Question about Cell Phones
There is no SD card in my phone....But can that be the problem
    New Friend:
  • 36 Answers
You only need SD card for storing extra data or for external storage. If your phone's internal memory has good capacity, you do not need an SD card for storing extra data.
However SD cards can be used for storing your important files externally. So if your phone doesn't support SD card, please keep a backup of your files elsewhere.
Posted on Dec 16, 2014
    Sergeant:
    Champion:
  • Cell Phones Expert
  • 318 Answers
A sd card is only needed for extra storage. A phone does not need it . Ypu did not state the problem ypu are having but lack of the sd most likejy is not a candidate.
Posted on Dec 14, 2014
How to get my pictures and videos off my Android phones SD CARD to my nextbook flexx10 by putting the SD card into the laptop
The Flexx10 has a micro SD slot, the SD card is about the size of your finger nail. If your Android phone also has a micro SD card you just remove it from the phone and plug it into the Flexx10. Then just transfer the pictures from the SD card to the tablets internal hard drive. When complete put the SD card back in the phone. If the SD card in your phone is the standard size it obviously won't fit the Flexx10. You then have the choice of either using Bluetooth to transfer the pictures between devices or buying a USB SD Card converter and plugging that in your FLexx10 with the Android SD card mounted in the converter.
Feb 06, 2016 | Nextbook Tablets & eReaders
Files on SD card not appearing?
try to unmount your SD card from device storage settings from your phone and re mount it. Also make sure you are seating the SD card correctly, it could be that the SD card reader on the phone is damaged. However you can check this by inserting a different SD card and if that doesnt work. Its likely the SD card reader that has the problem.
Oct 15, 2015 | Android Apps
Memory full, install new SD card, how move files to new SD card?
One of these ought to work:
  1. Remove SD card, connect to PC using a card reader (and adapter if needed), copy files to PC. Connect a larger capacity SD card to PC, copy files from PC to new, larger SD card, install new SD card in phone.
  2. Connect phone to PC with USB cable, then do same process as above.
  3. Back up phone to Google, Samsung, or other cloud resource. Replace SD card with larger one. Restore phone from cloud.
Mar 02, 2015 | Samsung Cell Phones
My phone keeps telling me that my SD card has been removed but it hasn't been. I've tried taking it out and putting it back in but it keeps telling me the same thing
maybe because your phone don't recognize your SD card anymore. try to put your SD card to other phone and try if the other phone recognize your SD card, if the other phone don't recognize your SD card, the problem is in your SD card. you should buy a new SD card if that's the case. Also try to put a different SD card on your phone and you'll see your phone will recognize the different SD card.
Kindly rate this post. Thank you for your question and I hope I help you a lot.
Jan 20, 2012 | HTC Cell Phones
I cant save files direct to sd memory all data is going to phone memory direct..how to activate sd memory as my default memory in E5 nokia mobile?
1. To save files received from bluetooth on sd card: Open messaging. Go to settings. Scroll to the end and select other settings. Change the default memory to Memory card. It will ask to copy or move the messages and file from phone memory to sd card. Select move to memory card.
Now all files will go to sd memory card.
2. To save all applications to sd card, open ovi store, go to settings, change installation preference from phone memory to sd card
Jun 07, 2011 | Nokia E5 Cell Phone
LG Ally Android phone says it's checking the SD card for errors. Can't access SD card.
you can try plugging the SD card into your computer with an SD card adapter and see if you can access your files.
You may have to format your SD card if you cannot access your files this way. from the phone go to settings, SD Card - phone storage (some phones its labeled different) From there you can format your SD card, depending on your phone you may have to choose Unmount SD card first.
If you continue to receive errors or are unable to format the card, it is most likely that the SD card is bad and needs to be replaced.
Mar 21, 2011 | LG Ally Cell Phone
Hi, my g1 has problem to read the sd card, when i try to use the camera, the phone says it does´nt have, and windows XP do recognize the phone
Need a little clarity on what your saying XP does recognize the SD card when you mount the phone to the computer, or it doesn't?
Well here is what you can try. and just remember ALWAYS ALWAYS ALWAYS do this before removing your SD card from your phone.
Settings>SD card & phone storage>Unmount SD card
Now if your phone has "Unmount SD card" blacked out then don't worry about just go ahead and remove the SD card.
Take the card and put it in a card reader and put it in your computer. Go to: Start>My computer> (and the drive corresponding to the SD card.) and then try to open it. If a window comes up saying something like drive E: is not formatted, Format now? and then Ok or cancel well if this comes up it could be one of three reasons; the SD card is not properly formatted, SD card is damaged, or the SD card reader is not working properly. So before trying to format the SD card try another card reader or try it on a different computer. If that doesn't work try to format the SD card. If formatting the SD card doesn't work, you may need to buy another one. If you do decide to get another one check Amazon.com they have good prices for the SD cards however if you prefer local buying best place to go (that I've found) is Radio Shack. They always have sales on the MicroSD cards. One other thing. For some reason. SanDisk Micro Sd cards seem to work the best for the G1. The transend cards are utter **** and worthless. Avoid buying them anytime your in the market for a new SD card or USB flash drive.
If you need further help feel free to check out xda-developers.com
Aug 07, 2010 | HTC G1 Smartphone
Hi..how do I transfer phone contacts to sd card?
hey you cannot transfer contact in sd card, unlike the picture images etc. but phone contacts you cannot,
Nov 15, 2009 | Samsung SCH-i760 Smartphone
How can you import pictures in inbox on cell phone to the microchip SD 2gb inserted in phone?
Micro SD cards for cell phones are now costing less and are holding more memory. 4GB SD cards can hold an estimated 1000 songs, over 13,000 images, or 22 hours of video individually. 2GB memory cards hold roughly half those estimates and 8GB SD cards would hold double. So if your cell phonemag-glass_10x10.gif has a SD card slot learn how to utilize this expandable memory option on your device. Follow these steps and you will soon be enjoying your music, pictures, and video on your phone!
  1. Insert your SD memory card adaptor (with micro SD card inserted) into your SD Card drive on your computer. This should open a "Secure Digital Storage Device" or similar window. If not, go to "My Computer" to locate your SD card and open it.
  2. Step 2 To transfer picture files to your SD memory card, open the folder or file that your pictures are stored on. Simply click and drag a file or multiple files and drop them into your SD Card window or folder. You can also copy a picture and then paste it to the SD Card.
  3. Step 3 To transfer music files to your SD memory card, open your "My Music" folder. Select the folder where you are going to get the music from (Itunes, Yahoo Music...). Click, drag, and drop the files into the SD Card window or copy and paste them in.
  4. Step 4 To transfer video files to your SD memory card, open your "My Videos" folder. Select the folder where you are going to get the video from. Click, drag, and drop the files into the SD Card window or copy and paste them in.
  5. Step 5 Take out the SD memory card adaptor from its drive. Remove the Micro SD card (small chip for your phone) and insert it into the SD Card drive on your Blackberry, IPhone, or other compatible cell phone.
  6. Step 6 Go to your media, picture, or music folder in your cell phonesmag-glass_10x10.gif menu. Select which item you are looking for and your files will appear!
Nov 14, 2009 | Cell Phones
I cannot remove my sd card from my lg dare. How do I access my sd card
To insert the SD Card you had to push it in the SD Card slot until it stayed in the phone. To remove the SD Card simply push the SD Card into the phone and it will eject itself. I think it is spring loaded or something. It's almost impossible to remove the SD Card by pulling on it.
Mar 14, 2009 | LG RUMOR Cellular Phone
Cell Phones Logo
44 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
