Question about Dryers
I have a whirlpool accudry cabrio dry i turn it on and hit the start and nothing happens it seems like its running but the motor is not running any ideas
  • Dryers Master
  • 744 Answers
Hello;
My name is Peter. I am a retired field service appliance technician.
Is this a gas or electric dryer? What is the model number? The model number is on the dryer after you open the door.
In the mean time. You may have a air flow problem. In the back of your dryer there is a air distribution manifold. It is held on with several screws. Remove the manifold. At the bottom is where it is most likely plugged up.
If this is not the solution send me your model number and I will help you.
Posted on Dec 14, 2014
  • 21 Answers
SOURCE: Whirlpool Dryer GEQ9858J autodry problem
Are you running the dryer in a relatively humid environment?
Posted on Sep 08, 2007
textonor
  • 130 Answers
SOURCE: whirlpool Cabrio electric dryer
ctwoods, this sounds like the heating element has shorted to the heater can. What that is doing is leaving the element at 1/2 power on all the time. If this happened, then the heat kept going up until it blew the thermal fuse which caused the motor not to run. So check the heater and any fuses in the dryer. You can go to Service Matters for Whirlpool Service Manuals on this model.
Posted on Feb 03, 2008
onthejob5130
  • 640 Answers
SOURCE: drum wont turn
yes the start whinding shot,,,replace motor..
Posted on Jan 25, 2009
SOURCE: Whirlpool Cabrio dryer won't start - the "sensing" light is on
where are the answers on those stupid site
Posted on Oct 21, 2009
Front door willnot stay closed
Hello Shirelle,
The door lock mechanism is defective Or the door seal is seating properly.
Jul 04, 2015 | Whirlpool Cabrio WED5500X 27" Front-Load...
HOW DO i RUN DIAGNOSTIC CODES ON THE WHIRLPOOL CABRIO ACCUDRY DRYER
This unit has a belt switch ( W10411937) located on the motor frame, you should first check to see if the belt is not broken, or has not come off track. This can be done by disconnecting power and removing the toe panel to view inside the unit. Pleazer Appliance...
Dec 27, 2014 | Whirlpool WED5500XW Electric Dryers
Lights come on, press start and nothing ..
Start Switch is bad, When they go out it leave's a open circuit and all light will come on but no action.
After the circuit is closed then it tells the dryer to start cause the circuit activates both the timer and the motor.
Good Luck
Mike Z
Dec 01, 2013 | Whirlpool Cabrio WED5500X 27" Front-Load...
Dryer not tumbling
It's probably the belt that turns the drum. They're easy to change and inexpensive too.
Oct 30, 2013 | Whirlpool Traditional Electric Dryer with...
Turn on power, the lights come on but when you press start nothing happens just a click sound.
Click sound at power button and start button should get it going. If not then Dryer drum is not turning.
Aug 08, 2013 | Whirlpool Cabrio WED5550XW 27" Front-Load...
Whirlpool Cabrio Dryer moisture sensor not working
The moisture sensor may be contaminated with softener residue. The residue can be removed with window cleaner ONLY.
Feb 01, 2018 | Dryers
Doesn't automatically turn off in accudry sensor
yes,the moisture sensor bars inside the unit can be replaced,you need to tear down part of the machine to do so,to further assist you,a model/serial# would help
Jul 17, 2010 | Whirlpool Dryers
Whirlpool dryer
is hte light going out?? ope nteh door and try physically pushing the door switch (grey rectangle in the top center of door opning, does it "click" as you push it??? if not really push it, pull it, samck it a fewt imes. sometomes i find they hang up and dont function properly. but when i go to replace one it pops out as i start to change it
Mar 11, 2008 | Whirlpool GEW9250P Electric Dryer
Whirlpool Cabrio electric dryer
Feb 03, 2008 | Dryers
Sep 07, 2007 | Whirlpool GEQ9858J Dryer
Dryers Logo
63 people viewed this question
Top Dryers Experts
