Question about Refrigerators
Freezer works fine, refrigerator not cooling model LTF2112ARB
Nothing yet
  • Refrigerators Master
  • 744 Answers
Hello Gerard;
My name is Peter. I am a retired field service refrigeration technician.
You have a old unit, some parts are not available. Lets try to fix this anyway.
1.) You only have one source of cooling in you unit and that is your freezer. You are not getting any cooling air. If you reach in your fresh food section, in the top back is your air vent from the freezer.
Do you feel any air flow? No.
2.) Freezer Vents - In the bottom back of your freezer are either one or two vents that go down to your fresh food section. They may be covered with Styrofoam covers that easily pull off. Feel around the covers before removing. The vents may be plugged up with frost and ice. If this is the case, use a hair dryer to break the vent covers free. Once the covers are off, put towels in the back of the fresh food section to collect water. Either use a hair dryer or warm water to clear the vent.
3.) If you have a Belt: Ok the freezer vents were not blocked. You are going to have to remove the control panel cover in your fresh food section.
There is a belt that goes from your control nob to the air damper in the back of the control cover. This belt is not longer available. The belt opens and closes the air damper. If the belt is broken you may want to take a wide piece of rubber ban and join the belt back together with a stapler. Make sure the staples are flat. Better yet, try to make a new belt out of a bicycle tube.
Remove the control panel:
1.) Unplug the refrigerator or turn power off at the breaker.
2.) There are two screws on the side front of the control panel. One screw on each side. Pull the control panel toward you, it should drop down.
4.) Ok, the belt is good. The only thing left is the control assembly. With the refrigerator unplugged, remove the control assembly. Disconnect the two wire connectors and replace.
Freezer works fine, refrigerator not cooling model - 25321666-mf1tdhkbs55tpszhgwrg1fbb-4-0.jpg
PART NUMBER: 63001358 - Cost: $78.00
Posted on Dec 14, 2014
SOURCE: maytag refrigerator side-by-side model MSD2756GE
remove the baskets and shelves in the freezer and remove the rear panels after shutting the fridge down. If you see heavy frost on the coils then the defrost model needs replaced. If not, check the that the fans runs, and then that the thermostat works and then that the damper that allows the air to the fridge compartment is opening correctly.
Posted on Sep 05, 2008
  • 51 Answers
SOURCE: norcold rv refrigerator freezer
Make sure the thermister is attached firmly to the fins in the back. The boards on a Norcold can be reset a service center familiar with this process is your best bet. It takes disconecting the board and then shorting it out best to leave it to some one who is familiar.
Posted on Sep 08, 2008
Techsim
  • 59 Answers
SOURCE: Amana BX22A2W - freezer works, fridge not cooling
Check the damper in the top back of the fresh food section. make sure that it is open and air is coming through it.
Posted on Nov 02, 2008
tech master
  • 120 Answers
SOURCE: frigidaire frs26zrf
IS THE EVAPORATOR FAN INSIDE FREZZER WORKING AT ALL IF IS NOT WORKING THEN THERE IS NO AIR FLOW TO THE BOTTOM PART
Posted on Nov 10, 2008
heatman101
  • 43501 Answers
SOURCE: freezer works refrigerator does not
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Posted on May 24, 2010
Just stopped cooling refrigerator and freezer model number 79571092111
Impossible for all fans to be working, compressor ok, freon levels fine, and no cooling. Of course, if your compressor is no longer compressing, then that would account for your problem - you could also confirm this by checking current draw. With the compressor doing nothing but spinning current draw should be next to nothing.
If ice in back of freezer self defrost mechanism is not working.
Mar 28, 2016 | Kenmore Refrigerators
We have a Admiral Top Freezer Refrigerator Model#
sounds like a defrost problem. if the freezer section gets too much frost build up then it wont be able to move air into the refr section. check to see if you have "heavy" frost in the freezer and if so then a defrost thermostat or a defrost control board may be you problem.
Nov 02, 2013 | Admiral Refrigerators
Freezer working but refrigerator is not cooling
if freezer is close to zero, top to bottom, and fridge is warm(ing), then you likely have a defrost problem, you will notice an abundance of snow/frost on back wall of freezer. it could either be your heater, thermistor, defrost safety thermostat, or your defrost control/main cpu, depending on model. if either or both sides are warm at the top, and cold at bottom, then your freezer fan is out. again depending on your model, it may just be the fan, or a combination fan/main cpu board hope this helps
Feb 15, 2010 | GE Profile PSW26P Stainless Steel Side by...
Freezer and fridge not cool enough
Check if the syrofoam pieces block air inlet. If so then this may be the problem.
May 08, 2017 | Admiral Refrigerators
Amana freezer on bottom working fine, but refrigerator not
heatman101
Sep 25, 2009 | Amana ABB1927DE Bottom Freezer...
Refrigerators Logo
56 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
