Question about Sony BRAND NEW UNLOCKED ERICSSON TEXT PRO CK15a PINK 3MP QWERTY TOUCHSCREEN WiFi SLIDE SMARTPHONE
What is the tool i need to unscrew wall bracket from back of tv
2 Suggested Answers
SOURCE: Trouble mounting cantilever wall mount bracket to Sony TV
Finally figured out the correct arrangement or configuration through trial and error (and my wife's puzzle solving ability). It sure wasn't clear in the instructions, and I could not get the needed information from the website of either the manufacturer of wall mount system or TV...a little frustrating, but perseverance paid off. Given the price of the wall mount, I would think they could do a better job.
Posted on Oct 25, 2009
How can i wall or bracket mount a Samsung Syncmaster S27B350
dear very easy. you just purchase a wall bracket from market and unscrew the stand from your monitor and place that bracket instead of monitor stand and make holes in the wall and place it on wall.
Oct 20, 2014 | Samsung S27B350H - SyncMaster S27B350H -...
How can I put. On my led tv on the wall
You need to purchase a wall bracket for your TV. There are several types on the market. Make sure the mountind holes on the TV line up with the wall bracket mounting holes and it can support the weight of your TV.
Google search for a wall mounting bracket for your model TV.
Nov 21, 2011 | Televison & Video
I have removed the piece requiring the hex tool. However, I can't get the base off the wall. How can I remove it?
The base is probably connected to wall with toggle bolts, thus meaning , as you try to unscrew the bolts that keep spinning, pull on the bracket away from wall as you unscrew the bolts and it will come off.
Aug 31, 2011 | Moen 24 In. Towel Bar...
How do you remove the base inner bracket parts so that you can mount the TV on to a wall?
What make and model?
Most wall-mountable TVs will have threaded holes in the back for wall-mounting. Most of which you can bolt a bracket to then unscrew a few of the set-screws for the stand and slide the TV off of the stand.
Most TVs have 4 set screws for the stand located near the bottom middle of the TV where the stand inserts into the TV. The screws may be recessed fairly far into the back of the set and may require a long thin screwdriver.
Jan 01, 2010 | Panasonic TX-32LXD1 32 in. LCD Television
How do I remove the stand of the Sony Bravia XBR KDL-V40XBR1 so i can wall-mount the tv?
you have to lay the tv on it's front on something to protect it from being damaged.on the back you'll see where the base joins the bottom of the display, this needs to be unscrewed and a wall bracket screwed in instead.
Nov 26, 2009 | Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV
Try to mount TV to the wall and need to release the TV stand
To Display your LCD TV using a Wall Bracket:
If you decide to wall mount your LCD TV, always use a ULlisted wall bracket appropriate for the size and weight of the LCD TV: 32HL37/32HL37U/32HL17/32HL17U: 38.6 lbs (17.5 kg)
37HL17: 46.3 lbs (21.0 kg)
42HL17: 59.5 lbs (27.0 kg)
1) CAUTION: Two people are required for installation.
2) Unplug and remove any cables and/or other component connectors from the rear of the TV.
3) Follow the instructions provided with your wall bracket. Before proceeding, make sure the appropriate bracket(s) are attached to the wall and the back of the TV as described in the instructions provided with the wall bracket.
4) After attaching the appropriate bracket(s) to the wall and the back of the TV, remove the pedestal stand from the TV as described below.
Removing the Pedestal Stand
1) Carefully lay the front of the unit face down on a flat, cushioned surface such as a quilt or blanket. Leave the stand protruding over the edge of the surface. Note: Extreme care should always be used when removing the pedestal stand to avoid damage to the LCD panel.
2) Remove the jack pack cover on the back of the TV to expose the pedestal stand screws. The jack pack cover can be removed without tools.
3) Remove the five screws. This will allow removal of the pedestal stand.
4) Once you have removed all five screws holding the pedestal stand in place, remove the pedestal stand from the TV by sliding the pedestal stand away from the TV.
Sep 28, 2009 | Toshiba REGZA 32WLG66 32 in. Television
How do I remove a plasma panasonic mounted on a wall.
if it is a swing bracket 4 screws on back bracket holding it in need to be removed, if it is flat wall bracket lift strait up the wall to remove.
hope this helps
daniel
Jan 11, 2009 | Panasonic TH-50PX75U Plasma HDTV
How to fit wall bracket to tv
the bracket should have instructions. the set will have screw holes on the back to bolt to the bracket.
more detailed info needs to come from the bracket MFG
Dec 05, 2008 | Televison & Video
I want to take off the base of my flat screen tv.
lay tv down on a flat soft surface remove 4 philips screws on back on either side of signal brd inputs base will pull out of bottom
Oct 15, 2008 | Westinghouse LTV-40w1 HDC 40.02 in. LCD...
Sony BRAND NEW UNLOCKED ERICSSON TEXT PRO CK15a PINK 3MP QWERTY TOUCHSCREEN WiFi SLIDE SMARTPHONE Logo
Top Sony Cell Phones Experts
Gil Shultz
Andrew Taylor
Andrew Taylor
Are you a Sony Cell Phone Expert? Answer questions, earn points and help others
