.
Else I'd go here and get a new one.
https://www.walmart.com/browse/electronics/32-inch-tvs/3944_1060825_2489948_7156390
Best Wishes.
Apr 29, 2017 | LG 32LH30 32 in. LCD HDTV
I have a LG 32LH30 TV. When I power on the TV I get a picture in the top half of the screen and vertical lines in the bottom half. Also I get a thin white dashed line across the middle of the screen....
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
The picture with my television has gone out. The sound is fine but there's only a white line across the middle of the television. How can I fix the picture?
The Toshiba sets are well known for this problem, the tv has a vertical deflection issue caused by the vertical ic and a few small capacitors going bad, I recommend a tv technician for the repairs.
Jan 15, 2011 | Toshiba 36A40 36" TV
Picture blank
Maybe it needs to be replaced with something more up-to-date.
Jun 26, 2017 | Sharp LC32D62U 32 in. LCD HDTV
Black Screen with white line across the
the vertical IC most likely has failed
Jul 19, 2009 | Televison & Video
Problem with tv
The problem is sometimes caused by the vertical output integrated circuit (IC) failing, but usually it's bad solder connections. If you or someone you know is comfortable with electronic soldering, a few minutes spent resoldering the IC pins to the circuit board will often solve the problem. Failure of these connections is common because the IC gets quite hot (and it's mounted on a metal heat sink). The heating and cooling cycles cause the solder joints on the circuit board to crack. You can usually see the trouble with light and a magnifying glass; gray grainy joints instead of shiny connections, and often visible ring cracks around the pins.
Mar 31, 2009 | Konka K1938U 19" TV
Black display with a horizontal white line in the middle.
Middle going across the screen from left to right??
This unit is plagued with bad solder connections in the comb filter board and flatpack underneath the comb filter board. These connections can cause any odd number of problems in video display. If it is that it's not expensive - virtually no parts. If it's a single line across the screen could also be the vertical circuit involved.
My suggestion is to have it estimated at a reputable shop and take it to them rather than the more expensive pu/del charges.
If you would like go to http://www.nesda.com/locator/state_search.php and locate a servicer from there. Kinda like going to the AMA to find a doctor...
Hope this helps!
Bill
Apr 18, 2008 | Hitachi 32UDX10S 32" TV
Picture problem
Sounds like the High voltage fly back is going or has loose connection
Feb 21, 2008 | Hitachi 50UX57B 50" Rear Projection...
27" flat screen
The main cause of this problem is cracked solder joints on the vertical output IC. Re-flowing the solder should take care of it. Sometimes a capacitor (normally against the heat sink containing the vertical output) will cause this, but, it usually has a different symptom. The price of repair will normally run, depending on where you live, $100.00 to $130.00. It's a small job and is done quickly. Hope this helps.
Mar 17, 2007 | Toshiba 27AF41 27" TV
Televison & Video Logo
56 people viewed this question
Top Televison & Video Experts
Electro Med Services...
