Beldray 5 in 1 steam mop, red light still flashing after 30 minutes plugged in and steam won't come out?
Plugging it in for first time
SOURCE: I have a Philips 50
I have the exact same problem! I have it hooked up to a power strip now to unplug it by flicking of the power strip and waiting for the red light to go out then I turn it back on while Channeling up 10 X's and then down and up until it comes on. I listen to the sound of the switch which it comes on. I turn it off if it is faint and then back on and channel up. Crazy process but it's been working. It takes about 10 minutes everytime to get the TV on until I get a tech to come out and look at it. The capacitor keeps a charge which is why the light is flashing with a code for 60 seconds./JJ
Posted on Dec 08, 2009
heatman101
  • 43501 Answers
SOURCE: I HAVE THE SHARK STEAM MOP S3101 AND ITWONT STEAM.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
The heating element may have died or there is an obstruction...
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it may not be getting steam to the head...
Euro-Pro Shark Steam Mop Problem
heatman101
Posted on Sep 04, 2010
heatman101
  • 43501 Answers
SOURCE: It doesn't steam up anymore.
Hi,,
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it maynot be getting steam to the head...
Here also is a link to get any of the Shark Manuals that you need.
heatman101
Posted on Sep 24, 2010
heatman101
  • 43501 Answers
SOURCE: My Shark Steam Mop quit steaming & light went
heatman101
s
Posted on Sep 25, 2010
SD Tech
  • 14553 Answers
SOURCE: sony kds-60a2000 power light flashes 5 times, no picture
5 flashes - Lamp Driver - (lamp driver faulty)
This is the error code that usually means the ballast (it is the power supply for the lamp) is bad.
SD TECH
Posted on Apr 20, 2012
I have got beldray. Steam mop not a vauuum I put water in switch it on red lights come on then go blue I will turn on steam and it will just not steam.
Lord Blake there sounds like there is a problem with the trigger or the seals for the steam pipe. Check it over completely and make sure it's assembled right.
Nov 02, 2014 | Vacuums
Why does my Beldray steam mop leave floors so wet
It probably has mineral deposits inside from the water. This build up of mineral deposits prevents the water from heating up to a high enough temperature. So instead of hot steam, you get hot water.
Jun 03, 2014 | Beldray Handheld Steam Cleaner, 1000 Watt,...
Red devil steam mop no steam coming out
Add CLR to water tank. Let it sit for an hr to overnight unplugged. Plug back in, turn on steam to medium setting and wait about 20 minutes. Mine started to steam and I let it steam for 5 min or so. Empty out CLR, add only "DISTILLED WATER" and clean away. Good luck.
Oct 24, 2013 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Require instructions/manual for Beldray 2 in one steam mop
I WAS AFTER THE WEB SITE FOR BELDRAY AS I NEED MOP CLOTHS BUT CAN NOT FIND THEM SOLD ANYWHERE . I COULD NOT EVEN GET THE 2 IN ONE TO WORK BUT FINALLY DID BY REMOUVING THE PIPE WITHIN THE WATER BOTTLE WITH THE BALL VALVE ON THE END AND THEN IT WORKS A TREAT WHEN USED AS A FLOOR MOP AT LEAST . I MAY HAVE TO REFIT THE PIPE AND BALL VALVE WHEN I NEED TO USE IT AS A HAND DEVICE I HAVE THE MANUAL THAT CAME WITH THE 2 IN ONE BUT THAT'S NOT A TECHNICAL MANUAL IF THAT IS ANY HELP
Apr 10, 2012 | Vacuums
I was using my shark steam pocket mop without any trouble for about 5 minutes & all of a sudden it stopped steaming. i tried unplugging it & starting over but when i did this the water chamber...
heatman101
[]0-0-
Jun 17, 2011 | Euro-Pro Shark Steam Mop - Gray/ Purple...
My h2o mop will not allow any water flow the red light comes on after afrw minutes the green light comes on but there is no water or steam flowing out what can i do
Try running a solution of 1 part white vinegar to 2 parts water,turn on & let run through if this dosn't work take the mop head off ( unplugged of course) & poke a needle or paper clip through the hole replace head & try vinegar solution agian. It worked for mine you need to clean out lime scale.
Apr 13, 2011 | H2o TR220002 Steam Cleaner
I have a Bionaire Steam Mop, Model SM-02. The water appears to be heating up, but no steam comes out. It was purchased at Macy's last spring for limited use in a summer cottage. So, it's less than...
Solition: 1 tbsp of vinegar in the 1 cup of water added to mop reservoir
I purchased my Bionaire steam mop in Nov. 2010 but did not try it out until just recently (Mar. 2011) - and had the exact same problem as you... green light on, base feels warm, sounds like it's working, but no steam coming out.
I called Bionaire customer service and the lady there told me to try adding 1 tablespoon of vinegar to the 1 cup of water that you put in the mop. Then she said to leave the mop plugged-in (but not switched on) for about 30 minutes; so the green light is on; then to turn the switch to "on". I did this and, when I switched it on, it still did not produce steam. In frustration, I unplugged it and left the mop (with the water/vinegar mixture still in it) sitting upright for two days. After the two days, I was just about to empty the mixture out of the mop and thought I would try it one more time... and IT WORKED!!!
I hope this solution works for you, too!
Nov 02, 2010 | Kitchen Ranges
Mop is not heating/steaming. It was fine one minute but when plugged back in 30 minutes later it won't steam. Light is on and canister is warm.
heatman101
;s
Aug 03, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Heating & Cooling Logo
78 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
