Question about Refrigerators
Can I remove the filter cover completely? Can I remove the entire filter housing (not hooked up to water line). How do I remove the whole bulky thing?
The parts guide shows parts 22, 23, 24, and 26 comprising the filter body. Do these pull apart and pull off?
  • Jack Smach
    Jack Smach Dec 14, 2014
    This question is for KBFS20ECWH - french door, bottom freezer KitchenAid fridge
  • Refrigerators Master
  • 744 Answers
Hello Jack;
My name is Peter. I am a retired field service refrigeration technician.
Do not remove the filter housing, otherwise you are going to have someone like me showing up at your home, and leaving with about $240.00 in my pocket.
I wish you would have posted you model number. Your model number is on a label near the top on the side wall.
Some filter covers are held in with a screw and tabs that you press un and pull out. Others you squeeze to release the plastic tabs.
Get back to me with a model number and I will instruct you.
You only change your water filter, either when the water dispenser is slow or you get small ice cubes. The filter change light is a timer, like a egg timer. It is not electrically tied into the filter.
Also, the next time you purchase a water filter go into the link I am providing. You can get filters for about 40% less.
http://www.filterfast.com/
Posted on Dec 14, 2014
Testimonial: "Thanks Peter. The model is This question is KitchenAid KBFS20ECWH - french door, bottom freezer fridge. What is the reason for removing filter housing?"
  • Jack Smach
    The model is KitchenAid KBFS20ECWH - french door, bottom freezer. What problems will removing the entire filter housing cause (if it's possible to remove it)? The fridge is not/will never be connected to a water line.
Need to replace the water filter tube on my Kitchen Aid KFIS29PBMS01 french door bottom freezer. How do you remove the water filter housing from the inside of the refrigerator to replace the tube?
Ok this is a hard one first take the two screws out near the filter just. That take a screw driver any pry the cover down start close to the ice maker side its held on with clips you will think its going to brake but just slowly pull it that back has hooks so once the front is loose don't yank use a flash litecyou will see three hook molded in the cover pull towards you the will come out disconnect lite harness and there will be a few more screw holding the housing up than you can get the filter out you do have to rotate the housing to remove
Oct 19, 2015 | Refrigerators
Culligan water filter is leaking
Turn off water
Remove filter and seal ring.
Look at mating surfaces.
Usually the cast metal has eroded away.
If it is the sealing ring , replace it. If it is the casting , replace the whole thing. Other brands may be an option.
Jun 24, 2014 | Culligan HF-365 Whole House Water Filter...
Does not remove smell from water
An in line filter will only remove hydrogen sulfide if you use a carbon filter. H2S will vary a great deal during the course of a year. If the carbon filter loads quickly (1 month or less) you may want to consider an iron / hydrogen sulfide filtration system before the water softener. Those that work with air work very well.
RJH2O
Aug 05, 2013 | Culligan 34" Whole House Water Filter...
The water pressure in the entire house is very poor. If more than one water tap is open the water trickles out. The house has a Culligan Water Softner system. Is there a filter or some other home...
First make sure all the filters on all faucets (kitchen, bathrooms and even the dish washer and washer) are clean and not clogged, sometimes on areas with hard water you will experience sand and minerals to accumulate and clogged all filters. If all filter are clean with no minerals, then your problem could be the culligan filter, ask your sales rep to perform an inspection for minerals on all ending lines.
Hope this clear up your water lines. It happened to me.
Aug 09, 2011 | Culligan 34" Whole House Water Filter...
Our automatic ice make isn't filling up completely with water. We are noticing smaller ice cubes.
Good day,
If it has a filter system, then that would be your first step. Replace the filter.
If done already, then either the water valve mounted in the bottom back of the machine is swelling internally and must be replaced, or the water supply from the house is not delivering the water at high enough pressure.
To test the water pressure, shut the house off at the main meter. Remove the house water line from the valve and point it into a bucket while someone else turns the water on for about a 15 second count. It should come out smartly. If not you will need to clean the lines and fittings where it hooks to the house supply or replace them as needed.
Jul 31, 2010 | Kenmore 57029 Side by Side Refrigerator
Leaks at the filter of a frigidare side by side SXS FEFRIGERATO
Assuming this is a side by side, with the water filter located at the top back of fresh food side, assuming filter is unclogged, i.e., new, check the housing that the filter slips into, that which you actually grasp and turn to remove the filter. If there are any cracks in this filter housing, you will need to replace it. If the cover is sound, the problem will lie within the housing assembly, that which you screw the filter cover into. This housing is held on with 2 or 3 screws. IN order to remove the water lines, you must squeeze the white collar towards the housing, away from the water line, while at the same time gently tugging the water line. If you squeeze the collar correctly, the line should come right out. Make sure to connect ONE line at a time. Do not disconnect both and reattach at the same time. If the lines are reversed, you will damage the filter and possibly water system itself. attach water filter and check again. if filter cover is ok, and this does not fix your problem, without personal inspection, i cant help you further. You can reply here or send me a question from my website: www.FixMyFridge.net
Mar 15, 2010 | Refrigerators
Can u hook up ps3 to a laptop catching from my
To be fair, the whole thing is very easy to hook up, and the range is good ... able to cover the entire house, upstairs, down stairs and even outside. ... now I can hook the output from my computer speakers to the docking ... Other popular topics, Netbooks, Palm Pre, PlayStation 3, Security software, Wii, Windows 7 ...
Nov 05, 2009 | Sony Playstation 3 (PS3) Console
Water leak at rear of filter at hose connections. will old filter cause this to clog and force water out of the connection fittings at the clear plastic water lines
it sounds like the filter housing could have a crack in it, but It could potentially be a leaking line. In the event the old filter where clogged to the extreme, you'd simply have little or no water flow, not enough pressure to cause a leak though. I've seen these housings damaged by customers forcing the filters in or out in ways never intended.
To check the lines are secure/not leaking...
**FIRST unplug the unit from the wall and turn off the water supply**
either go thru the front by removing the toe panel/kick plate grill, or go thru the back panel, you'll still need to remove the grill at the front though. the 2 screws securing the filter housing to the fridge are at the front behind that grill. (if your lines are long enough -they usually aren't- you can undo the screws and pull the housing out to work on it easier/unimpeded). remove the 2 lines to the filter housing carefully(when removing these you simply push the tab surrounding the line "in" or "down" and pull out the line) and inspect them at the ends where the "seat" in the fitting/"O" ring within the housing. with a razor blade or sharp utility knife, cut off a small amount to insure a clean fitting when re-installing the lines into the housing (simply push them in the way they came out, until they bottom out and you can't pull them back out). once that's done you can turn the water back on, plug the unit in, and check for leaks. Is it actually the lines, or the housing itself ?
I've seen this a few times. the complete housing can be replaced and it isn't that difficult. First verify it is leaking behind the filter at the housing, I could try and help further. the housing is # 2186443 if you need it.
hope that helps,
good luck
Sep 28, 2009 | KitchenAid (KSRD22FKST) Side by Side...
WATER DISPENSER NOT WORKING
It might be that you have a restriction at the water supply line serving the fridge. Check it for good flow (have bucket and towels handy!) If supply line is good, then move onto the fridge to check the water inlet valve(s). as newer models have 2 or 3 inlet valves, a main water valve for the entire unit, and possibly one each for the ice maker and water dispenser past the main inlet valve (solinoid).
You can check these by simply shutting off the main supply to the fridge from the house water line 1st, and then removing each water line from the supply side of the fridge and seeing if you have water flow from the house to the valve side. If you do, then reconnect the lines to the fridge valves and see if you can get water flowing to the other side of the solinoid/valve when you have someone try to get a glass of water from the water dispenser, etc.
It is possible that there is an obstruction in the lines, by not very likely. Normally it is a failed water valve(s) (solinoid) that causes low flow or complete loss of flow, especially if you've changed the fridge water filter or replaced it with the "cap" which eliminates filtering of the water.
It is that you'll likely have to replace at least one, maybe more, of the fridge inlet water valves. If you have the time, try to zero in on the failed one by bypassing each, one at a time, until you get water flow. That way, you'll only have to purchase just the replacement valve needed to get things working again.
Jul 07, 2009 | GE GSH25JFR Side by Side Refrigerator
Refrigerators Logo
46 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
