Question about Miscellaneous
Steamist sm-7 Heat element does not go off when unit turned off. Steam stops (water stops flowing) but can hear heat element still going.
Turn off at breaker box, turn back on problem still occurs
SOURCE: Heater element ignites, but turns off before gas begins flowing which stops the process.
clean your flame sensor with a piece of wool
Posted on Feb 27, 2007
  • 4 Answers
SOURCE: Heat turns off
Sounds like the high limit switch on the heater is kicking off. The flash is the switch shutting off the heating element. The only way to reset it is to turn unit off for about 5 minutes. Possible problems are: 1.) Bad thermostat 2.) blower motor not turning fast enough which means motor is bad.
Posted on Oct 13, 2007
jsrock516
  • 5911 Answers
SOURCE: bottom element will not turn off
Your BAKE element relay on the Electronic Oven Control (EOC) Board is shorted.  I have experienced this problem before.  The board is not serviceable and (unfornately) you will have to replace it.  The board can run anywhere from $100 to $200 for a new one.  Slightly less for a refurbished one.  Prices will also vary depending on source.  This is a repair you can do yourself if you choose to do so.  If you can provide me with your model number (located inside the lower door panel), I can do some research to get a part number and price for you.  Let me know.  I hope this is helpful.
Posted on Oct 31, 2007
tonybudz
  • 162 Answers
SOURCE: Stove top or oven will not heat
Next time buy a Kenmore? J/K
Posted on Aug 12, 2008
  • 11 Answers
SOURCE: thermostat says ''Aux heat on'' and buzzes when we turn on heat
You most likely have a heat pump, the aux heat (usually electric) comes on anytime the room temperature is 4 degrees below the thermostat setting. Does the buzz go off when the aux heat lite goes out? If the aux heat does not shut off then the primary heater (heat pump) is not putting out enough heat to satisfy the thermostat. I need a little more info. Do you have a heat pump? Is it working?
Posted on Nov 26, 2008
Mr Steam MS Super-1 kW: 10 doesn't generate steam
the first thing the generator should do when you hit the on button is fill. You will hear the water entering the tank. Once the water stops it indicates that the water has reached the water satisfied level, after which you should hear a loud click(your contactor engaging for the heat cycle, newer units will have all three light on the side lit). After this point is you aren't getting any steam after 5 minutes it probably means your heating element may be damaged. It would be best to remove the element at this point from the left side of the unit via 6 bolts and 2 wire leads. Any physical damage on the element such as a pinhole pop, burn mark, melting, or scar will surely prevent the element from heating
Jan 10, 2014 | Mr Steam Electrical Supplies
I have the Mr Steam MS Super 1 T steam unit with the Tempo Plus accessories and auto flush. The unit has worked great for about 2 years but for some reason yesterday the unit light comes on at the...
You would need a multi-meter or voltmeter to trace the power path. Turn on the generator and wait until you hear the water feed solenoid stop. This means the water has reached the satisfied level and the pc board should have sent 24v to engage the contactor. On the actual pc board there is a section label "cont" which is what sends the 24v to the contactor the engage the heating element. Verify that you have 24v on the spade terminals going out to the contactor, if not then you may have a pc board issue. Second possibility is the contactor, if it is recieving 24v and it is not engaging then it's simply a bad contactor. Check the load side of the contactors with the blue wires. Lastly if these two steps check ok, then perform an ohm reading with a multimeter on the actual heating element(with the power off, put your two test leads on the two flathead screws that hold down the blue leads the go to the heating element). If you get an open reading then this may indicate a failed heating element. Pulling the heating element out on the left side panel will confirm any element failure.
Nov 08, 2012 | Mr Steam Ms Super 1e Steam Shower...
SM-79 turns on normally and operates for about 5 minutes. Enclosure temperature goes up to about 79 degrees and the unit turns off. Very hot water issues from outlet until thermostat is turned off. ...
Hi Russell.
I am going to suggest contacting Steamist since they are the experts in this product.
http://www.steamist.com/contact.htm
My understanding is Steamist has 5 year parts warranty, and 3 year labor warranty, which is good warranty.
It seems you have passed the warranty period, and 16 years is a good run for any type device.
The contact e-mails includes 'literature' so you can order a manual, 'troubleshoot' so can get directions from the folks who make the product, and email for sales manager.
I would also inquire about authorized service center, and ask what is likelihood of getting long-term repair vrs buying another unit.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on any do-it-yourself project.
Fixya is always less expensive than a service call.
Feb 11, 2011 | Steamist SM-79 7900
I have a Steamist SM-8 and I am receiving an E4 error message on the control panel. What does this mean?
1) Steamist SM-8 is a Steambath steam generator with 5 year parts warranty and 2 years labor
http://www.faucetdepot.com/prod/Steamist-SM-8-IM-InstaMist-Steambath-Steam-Generator-29984.asp
2) Steamist website does not have manuals that we can immediately download and look at error codes alongside you.
3) However your manual has that information, and you can add a comment and say what the manual suggests as troubleshooting, so we can offer some level of do-it-yourself help.
4) Perhaps you could scan your manual into pdf format and post your manual on your website.
And then add a comment with web location of manual so we can download and read your manual, alongside you, and perhaps offer additional do-it-yourself solution for you.
For example check that circuit breaker is delivering 240V to product, and element is not burned out, and there are no loose wires, and condensing reservoir is not clogged with sediments that can be cleaned with CLR.
5) The manual is key: I'm sure the manual also shows regular maintenance needed to ensure long life of product. For example avoid exposure to hard water, use water filter, clean reservoir and lines regularly. Avoid freezing.
I always tell people to save product manual like gold and read it cover to cover because it will save money and trouble long-run.
6) Steamist website has contact us link: With direct e-mail to 'troubleshoot' and 'literature'
I suggest next step should be contact manufacturer and request each of the following: a) a manual b) do-it-yourself assistance c) warranty information d) name of authorized technician to make repairs.
For a price, expert speaks with you over phone while you work on steamer or any do-it-yourself project.
Feb 03, 2011 | Steamist Hardware & Accessories
Do I need to install a water softner before installing sm-79
you should not have to, but if the steamist is not gernerating the right amount of steam then you should put a sofftner on. you will be able to tell because it might have a hard time producing steam, but don't jump the gun right away.
Dec 09, 2010 | Steamist SM-79 7900
My SM11 model Steamist was installed above our shower/steam room. It is 2 years old. While in use recently, it made a loud sound like a low-pitch popping sound or low boom. Imagine somebody inside a...
The heating elements had burned up in the unit therefor creating a dead short on that circuit. Main breakers on homes and buildings are VERY sensitive and will sometimes trip before the smaller branch cicuit breakers will . So the popping you heard was the heating elements breaking down inside the unit it can be some what noisy.
Nov 03, 2010 | Steamist 1100 Sm11 Large Capacity Steam...
No steam is coming out of the outlet in the steam room, but alot of water comes out of it
Check the breakers that feed power to the unit--turn off, then on. If no help, remove power from the unit and measure the resistance of the heating element--it should measure somewhere around 20 to 30 ohms, but not infinity. Hope this helps!
Apr 09, 2010 | Steamaster Steamist SM-8 Fixed 8 Kilowatt...
Miscellaneous Logo
Top Miscellaneous Experts
Andy Fraser
Andy Fraser
Dan Grod
Level 1 Expert
dennis lewis
Level 1 Expert
Are you a Miscellaneous Expert? Answer questions, earn points and help others
