Question about Refrigerators
My fridgidaire refrigerator has the error code "oF" it doesn't seem like its running but it is displaying this code. Please help!!!!
  • Refrigerators Master
  • 744 Answers
Hello Owen;
My name is Peter. I am a retired field service refrigeration technician.
Your unit may have fallen into the "Cooling Off Mode", and needs to be reprogramed.
Send me your model number. Your model number is in your fresh food section, on a label, on the side wall, near the top.
Posted on Dec 14, 2014
3 Suggested Answers
SOURCE: PHS39EHSS Fridgidaire refrigerator leaking.
Ice makers making grinding noise. This happens every month. What we do is unplug the fridge remove all the food in the freezer then use a blow dryer to thaw the ice build up (fan?)This is very annoying and I would like to find a permament solution. Ibought Frigidaire Professional because I thought I was getting a quality product. I guess I was wrong. Any help I can get would be appreciated.
Posted on Jul 27, 2009
Sea Breeze
  • 4654 Answers
SOURCE: fridgidaire refrigerator flashing error code 4
From what I remember a flashing 4 means "damper error". Send your model number found inside or on the outside of the fresh food section, The air damper is found between the freezer and fresh food section and regulates temperature in the fresh food section by opening wide for things that warm up your fresh food section example would be opening the door and letting warm air inside . The damper then closes to keep the right temperature. If you have questions please ask, Thanks Sea Breeze
Posted on Sep 07, 2012
Fridgidaire F93 error code and beeps as soon as we try to use oven. Beeping stops with cancel but stove doesn't work, last 2 days.
Computer operated and monitored devices don't like safety features being disconnected.
I did find this though.
Based off the information you have provided your Frigidaire oven is displaying the error code F93. An F93 error code means that you have reached maximum oven door unlock time exceeded. This could be a potential issue with your EOC (Electronic Oven Control), lock motor, or light switch. I would recommend resetting your range and you can do that by disconnecting power from your appliance for ten minutes. Once you reset power to your range, if you continue to experience an issue I would recommend consulting with a technician. They would need to check each component to assure that the proper amount of power is being provided to each part. I hope this information is helpful.
Also this information generally.
Fridgidaire F93 error code Google Search
Dec 08, 2016 | Kitchen Ranges
Freezer temp is ok ref.temp too hot. fan doesn't seem to be operating
That model is twin cooling. Are you having any error codes on the display? Most models will shut off the fan when you open the door. If there are no error codes the thermistor could be out of range telling the fan not to run. You could try putting the refrigerator into diagnostic mode. You can look that up or reply I could tell you how to do it.
Mar 24, 2016 | Samsung RF217ACRS Bottom Freezer French...
Kenmore elite bottom freezer refridegerator error code er rf
you could call a repairman but if it is fairly old then buy a new smaller refrigerator the smaller simple ones seem to last longer in the long run .
Jul 17, 2015 | Kenmore Refrigerators
The code ER CO keeps coming on, on the display panel. The fridge and freezer still work but the code keeps coming up. Any info on that?
LG Bottom Freezer Refrigerator Error Codes Sears PartsDirect
Select
Use our model number finder
Choose your product type
Common model number plates
Close
LG Refrigerator Error Codes
These error code explanations can help you diagnose a problem with your LG bottom-freezer refrigerator. For repair how-to help, visit the PartsDirect repair help section, which includes repair help for washing machines, other major appliances, lawn and garden equipment, garage door openers, vacuum cleaners and more. You can also search for owner's manuals, get advice from an expert and find refrigerator replacement parts. Error Code
Er FS Error Code
Er rS Error Code
F dS Error Code
r dS Error Code
Er HS Error Code
Er IS Error Code
Er SS Error Code
Er rt Error Code
Er It Error Code
Er gF Error Code Error Code
r dH Error Code
Er IF Error Code
Er FF Error Code
Er CF Condition
Condenser fan motor is defective Check/Repair
Condenser fan motor, wiring or the control board Shop Parts
Condenser fan motor, Power control board, Wiring harness Error Code
Er CO Condition
Communication error Check/Repair
Communication error between main board and display board Shop Parts
Display control board, Power control board, Wiring harness
Jul 16, 2015 | LG LFX25974ST 24.7 cu. ft. French Door...
Fridgidaire refrigerator flashing error code 4
Sep 07, 2012 | Frigidaire Refrigerators
Our power went out due to the snow storm, and the display panel shows 88 on each side...how do I reset this...will this cause the fridge temp to go up?
From http://www.samsung.com/us/support/supportMain.do
Your refrigerator is equipped with an onboard diagnostic system. If the diagnostic system detects a fault, it will display a specific line segment on you refrigerators LED display. If your refrigerator is displaying an error code, please note the error code, and reset the refrigerator by unplugging the refrigerator for 30 seconds. When the refrigerator is plugged in, it performs a self diagnostic check of the various sensors and functions. If the error code reappears your refrigerator will require service. Please click the "Create Online Service Request" button below this article to initiate the service process. After a power outage the display panel may start blinking "88 88." If you unplug the unit for 30 seconds then plug it back in the display will return to normal operation after several hours. The power outage/surge can cause a communication error between the circuit boards in the unit. It can take several hours for these boards to stabilize.
If the display does not reset, go to the Samsung Support link above, enter your model number, and follow the prompts to request a service ticket.
Good luck, and if this helps, please rate my answer!
Feb 02, 2011 | Samsung Refrigerators
Kenmore Elite Refrigerator Trio display panel read ER IF and everything seems to be melting or thawing. Not making ice and water is running from door where the ice seems to be melting? HELP! My freezer...
This is an error code for the icemaker fan motor.
If the control does not see a signal coming back from the fan motor you will get this error code.
Please see the image below from the service manual that explains the ER IF error code.
http://media.fotki.com/1_p,wkbwtkdqbqkgrkkxgtqsskgwtqkq,vi/ktfgsrbbdxktrrwffdr/1/1303472/5961857/image18067img-or.jpg
The ER IF code indicates a failure of the icing fan.
You may notice slower ice production but the other fans should be okay.
You can select the ultra ice option and see if the fan toggles on.
The fan or the control is bad.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jun 08, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Fridgidaire frs26zsh side by side ice buildup in bottom freezer
if you have icemaker install check there or you have a clogged in your drain cut ashort piece of naked wire wrap it on the heater coil and puch wire down in drain not a long piece please unplug refrigerator
Mar 30, 2009 | Frigidaire FRS26R4A Side by Side...
I have an LG LRSC26923TT Refrigerator. The display shows "Er" in the freezer temp area and "FF" in the refrigerator temp area. Nothing happens when I press any of the buttons. However, the refrigerator...
ER FF is a freezer fan error. Basically the mainboard is not receiving a feedback signal from the freezer fan motor within 65 seconds. When this happens the error code will come up and then none of the buttons will work.
You can clear out the error code by unplugging and plugging the machine back in. The error code will come back if the problem persists. Check around the freezer fan motor fan blades to see if ice buildup is interfering with the operation. Clearing out this ice may fix the issue.
If the problem comes back, then the fan motor may be getting ready to go out or the unit may not be defrosting properly.
Hope this helps, please rate my solution.
Jan 09, 2009 | LG LRSC-26922 Side by Side Refrigerator
Refrigerators Logo
48 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
