Question about RCA Car Audio & Video
Where do the rca wires from amp plug into headunit
    Top Expert:
  • RCA Master
  • 41,738 Answers
If the head unit has RCA output connectors, the amp plugs into them.
Posted on Dec 14, 2014
I have the pionner deh p7300 i want to hook up a ipod i have a sub woofer and amp. on the back of the headunit i have rca plugs for the amp in the rca plug on back of unit. the there are 2 other sets of...
Buy a rca to aux 3mm plug then you can connect to aux port.
RCA out is for the signal to the amp from the Head Unit. Mic is probably for your cell phone.
Am pretty surprise that an HU like that doesn't have USB Ipod support?
Feb 06, 2011 | Pioneer DEH-P7300 CD Player
I have a metra turbowire 70-1857 wiring harness, and i am lost at connecting it to my pioneer aftermarket DEH-1100MP. I have the harness hooked up to the amp in the trunk. and strung through car and in the...
well head units usually dont have just rca inputs....but the outputs can be changed to rca style with adapters. the speaker level outputs are what you need to change....good luck
Apr 25, 2010 | Metra Turbowire 70-1857
How to hook up a kenwood amp.kac-5204
All amps are basicly the same. It should be plain as day where the speakers connect to.
The 12V screw connects to the main power from battery, be sure to fuse that wire and use a proper size wire, thicker is better,I suggest at least 8gauge with 40amp fuse. The GND is ground and should connect to car metal, file paint for soild connection. The REM is remote and connects to the remote of headunit or if you have a stock deck to the acc of car found in wire harness of headunit. Plug in the RCA's to head unit, or get a converter to plug into speaker wires from car if you have a stock headunit.
Mar 22, 2010 | Kenwood KAC-5204 350 Watt Max Power Stereo...
Amp comes on but no sound to the subs and i think i checed all wires and even got new rcas
Hi mate
I know loads of ppl who have had the same problem.
Are you getting an output from ur headunit RCA's? Sometimes you need to turn the sub RCA's on via ur headunit. I would make sure im getting an output from the headunit first.
Oct 24, 2009 | Car Audio & Video
Which wire is my amp power wire on a kenwood kdc-x617
hey mate,
You will need to run independent power and ground wires for the amp, then run your RCA leads from your headunit to your amp, the trigger wire to turn your amp on and off with the headunit is the pink and black wire in the kenwood wiring harness...
Hope this helps
Brad:)
Sep 22, 2009 | Kenwood KDC-X617 CD Player
Amp will not come on ,no light
Yes!!!!!!!!!! Your remote wire is what tells your amplifier to turn on and off it won't work without it. Assuming your stereo headunit is an after market unit it has the correct wire for this. what you have to do is pull out you headunit, and in the back of the headunit where all the wires plug into your unit there is blue wire with a white stripe. this is the remote turn on wire. connect a wire to that blue n white wire and run it back to your amp, insert it into to the spot marked remote. turn your head unit on and your amp will power up... if you have all the rca cables hooked up your amp should be ready to go.... btw good choice on the amp, kenwood is the way to go!
Aug 31, 2009 | Kenwood KAC-9152D Car Audio Amplifier
Stuck in ''Protect'' mode Phoenix Gold Ryval v8001monoblock
OK try this little trick i have to resort to on Saturday afternoons when the shop is about to close and i have a date who works in the adult entertainment industry.... AAhheeemmm..
1. Does your amp have a high input port? This is where instead of RCA's you feed it speaker output from your head unit?
2 If so try this and see if the magic happens.. If it doesn't your screwed and the problem is internal most likely in the input stage and that's why your having to "fool" the amp.
3. Also take off the remote turn on wire and make a short little jumper from the remote turn on to the B+ on the amp. Yeah the amp will blaze on but see if it changes the output. I know it sounds crazy but after 26 years working with this stuff i know where the gremlins hang out... Especially Rockford .
godd luck. let me know
Mar 18, 2009 | Car Audio & Video
Amp works but no sound from sub
Some older Pioneer radios require you to connect the Subwoofer RCA to the rear output on the back of the radio and then you have to turn on the subwoofer in the menu on the radio. What model Pioneer radio is it? Also, make sure that the RCA plugged into the amp is on the input side, not the output side.
Jul 29, 2008 | Sony XM-2002GTR Car Audio Amplifier
Connecting a amp
It has a remote output if it also has RCA pre-outputs. The remote output wire is blue with a white stripe.
Sep 24, 2006 | Pioneer DEH-1630R CD Player
Car Audio & Video Logo
Top RCA Car Audio & Video Experts
Colin Stickland
Colin Stickland
Jeffrey Turcotte
Jeffrey Turcotte
 Mikey
Mikey
Are you a RCA Car Audio and Video Expert? Answer questions, earn points and help others
