Question about Pool & Spa
Control says water sensor opened what does that mean-- not heating properly
I havent tryed anything yet
    New Friend:
    Problem Solver:
  1. Refit pool sensor cable to the left of roof sensor plug - no gap between them
  2. Check for breaks in cable, repair as per instructions from supplier
  3. Replace sensor
Depending on your controller model, Sunlover Heating may be able to help you.
Check out: http://sunloverheating.com.au/products/solar-controllers/
Check ou
Posted on Dec 16, 2014
Error code list
ALARMS THAT STOP THE DISHWASHER
A1 Want of water
Is the water cock open?
Does the water load solenoid valve work?
Is the water feed flow a min. of 5 l/min?
Is the water inlet filter clean?
Is the load solenoid valve filter clean?
Is the overflow inserted?
Do the tank/boiler pressure switches work properly?
C9 Automatic hood out of order
Alarm codes for automatic hood type dishwasher (see paragraph 9.2.1 Alarm codes for automatic
hood type dishwashers)
C12 Tank level sensor out of order
Are the connectors correctly connected?
Are connector contacts cleaned?
Does the air trap of the tank work correctly?
Is the level sensor broken (replace it with a new one)?
Alarm codes for automatic hood type dishwashers
When the alarm C9 appears, to facilitate fault-finding a parameter providing a more detailed indication has
been introduced.
The parameter is C9 and is found in the ron family.
The possible cause of the anomaly can be found (see next table) according to the value of the parameter C9.
E.g.: With an automatic hood type the alarm C9 appears.
Access the parameter C9 in the ron family.
Assuming the value displayed is:
20 ? During lifting, the current absorbed by the lifting motor has exceeded the threshold. This can happen if
a rack or other heavy material was placed on the hood.
ALARMS THAT DON'T STOP THE DISHWASHER (SHOWN ON THE USER INTERFACE AT REGULAR INTERVALS)
b1 Drain not efficient
Has the overflow been removed?
Is the water drain blocked?
Is the drain pump blocked?
Are the air trap and tank pressure switch clean?
Is there a constriction in the drain tube?
Is the pump breather pipe returning to the tank clogged or constricted?
Does the tank pressure switch work properly?
Is there a hole in the drain tube (only for versions with drain pump)?
b2 Overflow alarm
Is the load solenoid valve blocked? (see electrical wiring diagram - YV1 Filling solenoid valve)
Is the load solenoid valve relay stuck? (see electrical wiring diagram - RL5 relay of AP2 board)
C1 Boiler temperature rise too fast
Does the boiler level sensor work properly? The boiler could be empty.
Are no-original power resistances installed?
C2 Boiler temperature too high
Has the boiler temperature been changed (btC - increased above 90°C)?
Has the software alarm value been modified (bH,)?
Boiler relay/relays sticked (see electrical wiring diagram - RL1/ RL2/ RL3 relays of AP2 board)?
C3 Tank temperature too high
Is the feed water above 60°C?
Has the software alarm value been modified (tHi)?
Is the rinse water temperature too high?
Is the tank relay stuck (see electrical wiring diagram - RL4 relay of AP2 board)?
C4 Tank temperature sensor out of order
Is the temperature sensor broken or disconnected (see electrical wiring diagram - ST1 Tank
probe)?
Is the temperature sensor connector correctly inserted?
C5 Tank temperature sensor out of order
Is the temperature sensor short-circuited (see electrical wiring diagram - ST1 Tank probe)?
C6 Boiler temperature sensor out of order
Is the temperature sensor broken or disconnected (see electrical wiring diagram - ST2 Boiler
probe)?
C7 Boiler temperature sensor out of order
Is the temperature sensor short-circuited (see electrical wiring diagram - ST2 boiler probe)?
C10 Rinse temperature sensor out of order (only on machines with temperature sensor on the rinse circuit)
Is the temperature sensor broken or disconnected?
C11 Rinse temperature sensor out of order (only on machines with temperature sensor on the rinse circuit)
Is the temperature sensor short-circuited?
C13 Rinse pump out of order (the water level of the boiler does not decrease)
Does the rinse pump work correctly?
Is there any bottleneck in the hose, that connect the air trap and the board sensor?
WARNING:
Alarms C2, C6 and C7 lock the boiler temperature control.
Alarms C3, C4 and C5 lock the tank temperature control.
In the case of alarms C6 and C7, the boiler waiting phase is not executed (the rinse may be performed
with cold water) and, during the initial warm-up and subsequent rinses ( btF > 0 ), the boiler heating
phase is not executed.
In the case of an open probe error ( C4, C6 e C10 ), the displayed temperature is 10°C
In the case of a shorted probe error ( C5,C7 e C11 ) , the displayed temperature is 99°C.
E1 Communication error
Is the connection between main board and control panel correct? Are the connectors correctly
connected?
Are connector contacts clean?
E2 Tank temperature low
Does the tank heating element work properly?
Are the dishwasher feed voltage and current correct?
Is the relay RL4 (see electrical wiring diagram - RL4 relay of AP2 board) on the board disconnected
or faulty?
E3 Boiler temperature low
Does/do the boiler heating element/s work properly?
Does the possible remote control switch connected to the heating element work correctly?
Is there power at the remote control switch input terminals?
Do boiler relays (see electrical wiring diagram - RL1/ RL2/ RL3 relays of AP2 board) work properly?
CAUTION: IF THERE IS A MALFUNCTION ON RELAY RL1 AND THE BOILER HEATING ELEMENTS
ARE FED BY MEANS OF A REMOTE CONTROL SWITCH, THE BOARD DOES NOT
HAVE TO BE REPLACED; JUST MOVE THE BOILER HEATING ELEMENT CONNECTOR TO
ONE OF THE TWO FREE POSITIONS ON THE BOARD.
CAUTION: WHEN ONE BRANCH OF THE HEATING ELEMENT DOES NOT WORK AND THE
OTHER TWO CONTINUE TO FUNCTION, ON REACHING THE SET TEMPERATURE VALUE,
ALARM 3 DISAPPEARS AND REAPPEARS IN THE SUBSEQUENT RINSE PHASE. THIS
ALSO OCCURS WHEN A PHASE IS MISSING.
Dado
Sep 01, 2014 | Zanussi Dishwashers
Tip
LG Washing Machine Error or Fault Codes
If you have a LG Washing Machine you may see an error code come up and wonder what it is. Here are the common error or fault codes that will be displayed on the LG washing machine.
OE
This means that the washer has tried for ten minutes to drain the water out of your machine and the water did not drain out.
UE
This means that the load in the drum is out of balance causing excessive vibration when spinning.
IE
This means that the washer has not filled with water in 8 minutes.
LE
This means that the motor and the control panel are not talking to each other properly
PF
Power Failure – The power has gone out to the machine and then has come back on
FE
This means that there is too much water in the machine
PE
This means that the water level sensor is not working properly
CE
The washer motor has received and over current condition
TE
This means that your heating sensor is not working properly
SE
This means that you had a temporary sensor error
HE
This means that you had a temporary heater problem
DHE
This means that you had a temporary dry heater problem
This will give you a basic idea of what has caused your error code.
http://www.fixya.com/support/r4342015-lg_washing_machine_ie_error_code
http://www.fixya.com/support/r4341906-ue_error_code_lg_washing_machines
http://www.fixya.com/support/r4341798-lg_washing_machine_oe_error_code
http://www.fixya.com/support/r4341643-lg_washing_machine_error_or_fault_codes
http://www.fixya.com/support/r4348161-lg_washing_machine_le_error_code_or
on Mar 15, 2010 | Washing Machines
SUDsamsung washer error codes
• dc--Unbalanced load preventing washer from spinning
• dL--Door is in locked when washer is running
• dS(d5)--Door is open when washer is open
• FL--Washer failed to lock the door
• Hr--Water temperature control problem(Heat control problem)
• LE--Washer tried to fill but has not reached proper water level(Slow fill)
• LO--Door will not unlock
• E3--Motor not running properly
• nd--Washer is not draining/Washer senses a brief restriction while draining
• nF--Washer tried to fill but was unsuccessful
• Sr(5r)--Problem with control
• PF--Power failure, electric service was lost while washer running
• OE--Fault detected in water level sensor
• E2--Jammed key
• bE--Motor speed sensor problem
• tE--Temperature sensor problem
• 3E--High current detected
• 2E--High/low voltage detected
• 8E--Vibration sensor problem
• 7E--Silver Care control problem
• SUdS--Too much suds detected during wash cycle, unit on hold until suds reduced
Nov 12, 2013 | Washing Machines
P1684 - 1683 - 0135 - 0442 - 0455 error codes
P1684
It is not a fault code per say, it only indicates the battery has been disconnected or went dead in the last 50 drive cycles I believe.
P1683
This code refers to the cruise control speed servo power circuit is open or shorted. The power comes through a normally-on contact in the brake light switch. Use a test light or voltmeter to measure the voltage on the yellow wire / red stripe on the switch. If it's there, measure on the dark blue wire / red stripe. If it's missing there, the switch is defective. The voltage should go to 0 volts there when the pedal is pressed.
The rest of the fault codes are as follows.
P0135 - O2 Sensor Heater Circuit Malfunction Bank 1 Sensor 1
Possible causes- Faulty Heated Oxygen Sensor (H2OS) Bank 1 Sensor 1
- Heated Oxygen Sensor (H2OS) Bank 1 Sensor 1 circuit fuse
- Heated Oxygen Sensor (H2OS) Bank 1 Sensor 1 circuit open shorted to ground
- Heated Oxygen Sensor (H2OS) Bank 1 Sensor 1 circuit poor electrical connection
- Faulty Engine Control Module (ECM) Help with thisTech notes The code means that there is a problem with the heater element circuit of the heated oxygen sensor. The control module monitors how long it take the sensor to warm up and start sending an adequate signal. The code is triggered when the sensor is taking too long to warm up. Water getting inside the heated oxygen sensor connector can caused the heated oxygen sensor fuse to blow. Before replacing the sensor, check for the condition of the heated oxygen sensor fuse and connectors. If the sensor and connector are OK, replacing the O2 Sensor 1 usually takes care of the problem.
P0442 CHRYSLER - Evaporative Emission Control Small Leak Detected.
Possible causes- Missing or loose fuel cap
- Incorrect fuel filler cap used
- Fuel filler cap remains open or fails to close
- Foreign matter caught in fuel filler cap
- EVAP canister or fuel tank leaks
- EVAP system hose leaking
- Fuel tank leaking
P0455 CHRYSLER - EVAP System Large Leak.Possible causes- Missing or loose fuel cap
- Fuel tank leaking Tech notes The P0455 it's a very common code, because the code is set if the gas cap is loose or missing. Start by tighten the gas cap and clearing the code. In most cases the code can be clear by disconnecting the car battery for about 30 minutes.
Dec 04, 2012 | 2001 Chrysler Town & Country
P0037. heater sen. where is it on the engine?
The code is for the heater in the O2 sensor bank one sensor two. That would be the sensor after the catalytic converter on bank one.
It could be the sensor itself or the power supply for the heater.
Aug 25, 2012 | 2006 Mazda MPV
What code mean po302,,,,po135...p1705
P0302 TOYOTA - Cylinder 2 Misfire Detectedxicon.jpghttp://engine-codes.com/p0302_toyota.htmlForum CodePossible causes- Faulty spark plug 2
- Faulty ignition coil 2
- Ignition coil 2 harness is open or shorted
- Ignition coil 2 poor electrical connection
- Clogged or faulty fuel injector 2
- Injector 2 harness is open or shorted
- Injector 2 poor electrical connection
- Improper spark plug 2
- Insufficient cylinder 2 compression
- Incorrect fuel pressure
- Intake air leak
P0135 - O2 Sensor Heater Circuit Malfunction Bank 1 Sensor 1xicon.jpghttp://engine-codes.com/p0135.htmlForum CodePossible causes- Faulty Heated Oxygen Sensor (H2OS) Bank 1 Sensor 1 circuit
Tech notes The code means that there is a problem with the heater element circuit of the heated oxygen sensor. The Engine Control Module (ECM) monitors how long it take the sensor to warm up and start sending an adequate signal. The code means the the sensor is taking too long to warm up. Replacing the O2 Sensor 1 usually takes care of the problem
P1705 TOYOTA - Direct Clutch Speed Sensor Circuit Fault.
This is related to the sensor that gives info about the slippage rate o fthe transmisssion to the Transmission Control Module..
Jul 15, 2012 | 1996 Toyota Camry
What is the code p00300
this is an obd2 trouble code table, it can help you understand the meaning of code.
for po300:
Possible causes of OBD code P0030:
Heated Oxygen Sensor (H2OS) Bank 1 Sensor 1 circuit open shorted to ground - Heated Oxygen Sensor (H2OS) Bank 1 Sensor 1 circuit poor electrical connection - Faulty Heated Oxygen Sensor (H2OS) Bank 1 Sensor 1 circuit - Heated Oxygen Sensor (H2OS) Bank 1 Sensor 1 circuit fuse - Faulty Engine Control Module (ECM) The Error code is generally activated on detection of the following conditions: The P0030 is set when the ECM detects an open or shorted to ground condition on the heated oxygen sensor heater circuit
Possible Solutions:
The code means that there is a problem with the heater element circuit of the heated oxygen sensor. Water getting inside the heated oxygen sensor connector can caused the heated oxygen sensor fuse to blow, which is a very common problem for this type codes. Before replacing the sensor, check for the condition of the heated oxygen sensor fuse and connectors. HO2S Heater Control Circuit Bank 1 Sensor 1 is the generic definition for the P0030; however your vehicle's manufacturer may have a different definition and information for the P0030 code.
hope help.
Jun 22, 2011 | Nissan Altima Cars & Trucks
Subaru wrx impreza showing fault code p0037. how do i fix this fault which sensor is it and where is the sensor located?
http://helpforcars.net/obd_codes/codes.php?code=P0037
It's an O2 sensor according to the above link, and it is bank 1 sensor 2 low, the 2 meaning that it is downstream past the catalytic converter but not on the manifold.
- Heated Oxygen Sensor (H2OS) Bank 1 Sensor 2 circuit open shorted to ground
- Heated Oxygen Sensor (H2OS) Bank 1 Sensor 2 circuit poor electrical connection
- Faulty Heated Oxygen Sensor (H2OS) Bank 1 Sensor 2 circuit
- Heated Oxygen Sensor (H2OS) Bank 1 Sensor 2 circuit fuse
- Faulty Engine Control Module (ECM) Possible Solution Tech Notes The code means that there is a problem with the heater element circuit of the heated oxygen sensor. Water getting inside the heated oxygen sensor connector can caused the heated oxygen sensor fuse to blow, which is a very common problem for this type codes. Before replacing the sensor, check for the condition of the heated oxygen sensor fuse and connectors.
Good luck on this repair.
Jan 01, 2011 | 2001 Subaru Impreza
Error codes
Here are the common error codes for the LG machines.
If you have a LG Washing Machine you may see an error code come up and wonder what it is. Here are the common error or fault codes that will be displayed on the LG machine.
OE
UE
IE
LE
PF
FE
PE
CE
TE
SE
HE
DHE
Heatman101
Mar 15, 2010 | LG WM2277H Front Load Washer
Hi my myson orion has a pilot but nothing coming out of the main burners when demand for heat hot water, please help. cheers
A furnace goes through more checks than the Shuttle before it lights! First, on the control board, are there any lights blinking, if it did light, there should be. Somewhere there is a placard showing what the number of blinks means; I need to know what is says on the placard. In the meantime, check the draft fan sensor - it looks like a small flying saucer towards the top. Blow and **** on the tubes and listen for a clicking sound and look for the presence of any water in that tube. That switch verifies that the draft fan is on and the mains will not fire if the control board doesn't get the proper sequence of signal......off, sensor open, fan on, sensor closed, verify pilot, fire mains, verify mains all it (sensor at opposite end from pilot). Hope this helps, if not, get back to me with that control board code. Ron
Apr 21, 2009 | Ruud UBHC Air Conditioner
Pool & Spa Logo
109 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
