Question about Sewing Machines
How do I lower and raise feed dogs on Babylock Ellure?
  • Sewing Machines Master
  • 1,860 Answers
Try to look on youtube for a video, you didn't supply a model number so I couldn't look up a manual for it.. but you can check with babylock and see if they have a manual
Posted on Dec 15, 2014
Janome 3050 feed dogs wont come back up
Dropping the Feed Dog
The feed dog can be lowered with the drop-feed lever for sewing on buttons etc.
  • Shift the drop-feed lever to the right to lower the feed dog.
  • Shift the lever to the left to raise the feed dog, it will return to the up position when the machine is started.
NOTE:The feed dog should be in the up position for regular sewing. Turn the handwheel toward you to check if the feed dog comes up after setting the lever in the up position
JANOME DC 3050 User Manual Page 9
May 24, 2015 | Janome Sewing Machines
Janome/New HomeHF 2022 How do I raise and lower feed dogs
With the straight stitch set to zero the feed dogs should be down. To use a different number will make the feed dogs rise above the plate.
Oct 23, 2014 | Sewing Machines
How do I get the feed dog up on model 6235
The feed dog for that machine is NOT designed to be raised or lowered; instead a cover is put over the needle plate. You might want to remove the needle plate--it's designed to be removed to access the bobbin case--and see if you can pop it up again. On models that DO have the ability to raise and lower their feed dogs, once it has been lowered, if you press the dial or lever to raise it, it won't raise until the hand wheel is turned one or two times.
Sep 29, 2014 | Singer Sewing Machines
How do I raise or lower the feed dogs
The older machines had the switch directly behind the needle mechanism. Reach behind the machine and see if you can feel it. It should be a slider type of switch. The real old machines did not have the capability of raising and lowering the feed dogs, so an index card was taped over the dogs so that they would not interfere with free motion. Good luck!!
Dec 06, 2013 | Singer Sewing Machines
Can't raise the feed dog on Quantum XL 1000
If I remember correctly you have to raise the feed dog then turn the fly wheel 1 revolution to lock them in place
Feb 07, 2013 | Singer Quantum XL-1000 Computerized Sewing...
I have forgotten the settings to set the differential feed on my babylock 5380E
The differntial feed is usually set on N. If you move the lever up, you gather. If you move it down, the fabric will lettuce. These things happen because there are two sets of feed dogs feeding at different rates.
Aug 09, 2010 | Baby Lock Ellure
Raising and Lowering the feed dog on Janome 4900 MC
These machines are known to have this problem. The feed lift cam has a groove worn in it that won't allow the feed dogs to come back up. It is on the lower shaft and needs to be replaced. You can get the feed dogs back up by taking off the needle plate and lifting them up manually while turning the hand wheel. They should stay up until you drop them again.
Some people will not replace the cam and live with it.
good luck!
Feb 08, 2009 | Janome Memory Craft 4800QD
Feed dogs
I was having trouble with this too, but found more help online...you have to switch the dog feed back to 'up'....then turn the needle wheel toward you....the feed dog should snap back into place :)
Hope this helps :D
Mar 18, 2008 | Sewing Machines
Babylock ellure feed dog will not raise
go see your local parts man. he will know what you need and he will have it there or he will need to order it.
Dec 16, 2007 | Baby Lock Ellure
Sewing Machines Logo
65 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
