Question about Elite Kitchen Appliances - Others
My new elite 2.5 popcorn maker is not popping all the kennels tried quite a few times. It leaves about half the kennels in the bottom of the tray
    New Friend:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 109 Answers
Try not to put too many in at a time.
Posted on Dec 15, 2014
May I ask how much popcorn can the Elite Epm 250 Popcorn maker can produce?
The manufacturer rates it as a 2.5 ounce kettle. This means 2.5 ounces of raw kernels each batch.
1 ounce of kernels = 1 quart of popped popcorn.
Roughly a half gallon of popcorn every 3-4 minutes.
May 06, 2013 | Elite Epm250 Popcorn Maker
The unit only pops half of the popcorn
The symptoms of only pops half the popcorn is a hard one to trouble shoot.
1.Check your popcorn, old popcorn dries out. As it loses moisture its ability to pop is reduced. Popcorn only lasts about 90 days after opening the air tight packaging.
2. If it is a oil popper, make sure the stirring rod is turning during the popping cycle. They sometimes can stir, but once the popping starts the pressure of the corn can stall a motor. This results in the first half popping, and the second half burning on the bottom.
3. Popper is too cold. This has symptoms of a long, long popping cycle, and half the corn popping the other half just turning brown. Some machines had adjustable thermostats inclosed, most home units do not. Letting it pre-heat longer does not help, the temperature is controlled by a thermo-stat.
Mar 07, 2013 | Kitchen Appliances - Others
Elite Epm250 Popcorn Maker instructions
Turn on the heater and let heat for 2-3 minutes. The Elite EPM 250 popcorn maker uses a 2.5 oz kettle. This is for 1/3 cup of uncooked kernels. Add kernels with a tablespoon of popcorn oil (available in markets) and a 1/3 teaspoon of what's called "Flavacol". It's a seasoning that they use in movie theaters to add flavor, saltiness and color. It's available online (ebay) or at Smart and Final. Use this combo and you can't go wrong. For cleaning, let kettle cool, the add 1/2 cup water. Turn on kettle and let boil for 2-3 minutes. Then empty it out.
Jan 15, 2012 | Elite Epm250 Popcorn Maker
Ccp-510 popcorn popper pops only small amount and quits
I had the same problem when I firs bought mine. I followed the instructions as to the proportion of corn to oil. Forget the book! I found that with this machine I had to use three times the oil that was caled for in the instructions to get all of the corn to pop. Better yet, we started purchasing the premade kits with the oil, popcorn and salt. Since changing to both of these systems we have enjoyed GREAT ppcorn!
Feb 01, 2009 | Nostalgia Electrics Helman Group CCP-510...
Can't make multiple batches of popcorn
We are under new management.
Please contact us at 1-920-347-9122 and we can help you with your Nostalgia Electrics product.
Also, please visit our new website at www.nostalgiaelectrics.com
We are more than happy to assist you.
Jan 11, 2009 | Nostalgia Electrics CCP-509 Popcorn Maker
Not all kernals are popping
Heat the oil longer before you put the kernals in.
Dec 16, 2008 | Maximatic Elite 8oz. Deluxe Popcorn...
How much oil and popcorn do you need in the popper
single layer of popcorn on bottom of entire maker...no oil is needed but you can use a tablespoon if you like...butter melts through the hokes in lid....Place butter pats over top holes in lid before popping starts if you want butter to drip down on the corn ( it does pop better with a little oil!)
Dec 09, 2008 | West Bend 82306 Stir Crazy® Popcorn...
Popcorn won't pop
Hints for getting the best popped corn: Don't pop popcorn in butter as the butter will burn before it can get hot enough. Popcorn pops best in temperatures of 400-460 degrees F. If your oil starts to smoke which happens at 500 degrees F, you've got it too hot. Any oil will work. Use enough oil to cover the bottom of the pan. For your health, you should choose a light cooking oil or better yet, skip the oil all together and use an air popper. The movie houses use yellow dyed coconut oil which does a great job of popping the popcorn although there are healthier oils you can use than coconut oil. To see if you have the oil hot enough, drop a couple of kernels into the hot oil. If it's hot enough, they should pop in just a few seconds. If you don't have a popper, any thick bottomed, high walled pan will do. Popcorn can even be easily made in a Dutch oven over a camp fire. When your oil is the right temperature, pour in your popcorn, shaking the pan to cover all the seeds in oil. Do this with the lid on to prevent burns should the hot oil try to splash out of the pan. Using a lid helps the kernels to heat more evenly and keeps the popping corn from flying all over the place. (If you are using a popcorn popper, shaking it isn't necessary because of it's rounded bottom.) As it begins popping, it's important to continue to shake a flat-bottomed pan. This helps any un-popped kernels to settle to the bottom of the pan where they can pop. As soon as you hear the popcorn stop popping, pull the pan off the heat and pour the popcorn into another container. It will burn if you leave it in the hot pan.
What can you do if you've done everything right but your popcorn still doesn't pop very well? As mentioned above, popcorn must have about 13.5 to 14% moisture to pop properly. This is because as the popcorn kernel is heated, the moisture inside the seed is turned to steam creating a huge inner pressure. As this pressure continues past the shell's strength to keep it in, the skin ruptures and the inner starchy layer of the kernel greatly expands and turns itself inside out. If the moisture isn't there, this pressure build-up can't happen. If you find your popcorn has excessive old maids (un-popped kernels) in it, the problem might be that it lacks moisture. Place 3 cups of un-popped popcorn into a quart bottle. Add a tablespoon of water, put the lid on and shake it to get water on all the kernels. If the water puddles in the bottom of the bottle, shake it again every 10 minutes until enough of the water has been absorbed to prevent puddling. Now let it sit for two or three days while the moisture is evenly distributed into the kernels. If it still doesn't pop correctly, repeat this process but add no more than 2 teaspoons of water the second time. Yes, it's also possible to get it so moist it won't pop, so definitely, don't add water a third time. Lastly, you can even take your old maids that didn't pop, rejuvenate them with water using the above process and re-pop them. (With a measurement of three cups un-popped popcorn, 1 tablespoon of water will increase the moisture content 2.5%. A teaspoon of water will increase the moisture level almost 1%. Air dried popcorn will probably never get below a 10% moisture content on it's own, so adding even two tablespoons of water would be pushing it, raising the moisture content to 15% - that is if it started out at a moisture level of 10%.)
Nov 06, 2008 | Gold Medal 2131 Antique Gay 90s Pinto Pop...
Incorrect popping
you see,my [popsocrn uis turning into paper.
Apr 20, 2008 | Toastess TCP-6L Popcorn Maker
Kitchen Appliances - Others Logo
105 people viewed this question
Top Elite Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Ruth summersides
Andrew Taylor
Andrew Taylor
Are you an Elite Kitchen Appliances - Other Expert? Answer questions, earn points and help others
