Question about Tablets & eReaders
My tablet will not charge
Model mhtmid_8718dcb_b
My kindle don't want to charge do kindle needs new batterry
  • Sometimes yes they need a new battery. Start by using a different charging block, they a new charging cable. Could also be the charging port in the tablet. What model do you have? Does it show it is charging?
Mar 02, 2017 | Amazon Tablets & eReaders
Why does my tablet turn off when charging
Read the user manual because the model you have may be designed to be in sleep mode when charging to provide a more efficient charging process.
Jan 02, 2016 | Tablets & eReaders
My tablet wont charge
If the cable has a micro USB connector (most android tablets do), then the connector is likely the problem. With the cable plugged in, there should be a light to indicate charging. It would usually be orange until charged, when it turns green. If you don't see the light atall, the connection is bad. Try wiggling it to see if that helps. If it does, then you will need to make sure the phone is charging somewhere so that it is not subject to being moved at all, which might cause the connection to become loose. The phone will charge faster if it is off.
Feb 03, 2015 | Mach Speed Trio Stealth G2 9.7 inch Tablet...
What charger can I use to charge tablet
That depends on the tablet.
Many tablets charge via the USB port, the power coming either from a computer's USB port or from a wall adapter.
If you require further assistance, please add a comment to this question and specify the make and model of your tablet.
Oct 12, 2014 | Tablets & eReaders
Will not charge
try ordering a new charger or have someone check the charging prort to see if it has loosen or damaged, it may need to be replaced. they parts are available on ebay, just make sure you put in the exact model number when looking
Mar 16, 2014 | RCA CA 7" Tablet with 4GB eory 28458515
Tablet wont charge
The DC - In Jack where you connect the AC Adapter to charge is either cracked, broken or loosened in the inside of the tablet. Investigate further on the company's website: enter the make of your tablet, model and serial number. It will show you the part and how much it will cost. It gives you an idea on what to expect to pay.
Parts cost less then the labor.
Jan 17, 2014 | Tablets & eReaders
My pandigital tablet dont wanna charge
USB Connections
All tablets connect to your computer using a USB cable.
Once connected, the device should charge as long as the computer recognizes it.
Look for manufacturer-specific software to launch once you plug your tablet into your computer; if this software fails to launch, it's likely that your computer hasn't detected the device and won't charge it.
Try a second USB cable, if available, or plug the USB cable into a different port.
If the device doesn't charge in either port, replace the USB cable.
AC Adapters
Some tablets are sold with an accompanying AC power adapter, though these accessories are often optional.
Try plugging your tablet into its AC power connector in the event that its USB cable isn't functioning.
Also check different wall outlets in case the outlet you are plugging your tablet into is defective.
If the device fails to charge in different outlets, the AC adapter may be faulty.
Reboot Like any device with an operating system a computer, a mobile phone or an MP3 player tablet computers can freeze from time to time.
When a computer freezes, you can reboot or restart it to get the operating system working properly again.
This is true of tablets too, but rebooting these systems can be a little tricky.
Check the manufacturer's website for specific instructions to restart your system.
Putting the tablet to sleep and waking it up doesn't clear its memory look instead for the buttons for a "reset," which are different for every brand.
This may clear up any recent malfunctions, like freezing apps or charging issues.
Restore
Just like a computer, tablets sometimes need to be restored to their original state to overcome technical issues like charging problems.
Again, the process of restoring your tablet to its factory default differs from model to model and from brand to brand.
Check the manual or the manufacturer's website for specific instructions, but as a general rule: plug the tablet into your computer using the provided USB cable.
Wait for the appropriate software to load and then look for a "Restore" option.
Follow the onscreen prompts to restore the device.
Aug 05, 2013 | Tablets & eReaders
Is there a way to charge my tablet
What make and model tablet?
Jul 09, 2013 | Tablets & eReaders
Tablets & eReaders Logo
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
