Have a Harris Vent Free Propane Gas Log, 65% gas left, the pilot will not stay lit.....any help?
Taken everything apart and cleaned thoroughly, made sure we had gas, re-connect gas line using better connectors
    Champion:
  • 305 Answers
Check the pilot generator for proper current. check from PP terminal to TH/PP terminal while pilot is still lit. you should be getting well over 250dc millivolts. if not, replace the pilot generator
Posted on Dec 31, 2014
  • 6 Answers
SOURCE: Propane fireplace insert won't light
Gas apliances have safety features built into them so you don't blow yourself up. The pilot heats a thermocoupler which tells the gas valve there is a flame, open the main gas to the burner. If you can see the flame area of the pilot look for a round post about 3/16 inch in diamiter. This should be directly in the flame, if not bend the bracket so it is in one side of the pilot flame. The thermocouple is attached to a mounting bracket. This will be held in place by a 1/4 inch hex screw. remove the screw and the capilary tube leading to the gas control valve. Before you do anything, close the main gas supply to the fireplace and disconnect the power to the fan. You may need to semi dismantle the fireplace to get the thermocouple. The gas valve end is a brass 1/4 pipe thread plug. Turn the outer nut and remove without twisting the tube. Reverse this order to install a new one. Besure not to twist the capilary tube, tighten brass nut 1/4 turn past hand tight. Your better heating supply house will have these in stock. Restarting the pilot will take a few tries because the gas was off. Your gas suplier would charge about $75 to fix this. if you don't have the proper tools and it dosen't look pretty stright forward don't do it. You could get dead.
Posted on Dec 02, 2008
  • 2597 Answers
SOURCE: Bad odor from vent free gas logs.
it could be leaking when the fire place is on you said you checked for leaks was this to the burner as well ? it sounds like unbrunt gas check the burner , hope this helps , are you feeling sick or headaches as this would b e fumes ?
Posted on Jan 14, 2009
  • 139 Answers
SOURCE: My vent free Desa natural log will run for a short
it is likely you have dirty O2sensor, it is incorporated into pilot assembly.turn unit off,use compressed air in a can and blow into spot where pilot flames comes from.this will fix it in most cases.in a small % of time entire pilot assembly needs to be taken apart and cleaned
Posted on Jun 25, 2009
  • 70 Answers
SOURCE: I have a set of propane gas logs. The pilot light
Check the connection of the thermocouple or replace it if connections are tight.Pilot safety valve may be badreplace gas control valve.
Posted on Oct 24, 2009
  • 75 Answers
SOURCE: pilot lites; but, as soon as I turn on gas flame
sounds like your thermacouplar is going out and needs replaced. Sometimes these will act like they are working fine , but when the pilot stays on for awhile and later goes out it is a sure sign that it is bad
Posted on Nov 08, 2009
Lights but turns off in about a minute
It might have a built in thermostat that will light the heater when room temp falls below a certain temp. It should then relight and warm things back up. As long as the pilot stays lit it should work just fine.
Feb 08, 2014 | Emberglow Melbourne Oak 24 in. Vent-Free...
Small explosions
What is the make and model of the gas valve? They are not made to be taken apart and so the springs might be in wrong or the calibartion screws set wrong. At this point you probably are going to end up having to replace it.
Nov 28, 2013 | Empire Direct Vent Wall Furnace;...
I have a Jayco pop up with an Atwood water heater, serial # 37C14U-5. My problem is two-fold. The water heater pilot doesn't stay lit after initial run, and propane is leaking out of the vent on the...
Leaking propane is red flag #1 and fire hazard.
Immediately update your insurance and then turn off gas.
If pilot is not staying lit, then gas leak can be cause of pilot problem since pressure on the line is reduced.
Other causes include bad gas control valve, air in the gas line, bad thermocouple, burner parts need cleaning, or all the above.
After fixing leak, replace thermocouple, clean combustion chamber and burner parts, and bleed gas line to remove air.
More resources:
http://waterheatertimer.org/Atwood-water-heater-resources.html
Jun 28, 2011 | RTO Atwood Water Heater - 6 Gal LP
Pilot lite will not stay lit, have a full tank of propane
YOU WILL HAVE TO TAKE THE TUBE FROM THE CONTROLLER TO THE PILOT TIP APART AND CLEAN OUT THE ORFICE AS THE SPIDERS MAKE NESTS IN THEM.
Nov 12, 2009 | Hayward H Series Pool & Spa Heater 400k...
Oct 24, 2009 | Desa International CCL3924PTA 24" LP Gas...
Have Model CGP30TB Copmfort Glow propane heater. Pilot light won't stay lit. Flames also coming from what seem to be air vents just below flame on pilot light.
sounds like an obstruction in pilot assembly.try using canned compressed air to blow directly into pilot. this technique is successful about 70%. if not,pilot assembly must be removed and cleaned thorougly
Sep 10, 2009 | Desa International Comfort Glow Infrared...
Jun 25, 2009 | Desa International Unvented Gas Space...
My ventless propane heating stove shuts off by itself
I have a Rinnai Ventless heater hooked up to a 20 lb propane cly with a Moble home type regulator in line, and when I light it the pilot light lights and stays on. When I turn it to the heat position the pilot light go's out and that it!
Jan 28, 2009 | Rinnai Desa Vent-Free Infrared Gas Heater:...
Heating & Cooling Logo
43 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
