How do i set time and alarm on a lloytron projection alarm clock?
Pressing random buttons, and can only move minutes no. up
Need instructions for Discovery Kids Projection Daisy Bloom Alarm Clock
1.set time: hold down "clock" button for five seconds, then use up and down arrows to change, and press "clock" button once to toggle between month/day/year/hour/minute. Try it a few times b/c sometimes it just goes to the alarm setting (i don't know why, i think it's a glitch).
2.set alarm: hold down "alarm" button for 5 seconds, use up and down arrows to change, press "alarm" button once to toggle between hour/minute. press "clock" button to return to clock
3.turn on/off alarm: press "alarm" button once, press up to turn alarm on and press up again to turn alarm off. press "clock" button to return to clock
4.to project the images: push the buttons that look like video cameras. to focus the image, rotate the cylinder around the lens that projects the image. on the daisy clock, there's a button on top that you can use to flip the projected image of the time upside down. use the dial next to the lens-cylinders to select a different image (you may need to point the cylinders in a different direction to reach the dial)
Aug 19, 2013 | Bon-Ton Kids Discovery Kids Projection...
I need discovery kids tm daisy clock manual
1) set time: hold down "time set" button for five seconds, then use up and down arrows to change, and press "time set" button once to toggle between month/day/year/hour/minute. If it goes to the alarm setting instead of time setting, try again.
2) set alarm: hold down "alarm set" button for 5 seconds, use up and down arrows to change, press "alarm set" button once to toggle between hour/minute. press "time set" button to return to clock
3) turn on/off alarm: press "alarm set" button once, press "up" to turn alarm on and press "up" again to turn alarm off. press "time set" button to return to clock
4) to project the images: push the buttons that read "time" or "image". to focus the image, rotate the cylinder around the lens that projects the image. use the dial near the lens-cylinders to select a different image
5) military time: press the "up" button when the time is displayed (not when you're setting the time)
Good Luck!
Jun 22, 2013 | Toys
How do I reset alarm?
1. Press the Alarm Set button to display the current alarm.
2. Hold down the Alarm Set button for a few seconds. This will cause the time to flash.
3. Press the Up/Down buttons to reset the new time.
4. Press Alarm button once more to set minutes. Press again to exit alarm setup.
Cheers!
Jan 22, 2013 | Discovery Channel Discovery Kids - Rocket...
Discovery kids rocket clock - no manual
I can't upload a manual but I can give you instructions:
1) set time: hold down "time set" button for five seconds, then use up and down arrows to change, and press "time set" button once to toggle between m/d/y/hour/minute. If it goes to the alarm setting instead of time setting, try again.
4) to project the images: push the buttons that read "time" or "image". to focus the image, rotate the cylinder around the lens that projects the image. use the dial under the lens-cylinders to select a different image
5) military time: press the "up" button when the time is displayed (not when you're setting the time) to change from 12 to 24 hr or vise-versa
Good Luck!
Dec 03, 2012 | Discovery Channel Discovery Kids - Rocket...
How do you set the alarm clock for a model:38229-1 clock
Press mode key at any time to exit.
Press mode, then press adjust to change time zones.
TO SET TIME AND DATE:
Press and hold alarm on/off for about 5 seconds until hour flashes.
Press adjust to change hour.
Press alarm on/off to move to minutes. Press adjust to change minutes
Press alarm on/off to move to seconds. Press adjust to change seconds
Press alarm on/off to move to month. Press adjust to change month
Press alarm on/off to move to date. Press adjust to change date
Press alarm on/off to move to day of week. Press adjust to change day of week
Press mode key to save to exit.
TO SET ALARM:
Press mode to go to alarm screen (AL shows above temp)
Hold the alarm on/off button for about 5 seconds and the hour will flash.
Press the adjust button to change the hour.
Press the alarm on/off button again to move to minute
Press the adjust button to change the minutes
Press the mode key to save and exit
Aug 22, 2011 | Audio Players & Recorders
I just got a Memorex Digital CD Alarm Clock with no manul the modle number is MC 7101. I'm not able to set the clock or alarm. I just need the instructions.
To set the clock:
1. With the power off, press the TIME button; the time will blink.
2. Press the MINUTE button to set the present minute and the HOUR button to set the present hour.
Make sure to set the correct AM/PM setting.
3 Press the TIME button (or wait approx. 15 seconds) and the time will be set.
To set or reset alarm time:
1. With the power off, press the desired ALARM, Press and hold the desired ALARM 1 or ALARM 2 button; the alarm time will blink. The Alarm 1 or Alarm 2 time and settings will appear.
Press the MINUTE button to set the alarm.
2. Press and hold the desired ALARM 1 or ALARM 2button; the alarm time will blink.
Press the MINUTE button to set the alarm minute and the HOUR button to set the alarm hour. Make sure
to set AM/PM setting. Press the ALARM 1 or ALARM 2button again (or wait approx. 15 seconds).
3. Repeatedly press the ALARM 1 or ALARM 2 button to select alarm off, alarm on, for buzzer, radio or CD.
If you needed the manual it could be downloaded:
http://www.retrevo.com/support/Memorex-MC7101-Clock-Radios-manual/id/1081dj880/t/2/
Thanks.
gylacz
Aug 01, 2011 | Memorex MC7101 Clock Radio
I can't set the alarm on a Bush dabcr2004/a radio alarm clock
If anyone still has one of these, and is struggling to set the alarm, try this:
For setting the alarm
Press the menu button. Press right arrow button 5 times until you get 'clock' then press select.
You'll see 'set alarm,' press select button again to say yes.
You'll see a display with all the current settings: Alarm 1, the current alarm time and whether it's set for Daily or Once. Pressing the right arrow now advances the hours, the select button moves you on to the minutes, set these with the arrow buttons too.
Select button now moves you to 'Daily' or 'Once' - again you change this with the arrows. Select button moves you on to choose Radio or buzzer (again, you change this with the left/right arrows and press select for your choice).
All settings are done, you can power off now, or I think pressing menu took me out of settings mode and back to radio display.
Turning the alarm on or off:
Press menu, then right arrow 5 times for 'clock.'
Select this and you'll see 'set alarm' - press right arrow button once and you get 'Alarm On/Off.
Now every time you press select, the bell symbol toggles from visible to invisible, visible being 'on.'
You can now press menu to get out of the settings mode.
Jul 20, 2011 | Audio Players & Recorders
Can not change time!!
TO SET ALARM:
Good luck and please rate 4 thumbs up for the free answer
Apr 22, 2010 | SkyScan 86709 Atomic Wall Clock
I can't reset the time on my clock
TO SET ALARM:
Good Luck aqnd please rate 4 thumbs up for the free answer
Sharper Image Projection US Atomic Alarm Clock (model number OQ311)
try looking up the manual on the model number you might find it online. I have the maual for this model.
Jun 10, 2008 | Audio Players & Recorders
44 people viewed this question
 Grubhead
Grubhead
