Question about Beko Refrigerators
What's wrong? turned off my beko f/freezer AB910s after it stopped working. turned it back on after 24hrs it worked for another two wks,in that period every now & then these symbols would show in the front window including fridge too warm and others that did'nt make sense, i used the fast freeze button, it started working again. now after 3 days, it stopped working . turned it off and back on, the number 8 showed in the front window, still not working, turned it off for 24hrs, and back on, the warm sign lit up including half signs that did'nt make sense. tried to use the fast freeze button but none of them would work. turned it off again. hope someone can help.
  • 29 Answers
SOURCE: Our beko frost free fridge
the thermostat in the fridge is turning off your compressor before the freezer has completed its job.this is because it doesnt care about the freezer temperature only the temperature where its located in this case the fridge,try completely defrosting the fridge and restarting it
Posted on Aug 13, 2008
tborn6
  • 700 Answers
SOURCE: kenmore fridge stopped cooling
sounds like its freezing up on you. check the drain outlet and make sure that its clear. also i would replace the defrost timer on this unit because its suppose to bring on the heaterfs to melyt the ice so thaat yoiu don't have to. they are around 30 mdollars at the appliancew repair store and all you need is the model number and serial number for the uit. after you get it it's either on the very top of the refrigerator section or in the very back. It has 4 wires going to it. good luck.
Posted on Jan 12, 2009
  • 340 Answers
SOURCE: my fridge won't cool down or freeze
Your condenser is likely dirty clean it. the compressor could be tripped out on over load (to hot) unplug the fridge a couple hours should do it . plug it back in make sure the thermostat is on and set correctly if that does not work you will need service. Tom
Posted on Jun 17, 2009
SOURCE: Fridge doesnt work, freezer works
You need to change the freezer fan motor. FF means problem with the Freezer Fan.
Posted on Oct 19, 2009
SOURCE: bosch fridge freezer stops working after approx 8
Found a solution at
www.reviewcentre.com/vt100228_start50_orderasc.html
Short out the dark blue and the dark brown wires that lead into the temp control dial. Everything now works. This bipasses a dodgy thermister or something. Of course this might not solve all similar problems but it does seem a common fault.
Posted on Dec 15, 2009
My Beko AB910S/1 is freezing the food on the bottom two shelves of the fridge. My wife commented it was making more noise than usual the day before this started to occur. ANy common faults?
The coldest part of your fridge is at the bottom. The bottom shelf will freeze before the top. Check the temperature with a thermometer - its should be about 6 degrees. Trying turning the fridge down a little. If this doesn't put things right chances are the thermostat has stuck and needs to be replaced.
Oct 22, 2013 | Beko Refrigerators
Why has my fridge freezer started to make a louder humming noise?
no problem with that it is normal..your ref working properly it is just the motor you hear
May 22, 2012 | Beko Refrigerators
I have a 52"
Need model number and blink code at time of defect.
Feb 16, 2011 | Panasonic Televison & Video
BEKO Frost free freezer not as cold as it should be!
Sorry I don't have a solution for you, however would like to know if you found out what was wrong. I have an identical problem with my Beko fridge/freezer. It's only 14 months old and the freezer just wont freeze. I've turn it off for 24 hour and let it defrost completely (even had the panel off to make sure there was no ice left). I've turned it back on again and it still wont freeze. Everything seems ok, ie fan blowing, motor running etc. I really am beginning to regret buying Beko. thanks
Apr 12, 2009 | Freezers
Refrigerator not cooling
These units suffer from freezing up the evaporator in the freezer, before loooking for a fault I would suggest turning unit off for 24hrs leaving the door open, restart and within 24hrs the unit should work ok.
Regards
Advisor
Nov 11, 2007 | Whirlpool GS6NBEXR Side by Side...
Beko fridge freezer not working... not cooling
yes it can b fixed is the fridge running ? if it is it will need re gasing which is a common fault with beko and you should not pay more than £40 for the re gas if it is not running it will b either your thermastat which again you should nt pay more than £48 4 or the compressor which will b aprox £120 supply and fit none of the above should b done by a novice good luck
Sep 07, 2007 | Refrigerators
Fridge is hot while freezer works fine
Defrost for 24hrs with doors open, turn back on it will then work ok. Regards Advisor
Aug 18, 2007 | Kenmore 73502 / 73504 / 73509 Bottom...
Amana bottom Freezer Refrigerator
Fan motor probably iced up, turn off defrost for 24hrs with doors open turn back on and should be working within 24hrs. Regards Advisor
May 14, 2007 | Amana ABB1927DE Bottom Freezer...
Refrigerators Logo
Top Beko Refrigerators Experts
John Tripp
John Tripp
mike cooper
Are you a Beko Refrigerator Expert? Answer questions, earn points and help others
