Question about New World DW45 450 mm White Built-In Dishwasher 8 Place Settings, A Energy Rating
The diswasher will not program and makes a beeping sound for aprox 1 min before draining when i close door what is it
Pulling it out and chescking hoses blockages etc works when it wants to
Indesit IWD7145K Washing Machine Error code F06 flashing on digital display + all program indicator lights. What does this mean. There is no such error code in the troubleshooting section of the manua
F06 - Door lock fault
Issue: Washing machine door cannot be opened or closed/when the door is closed the machine the programme will not start.
Advice: If your washing machine door will not close, please check for any obstructions in the door lock.
OR,
Switch off the device. Disconnect power. Wait about 3 minutes.
Open the door, then close. Reconnect device to the network.
Start device.
Cause: Door lock fails to close / open door lock triac open / closed,
frequency signal fault
Dado
Feb 12, 2015 | Indesit Washing Machines
Can't open diswasher door. (Triton XL) Tried holding Heated dry button for three seconds and still won't open
unplug from power outlet for 30 mins and plug back, this may reset the safety lock
Apr 18, 2008 | Dishwashers
Hoover HFI 3015 integrated dishwasher beeping on each program cycle selected
Check out the micro switch on the door seems to not indicate that the machine is properly closed or your outlet pump is blocked and needs to be cleaned out,cause it is clogged up and cant remove water properly
Jan 06, 2014 | Dishwashers
Kenmore washer HE3t won't turn on but is making beeping error sound when pressing power button. Is there a reset button to press or common problem
1 Beep/E10--Error: Water doesn't enter Cause: Water supply problem, Check kinks and faucets
1 Beep/E10--Error: Water leaks Cause: Water connections loose,household drain clog,oversudsing. Correct problems.
1 Beep/E10--Error: Dispenser drawer is open Cause: Washer will not operate if drawer is open.
2 Beeps/E20--Error: Water dosen't drain. Cause: Drain is kinked or household clog. Correct.
3 Beeps/E30--Error: Drum overfilled. Cause: Inlet valve,pressure switch or control board failure.Select drain/spin to remove water. Restart.
4 Beeps/E40--Error: Door is open. Cause: Washer will not operate if door is open. Close door.
5 Beeps/E50--Error: Motor is overheated. Cause: Wait 30 minutes to cool down. Restart.
7 Beeps/E70--Error: Cold water doesn't enter. Cause: Hoses crossed,faucet problem.
15 Beeps/EF0--Error: Oversudsing. Cause: Too much detergent,or improper detergent for machine.
15 Beeps/EF0--Error: Hot water doesn't enter. Cause: Hoses crossed,faucet problem.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jul 10, 2010 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question%$@@
Jun 20, 2010 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
I have a Kenmore elite dryer, and the signal cycle keeps beeping and the light switches from on to off with every beep...it does it about 6-8 times then may wait 20 seconds to 5 mins b4 it does it again. ...
May 09, 2010 | Kenmore 67082 Electric Dryer
Haier diswasher flashing lights and beeping after 10 mins i have tried the lean back to 40degrees and it not sorted it ive checked the float switch thats not blocked etc if anyone has any more ideas please...
i took apart the door fiddled with the micro switch which tell the washer the door is closed looks like the switch was worn so i have place a little paper under the switch to get it to make a better contact until i can find a replacment
Dec 06, 2009 | Haier Dishwashers
Beeps while driving
My van did this aswell, you must have a power sliding door, when it is not latched properly this warning goes off but it won't say on your message center "door ajar". Stop and reopen the door and close it again no more bell. good luck.
Aug 19, 2009 | 1999 Pontiac Montana
Does not complete program
Mar 15, 2009 | Kenmore Washing Machines
Machine won't start and clicks if turned on with door open
Ok, this is the fix:
No payload. Close the door. Press off, then press on. Then enter a program starting by selecting the fabric and the others as usual. Do not press start, instead press the slip button to advance the programme to the very last phase, ie drain and empty. Then press start. It will perform this operation with no load and pump out the “no water”. This part takes 5 minutes. After the 5 mins the programme will end and the machine will beep annoyingly, but the computer will be reset and you can clear the program and use the machine as normal.
Why?
I had the same problem. The stupid computer inside remembers the program whilst it’s off and unplugged. What has happened is you accidently pressed start and start again to pause it in very quick succession. This confuses the computer and it thinks that a program is in progress. This is why it wants to close the door. There is no problem with the latch (unless it is a separate problem). You have to let it play out a program to reset it, which is why you can play the very last “drain” segment.
Question.
Presumably there’s a way to reset the computer either by a secret button combo or shorting out two pins from the computer box. I don’t know. If someone knows this please tell me.
Good Luck!
Jun 07, 2008 | Zanussi FJS1225W Front Load Washer
New World DW45 450 mm White Built-In Dishwasher 8 Place Settings, A Energy Rating Logo
60 people viewed this question
Top New World Dishwashers Experts
Owen Barnes
Are you a New World Dishwasher Expert? Answer questions, earn points and help others
