Question about Radio Communications
On a galaxy 66 v it was working then feq and channels got real dim and went out what cause that
I was thiking voltage regulator but not sure
    Genius:
  • Radio Commun... Master
  • 1,795 Answers
Could be but check the reverse polarity diode first and see if its blown. If it is replace it with the same diode .1n4001
Posted on Dec 17, 2014
I am getting a code telling me my voltage regulator diodes are bad on my 1996 Dodge Grand Caravan. Should I be replacing the PCM to fix the problem.
Not sure about the 96 but, voltage regulators generally have to do with the alternator. As a matter of a fact you can just replace the voltage regulator on the alternator as opposed to spending the money that it cost to replace the whole alternator, I found this out because a mechanic ripped me off and charged me for a alternator but, he only replaced the voltage regulator diode part on the alternator.. Replacing the PCM is going to be expensive and in my opinion not necessary
Feb 09, 2017 | Dodge Grand Caravan Cars & Trucks
Where is the voltage regulator located
The voltage regulator is located on the engine itself. Before blaming the voltage regulator you need to make sure that there is no drain on the battery while it is sitting and also the battery is a good one. Batteries can develop problems that will cause them to drain themselves over time. Also using a DVM (digital volt meter) check to see if there is a charge voltage of 12.5 vdc up to about 14.5 vdc. If this is present then voltage regulator and alternator both are working fine.
Mar 02, 2014 | Mustang Rzt 50" Zero Turn Riding Lawn...
Battery not charging..good alternator...internal regulated alternator
that year 1986 alternator voltage regulator either external or internal follow alternator battery feed wire if you see battery feed wire going to black box mounted on fire wall you have external voltage regulator.if voltage regulator okay problem could be alternator fuse or fuse link could be faulty battery cables if cables over 20 years old but make sure alternator drive belt tension correct.
Oct 27, 2013 | 1986 Chrysler LeBaron
Replacing voltage regulator
Not sure what you mean when you say Replacing voltage regulator. Would need to know the model number of the engine however as a general rule a voltage regulator is fairly easy on most of the John Deere mowers. As with any electronics when you buy they are not returnable. Depending on the engine you have a voltage regulator can be costly and may not fix your problem.
Sep 29, 2013 | John Deere Garden
My problem is voltage fluctuation, after starting generator the voltage is 380v and become 150v then goes up to 410v
I am sure the problem is the adjustment of the voltage regulator.
There are 3or4 small adjustable "pots" on the circuit board of the regulator.
You must connect an analoge volt meter to the output of the generator for this adjustment. Adigital will not work in this case. You will need to adjust the "IR" compensation pot as necessary to stabalize the voltage. This adjustment will surely change the voltage also. As you change the IR you will need to change the voltage too.
Let us know if you need more help.You may need to get the info sheet for your regulator if the pots are not cleasly marked.
Robert
May 11, 2012 | Caterpillar Electrical Supplies
There was a fluctuating voltage and my Kenwood XD-V323 started blinking its display screen and then stopped working, Was not able to switch it on again. I tried changing the Fuse inside, thiking that it...
there is a downed primary circuit on your power supply board it will need to go into the shop to have the fault found and repaired there is no easy fix to this problem
merry christmas
please rate advice
Dec 25, 2010 | Kenwood Audio-Video Control Center VRS6100...
Where is the voltge regulator on a 1989 lincoln town car
VOLTAGE REGULATOR IS LOCATED BEHIND BATTERY.YOU PROBABLY MIGHT HAVE TO REMOVE BATTERY TO REMOVE THE VOLTAGE REGULATOR.
May 16, 2010 | 1989 Lincoln Town Car
Voltage regulator location
NOT sure of what back feed you are talking about. But for reference the voltage regulator is BUILT IN the alternator.
Jan 08, 2009 | 1995 Eagle Summit
Radio Communications Logo
41 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Are you a Radio Communication Expert? Answer questions, earn points and help others
