Question about Dishwashers
Troubleshot dead dishwasher
Dead, have power to it. Contractor recently installed new disposal.
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 26 Answers
The contractor may have cut the flow of water to the dishwasher while he was working on the disposal. Look for a cutoff valve in the vicinity where he was working. Good luck!
Posted on Dec 16, 2014
Whirpool built-in puddle of water in bottom, food on drain
see this causes and proceed according. God bless you
Belt, Water Pump Although few dishwashers have a water pump belt, if the dishwasher won't drain there might be a worn or broken water pump belt. After removing the lower kick panel the motor can be seen in the front, the water pump belt is on the bottom of the motor.
Drain Pump If the dishwasher won't drain, the drain pump might be defective. Test the pump motor with an Ohm meter. Drain pumps are not repairable, if it's defective it will need to be replaced.
Drain Impeller The drain impeller is attached to the pump and pushes the water out of the dishwasher, through the drain tube and into the garbage disposer or drain line. If the dishwasher won't drain, the drain impeller might be broken or worn out. Replace both the impeller and seal at the same time.
Drain Solenoid Kit If the dishwasher won't drain, the drain solenoid kit might need to be replaced. The drain solenoid is an actuator that opens a flap to allow the water to drain.
Drain Valve The drain valve can get clogged with debris and should be cleaned out if the dishwasher won't drain. If it seems clear of debris but won't actuate, it will need to be replaced. The drain valve is not repairable Pump and Motor Assembly If the dishwasher won't drain, the pump and motor assembly might be defective. If the motor runs during the drain cycle, check for a blockage in the drain line. If the motor won't run during the drain cycle or if it just hums when it should be running, the pump and motor assembly might need to be replaced.
Clogged or Improperly Installed Garbage Disposer If the dishwasher won't drain and the garbage disposer was installed recently, the installer might have forgotten to knock out the drain plug from this disposer. All garbage disposers are sold with a solid plug in the drain tube for situations where a dishwasher isn't connected. However, if the dishwasher is connected, the plug will need to be removed. If the disposer wasn't replaced recently, remove the dishwasher drain hose from the disposer and clean out both the fitting on the disposer and the end of the drain hose. These are the most common places to find an obstruction if the dishwasher won't drain.
Check Valve If the dishwasher won't drain the check valve might be stuck closed. The check valve is a small plastic device which prevents water from returning to the dishwasher after it has drained. If the valve gets stuck closed, it will prevent the water from draining. The check valve is the device that the drain hose is attached to on the dishwasher.
Check Ball If the dishwasher won't drain the check ball might be stuck. The check ball is a small plastic ball in the check valve which prevents water from returning to the dishwasher after it has drained. If the ball gets stuck, it will prevent the water from draining also. The check valve is the device that the drain hose is attached to on the dishwasher.
Oct 16, 2012 | Whirlpool Dishwashers
My dishwasher was recently 'installed'. i don't know if the contractor made a mistake or if the water valve is not turned on, but the cycle tries to start but then no water is flowing into the dishwasher....
This sure sounds like a water valve issue, for sure. You will have to trace out the lines (not easy, but possible) and figure out where the valve is. They usually turn left to open, and right to close. I would call the contractor and tell them what's going on- they could hopefully tell you where the valve is, and how to make sure it's on. The person who installed it should know.
Good luck, hope this helps, and thanks for using FixYa.
Sep 20, 2010 | Frigidaire Professional Series 24 in....
Dishwasher is not draining correctly in the air vent on top of sink. Recently had a new garbage disposal installed and this is the first time using the dishwasher since installation of disposal.
Hi and welcome to Fixya, I'd suggest you start by checking the drain spout of the disposer where they ( the installer ) connected the drain hose from the dishwasher and make sure they've knocked out the plug in the spout. **Turn off the power or unplug the disposer/garberator before performing any service** If the plug is not punched out, with the aid of a long screw driver and a hammer, or a firm smack with the palm of your hand you should be able to knock out the plug. Then reach in the disposer and remove the plug you`ve just knocked out, reconnect the drain hose for your dishwasher and you should be good to go. Thank you for visiting "fixya". Please take a moment to rate the solution provided here for you. Hope that help`s. Good luck. macmarkus :)
May 31, 2010 | Maytag Dishwashers
Bosch SHX99A15UC went completely dead. Circuit
no it wouldn't, this is a common failure on bosch dishwashers. you have either a bad control or a bad touch membrane. parts are fairly expensive and only way to know for sure is to replace one. I usually find that the control panel is at fault most times
Apr 23, 2010 | Bosch 24 in. SHX99A15UC Stainless Steel...
The water will not empty
Have you had a new disposal installed recently and does the drain connect to this? If so remove drain hose from disposal and knock the plug out.
Jan 27, 2010 | Electrolux 18 in. ESL4114 Slim-Line...
Power up to the control panel \ Dishwasher dead
First, power usually comes in from plug, under the kitchen sink, and shares a socket with the disposal(which is controled with the wall switch) make sure you are plugged into the right recepticle. try a lamp or something in the plug make sure it's got power. then check where the cord attaches to the dishwasher..usually behind the kickplate bottom, right front. Dissconnect power then remove the cover at that point you might find the wire nuts or connection is loose..if that is good ...then there could be a broken wire in the that feeds the timer/controller..those are hard to find...a wire that looks good but within the insulation of the wire, it's broken, usually where the wire bends at the bottom of the door.
Oct 24, 2009 | Maytag Dishwashers
The water will not drain out of the dishwasher.
did you recently install a new disposal?
if so make sure to remove knock out at drain hose end connection on disposal
otherwise clear drain hose of grease and gunk
or on rare occasion you may need a new drain pump
most commonly a clogged drain hose
Oct 08, 2009 | Kenmore Dishwashers
I have a new dishwasher and it won't start. it is set for normal wash and heated dry. when i close the door and push start, it doesn't start.
You don't say if it does anything at all or is just dead. I'll guess just dead.
First, make sure you have power to the dishwasher. Breakers all on? Some homes have the dishwashers plugged into an outlet under the sink. Usually one of these outlets is switched (for disposer) and the other half of the outlet is live, for a dishwasher. If you have the outlet connection, plug a lamp into the recepticle to make sure you have power. Some outlets may even be "downstream" from a GFI recepticle which may be tripped. Second, you may have to check to make sure the twist wire nut connectors are all good and tight on the white, black, and ground wires at the connection to the dishwasher. Hold the wire nut and tug on the wires to make sure they stay in the wire nut.
Aug 27, 2008 | GE Dishwashers
New Garbage disposal, washing machine and dishwasher won't work.
Does not sound like these problems are directly related to the disposer. Grinding sound is most likely the impeller on the washer's pump. The washer gets to the first pump out and is unable to pump due to bad impeller or an obstruction. Bad impeller means replace pump motor. (not very hard) Check water supply to dishwasher. Valve turned off or line kinked? Filter screen at solonoid valve plugged?
Aug 15, 2008 | LG WD-3243RHD Front Load Washer / Dryer
SHU43 Bosch Built-in dishwasher
Try running citric acid (3 tablespoons) through.
You can get it from a drug store.
Or, run 1/2 cup vinegar through.
Do this in both the dish washer and the disposal.
After doing this try running some water into the disposal and then see if the next time you run the dishwasher if it still smells.
You could be having a problem with water not staying in the drain trap under your sink that is why if you run water and fill the trap, then you will find out if it was the dry trap that caused the smell from sewer gases backing up into the house trough the garbage disposal.
Apr 30, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishwashers Logo
48 people viewed this question
Top Dishwashers Experts
Owen Barnes
