Question about Samsung Refrigerators
I replaced the water filter and the light is still on. What should I do next.
I replaced the water filter. the light is still on. I went down and talked to a Lowes representative about the Samsung refrigerator. He asked me did I replace the water filter with the new filter or the old one. I informed him I replaced the water filter with the new one. I returned home and removed the new water filter and left it out for over three minutes and put it back in. the light is still on. What should I do next?
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 13 Answers
Have you held down the reset button which is usally right on the front on the refrigirator. Please give your model to help you out more. I just have to hold down my filter icon and it disappeared.
Posted on Dec 14, 2014
We have a Kenmore Refridgerator in our rental apartment. The light for the water filter went to red. We called the landlord but they claimed that they replaced it 3 months ago. They suggested we hit the...
recommended replacment time is 3 months and the computer knows it was replaced 3 months ago and has counted down the time the reset button was last pressed and determined its been 3 months. Depending on water quality in your region it may not need to be replaced unless the in door water or ice taste funny or the water dispenses slowly through the door because the filter was clogged and having a hard time having water pass through it.
Aug 17, 2011 | Kenmore Side by Side Refrigerator
Changed water filter and bushed lock & water buttons, red light went off but green light and other indicator lights (crushed ice, cubes, night light) did not work. Removed new filter & put . .back...
Below are instructions to reset water filter light. Thanks, Sea Breeze
If helpful please rate.
Reset Filter (select models)
When a water filter has been installed in the
refrigerator, the yellow Order light will illuminate when
90 percent of the volume of water for which the filter is
rated has passed through the filter OR 11 months have
elapsed since the filter has been installed.
The red Replace light will illuminate when the rated
volume of water has passed through the filter OR 12
months have elapsed since the filter was installed. A
new filter should be installed immediately when the
Replace light is illuminated.
After replacing the filter, press and hold the Reset
Filter pad for three seconds. The Order and Replace
lights will go off.
Vacation Mode
The Vacation Mode feature causes the freezer
to defrost less frequently, conserving energy. The
Vacation Mode indicator light will illuminate when the
feature is activated. To deactivate, press the Vacation
Mode pad again OR open either door. The indicator
light will go off.
Temp Alarm
Apr 22, 2011 | Amana 22.6 cu. ft. Side-By-Side...
I have a master 150000 btu kerosene direct fire heater that runs for 5 minutes then shuts down and blows white smoke. what is the problem?
The white smoke is the kerosene fuel hitting the hot combustion chamber. Your flame has went out. The cause for this could be many. The first thing you need to do is check your fuel. Remove your fuel cap and look at the bottom of the tank for trash or water. Use a good flash light. It will all settle to the bottom. If so, drain and clean out your tank. Add fresh kerosene. Check your fuel filter. Replace if dirty. Test again. If problem continues, It is possible that your photo eye could be deffective or just dirty. It is located next to the ignitor or spark plug. It sees the flame. If the flame goes out, the unit shuts down. The flame has to be smooth (not sputtering). Water in the fuel will make it sputter and the unit will shut down. When the water/moisture in tank settles to the bottom, your suction fuel line is just off the bottom which results in it picking up the water instead of good fuel. Always disgard the old fuel from previous year and start with fresh fuel. This will cut down alot of your problems in the future.
Dec 07, 2010 | Master Heaters B155DST
How do I change the water filter
Removing and replacing a water filter - upper right hand corner location
Filters situated in the upper right hand corner of the refrigerator compartment of Maytag-built side-by-side refrigerators are relatively simple to replace. Follow these steps:
  • These eight inch long filters are housed in their own compartment. The base of the compartment can be released by pushing in on the release clip found at the end of the housing unit. Allow the base of the housing compartment to hang down while you remove and replace your filter.
  • Twist the spent filter to the left (counter-clockwise) and gently pull on it to remove it. There is an automatic water shut off to keep leaks and spills to a minimum.
  • Remove the new filter from its packaging. Remove the plastic wrap, and peel off the aluminum topping. Insert the new filter into the housing unit. Twist the filter to the right (clockwise) until it clicks into place. Replace the base of the filter housing by cliping it back in place.
  • Condition the filter by dispensing several glasses of water through your refrigerator. This ensures that all fine carbon particles have been removed.
  • Check the filter and the inside of the refrigerator for leaks. If you find a leak, remove and install the filter again.
  • Finally, reset the 'change filter' indicator light, if your refrigerator has one, at the front of your refrigerator. The procedure for resetting the change filter indicator light can vary from fridge to fridge. Typically, the indicator light can be reset by holding down on the 'lock' button and the 'water' button simultaneously for three seconds. Sometimes, it is the 'lock' and the 'light' button you need to press down on simultaneously for three seconds in order to reset the filter indicator light.
Removing and replacing a water filter - center ceiling location
Filters situated in the center ceiling of the refrigerator compartment of Maytag-built side-by-side refrigerators are relatively simple to replace. Follow these steps:
  • Turn the filter a quarter turn to the left, in a counter-clockwise motion. The 'unlocked' symbol on the filter will be lined up with the indicator line that is molded into the refrigerator just above the filter. Allow the ears of the cartridge to disengage from the filter holder.
  • Gently pull down on the filter, being careful to not spill any water still in the filter. Discard the used filter.
  • Remove the new filter from its packaging. Remove and discard the red plastic cap found on the top of the new filter.
  • Apply the appropriate month sticker to the filter to remind your self to remove and replace the filter in six months' time.
  • Insert the new filter into the filter opening. Line the 'unlock' symbol on the filter up with the indicator line that is molded into the refrigerator above the filter. Turn the filter a quarter turn to the right, in a clockwise motion. You will be able to feel the filter stop when it is all the way in, and the 'locked' symbol on the filter will now be lined up with the indicator line above the filter.
  • Close the refrigerator door and dispense several glasses of water through the water dispenser in the door in order to purge the new filter of any impurities. Open the refrigerator door again and check for leaks. If you find a leak, remove and replace the new filter again.
Nov 29, 2010 | Maytag MFI2568AES Stainless Steel Bottom...
Went through not too deep water car stalled , replaced air filter and checked batterie car clicks and lights dim when you try to start.
Well if its clicking that means your starter isnt working. You can try replacing the starter. Its also possible that your starter isnt' getting enough juice, or your ground is bad. Go from there. Also if it went through enough water for it to go in air filter, it would be wise to change the oil as well to make sure no water is in your oil.
Thank you,
Lee
Apr 26, 2009 | 2005 Ford Freestyle
Changed water filter red light stays on
Afer you change the filter and have run the water for about 1 minute you then hold down the light & lock button together and this should turn the change filter light off.
Apr 23, 2009 | Refrigerators
New water filter replaced follower instructions in book Orang lig
There is no sensor that knows you replaced it. Probably have to hold down a button or two to reset light on dispenser area; read your manual for directions or find it on-line from the mfr website if you don't have it. I do not know what key sequence.
Nov 27, 2008 | Refrigerators
Reverse osmosis water filter
Hi jennym123,
I'm Harvey the Master Plumber.
Your question is: You have a reverse osmosis water filter. The other day water production went from over a gallon of filtered water to 3/4 of a cup. You changed the filters thinking that may be the problem, but that did not solve anything. What else could be wrong with it?
This is a common problem. Can also be very frustrating. A small bit of debrie has been brought up by the flowing water and is stuck somewhere. As you can imagine this will restrict the flow. I would start with the on/off valve next to the cold water line first. Turn the water off first and take it apart checking for obstructions. Then work your way down checking the lines and any place you can. It's helpfull to have a bit of wire to probe with. If you turn it back on and the problem still persists then you missed it. Try again. Good luck.
Feel free contact me again!
Please give me a rating here at fixya before you sign off
Thank you,
Harvey your Master Plumber
Sep 16, 2008 | Home
KitchenAid Superba
You indicator light on your fridge is set on a timer. If you never took a single glass of water it would go on after six months or so. It is just an aide to remind you. To replace it, firmly turn counterclockwise about a quarter turn with a little pressure pulling down or out depending on the location of the filter. You need not turn off water. Replace with new one.
Sep 21, 2007 | KitchenAid Superba Architect KSCS25INSS...
Refrigerators Logo
77 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
