Question about Garden
Carburetor fills with gas I have replaced needle and floot is fine . What does the electric selianode do
It's a 15003-2801 model carburetor
  • 5 more comments
  • Eugene Rounds Dec 14, 2014
    Hi Forrest williams, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
    Which Kawasaki engine is it used on so I can look the IPL?
  • Forrest williams
    Forrest williams Dec 16, 2014
    It's a 20 hp Kawasaki mog3458112294 got it started floods bad will run on high idle if cut off I have to remove plugs to clear gas from Pistons and dry the plugs of gas .it will blow gas out of plug holes when spinning motor over with plugs out .with bow
  • Forrest williams
    With bowl off I can hold the floot up and gas will not come out .would the setting have anything to do with it.by the way where is it supposed to be set
  • Eugene Rounds Dec 16, 2014
    With the carburetor inverted the float should be parallel to the base of the carburetor. It is hanging down closer the the base of the carburetor it will allow the carburetor to overfill with fuel. You can also apply fuel the carburetor while it is inverted to test for leakage needle seat.
    This is a plastic float with no adjustment; only can be replaced when it is out place.
  • Forrest williams
    thank you where is best place to buy a floot john Deere wants &23.00 I think that's high
  • Forrest williams
    Forrest williams Dec 19, 2014
    I changed floot it's still flooding
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,917 Answers
Make sure needle seat is not upside down
Posted on Dec 15, 2014
  • charles beach
    charles beach Dec 16, 2014
    the float if you turn upside down it will the float will be level with carb body if not replace float there not expensive about 7.00 dollars
  • Forrest williams
    I changed floot still flooding
libaredneck
  • 119 Answers
SOURCE: I have a 15.5 Briggs and Stratton engine. I used
you need to have the carb cleaned. sounds like the float is stuck
Posted on May 05, 2009
wilsodfarm
  • 986 Answers
SOURCE: 3020 carburetor ? john deere gas tractor, 3020
those carbs are real simple you will not have any problem
Posted on Jul 29, 2009
mowerman1857
  • 389 Answers
SOURCE: Carburetor problem on Craftsman 14.5 HP B&S
The switch you are talking about is an anti-after-run solenoid. It shuts off the fuel flow when you turn off the key switch.
To check its operation is easy, turn the key on and off a couple of times and listen for a click, if you don't hear it, hold the switch between your thumb and forefinger to see if you can "feel" it click on and off.If you neither hear or feel the switch working, you will need to use a test light or meter to check to make sure it is getting voltage to it to make it operate.
If you just recently filled up the tank, it is possible that you have gotten some contamination (dirt or moisture) that has gotten to the carburetor. You will need to remove the float bowl to check this. You will need a very thin 1/2" wrench to remove the solenoid (electrical device) from the bottom of the carburetor to get the bowl off after you unplug the wires from it. Use some sort of small tray or cut off the bottom of an oil container or whatever to catch what is in the bowl to inspect it for contamination.
If you have a plastic in-line fuel filter look at it at its lowest point to see if there is any water in it. Water will look like a seperate bubble within the gas and floating at the bottom of the gas. Before removing the float bowl you might want to rig up something to plug or pinch the fuel line to stop the gas from flowing out of the tank while you are working on it
Posted on Oct 25, 2009
backwoodsctr
  • 169 Answers
SOURCE: Kohler engine carburetor adjustment on John Deere Model 112
When u adj a kohler carb you adj fuel not air. Always adj the high speed then low speed. Then adj the curb idle. 1.5 turns out is a good starting point. Then tweak it after its warmed up. Hope this helps
Posted on Nov 20, 2009
  • 8 Answers
SOURCE: Tecumseh TC200-2026C carburetor
Rule of thumb for high speed is turn in til tight and back off 1.5 turns
Posted on Jan 08, 2010
I have a 60 inch with a 25 hp kohler. It keeps filling the oil up with gas. It runs fine but after 30 min runnin the oil is full of gas
rebuild the carburetor float is stuck down . and while at it put a shut off in the line going to the carb
Mar 18, 2016 | Garden
Why is there gas in crankcase
Hello Ricky, I would check the carburetor needle valve and seat along with the carburetor float. You could get lucky and just need to clean the crud out of the carburetor float bowl.
Nov 04, 2015 | Honda Es 6500 Gas Generator Electric Start...
What would cause gas to leak from carburetor on pressure washer
Needle and seat problem probably with the needle worn or seat worn or both OR needle sticking OR float and/or float level adjustment problems.
Sep 19, 2014 | Garden
Cyl fills up with gas after shut down to re-start must remove plug drain cyl re-install plug then mower runs fine??
Sounds like the inlet needle in the carburetor is stuck open. If you are lucky, you can give the carburetor a few taps near the fuel inlet area. (A few taps doesn't mean hitting it with a sledge hammer.) If that doesn't work, remove the fuel supply line from the carburetor and give the fuel inlet on the carburetor a shot of compressed air.
If the problem still persists, you need to replace the carburetor inlet needle and seat and be sure the float level is correct. I am assuming that you have not had the carburetor off and have not changed the carburetor float level.
Mar 24, 2014 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Gentron 10000w generator has a leaking carburator
Your carburetor float valve may be stuck open. You'll have to remove the carburetor, remove the sediment bowl at the bottom of the carburetor (where the float is), and check the float. Is it filled with gas? Replace the float if it is. If the float is dry inside, then remove the float and clean the needle valve & seat. (be careful to note how the float pin, linkage, spring, etc. are positioned so you properly reassemble. After cleaning & reassembling, turn the carburetor upside down & try blowing into the gas line connection on the carburetor. You shouldn't be able to blow air. Turn the carburetor right side up & repeat. If you can blow air into the carburetor's gas line connection, the float valve & seat are properly working. Reinstall the carburetor. You should be good to go.
Dec 03, 2013 | Gentron 10,000W Generator with Electric...
Gas leak from carburetor into bottom of air intake elbow. Filled empty gas tank and within seconds after opening the shutoff valve under tank, gas started to drip from bottom of intake elbow. Shut off the...
It sounds like the needle valve in the carburetor is not seating properly to shut off the fuel. A badly worn needle or dirt/debris in the needle seat area can cause this. Disassembly of the carb and a good cleaning will be required.
Sep 04, 2011 | Garden
Starts and runs for short time then dies. The oil is overfull and smells like gas.. When you take the dipstick/cap out oil/gas runs out
Don't run it that way! Drain the oil....all of it. You have a flooding carburetor. Most likely a stuck float needle. Drain the gas out of it too for now. Unscrew the Bowl on the bottom of the carburetor AFTER you drain the gas. At the front of the bowl is a clip attatched to a small metal needle valve.Let the float hang down and spray with quick bursts some carburetor/choke aerosol spray cleaner upwards where the little clip holds the needle on. This may dislodge whatever, dirt or crud is not allowing the needle to seat all the way, once the bowl fills up with gas. It works JUST like the water fill valve in the tank of your toilet. Clean out the bowl of any water and debris. Clean the bolt that holds the float bowl on the carburetor. Do NOT scrape it with any metal objects.
If you don't want to work on the carb this way, then remove it, disassemble it and clean it well with carburetor cleaner. Depending upon the age of the machine, you may need to install a rebuild kit.
Jun 17, 2011 | Honda Garden
Carburetor flooding
Not familiar with this model, but this is exactly how the smaller ones behave when the carburetor diaphragm is shot. Larger engines usually have a float system with needle and seat in which case the problem is either a leaking needle/seat assembly or saturated float.
Apr 11, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Troy-Bilt Chipper/Vac 5HP gas leaks out the carburetor
The float may have a hole in it causing it to sink and not seal the needle. Look at the float and check it for holes. You can shake it and listen for gas inside it. if so replace float.
May 01, 2009 | Troy Bilt Walk Behind...
Garden Logo
54 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
