Question about Tricity Bendix Dryers
I am wanting to replace belt on Tricity Bendix reverse action Condenser Dryer. I have removed all screws from around back of dryer but it still does not want to come off. do i need to remove "C" clip
Tricity Bendix Reverse Action Condenser Dryer. Using 125828800 Polyv 1975 H belt
    Top Expert:
  • Tricity Bendix Master
  • 34,796 Answers
The dryer may open from the front.
Posted on Dec 14, 2014
Tricity bendix tm 550 motor spring adjustment
If there is no provision for adjustment, the spring may have lost its tension and will have to be replaced.
Nov 18, 2016 | Tricity Bendix Dryers
How do I replace a belt on a tricity bendix TM221W tumble dryer - a video of this would help. thanks.
no video
unplug it
you have to take the top and back panel off
take photos of how the belt is fitted before removal
see what holds the belt on or stops it from coming off
undo what is required and fit the new belt
then reverse all the take apart steps till it is fitted
Tricity Bendix TM221W 91609308601 Tumble Dryer Functional parts Spare...
Dec 26, 2014 | Tricity Bendix Dryers
How to fit belt on a tricity bendix tm310w tumble dryer
round the pulley then around the tensioner then around the drum.
Jun 08, 2014 | Tricity Bendix TM310W Electric Dryer
Replace a belt on a Tricity Bendix TM 320 W Tumble Dryer
1. remove top plastic panel (retaining screws are at back)
2. locate metal brace (12 incles long and 1/2 inch wide) on top of the cabinet (in mine it is on right edge)
3. unscrew retaining small bolts (there is one a few inches below on the inside of the cabinet too).
4. Repeat for left side.
5. push the back and front halves of the cabinet away from each other
6. slide the new belt around the front of the drum
7. reassemble
8. if you need to tension the belt wrap 10-20 turns of insulation tape around the idler pulley
Jan 30, 2010 | Tricity Bendix TM310W Electric Dryer
Tricity Bendix Condensor Dryer
the belt needs to go over motor rod first this means you have to take cover off then release the spring that attached to the motor so there is some play with the belt ,then pull the belt around the drum,quiet tight but you can do it,then pull the motor spring back into position to tigthten the belt put back together.... job done
Jan 19, 2009 | Tricity Bendix TM310W Electric Dryer
Tricity Bendix WDR1240W Condenser dryer problem
Check the fan that is supposed to blow the hot air into the drum. It may be seized or jammed. It should be situated on the top of the outer drum. You will need to remove the top cover from the machine and identify the blower fan.
Nov 01, 2007 | Tricity Bendix WDR1240W Front Load Washer...
Dryers Logo
115 people viewed this question
Top Tricity Bendix Dryers Experts
Tim Whalen
TO Lady
Are you a Tricity Bendix Dryer Expert? Answer questions, earn points and help others
