Question about Coffee Makers & Espresso Machines
Why won't steam come through the nozzle - Coffee Makers & Espresso Machines
  • 691 Answers
This could be because the end of the steam wand is blocked. Use a small sharp needle or similar to open up the holes in the nozzle and try again. If not you may need to remove the steam arm and clean it through. It could also be that the valve is failing to open when you operate it. Without knowing the make model you are unlikely to get a detailed answer to your problem
Posted on Dec 14, 2014
The steam comes out of the water reservoir cap instead of the steam Jet Nozzle.
I can only guess since I have never worked on one of these units, but I think you lost a gasket on the cap. Pressure must build in the reservoir before being forced out the nozzle.
Jul 13, 2015 | Tristar SB Steam Buggy Vacuum
Lavazza does not steam
put in steam nozzle something like a long needle or something similar.
Dec 07, 2013 | Lavazza Espresso Point Capsule Machine
Steam nozzle
Yes, it's OK to work without steam function. Actually, it is not a real hot steam. It just spray the water.
Oct 06, 2013 | LG Dryers
Singer 7467 wheel won't spin, unless little bit if I do manualy by hand...
do this
If the iron heats but steams improperly, inspect the soleplate and clean the vents (see below) and flush sediment out of the steam chamber (see below).
If the iron produces too much or too little heat, test the electrical cord . Also test and, if needed, adjust calibration of the thermostat
If the iron does not spray properly, inspect and clean the nozzle (see below).
If the iron leaks or spits, clean the steam vents, nozzle, and tank.
If the iron sticks to fabric, clean or repair the soleplate. If the iron stains fabric, clean the soleplate, clean the tank with a commercial cleaner, and use distilled or filtered water.2_1_2013_6_01_09_pm.jpg
Jan 31, 2013 | Singer 7467S - Confidence Sewing Machine
Little yellow steam cleaner wont work no steam coming out of nozzle
I have got a little yello steam cleaner there is no steam coming out of the nozzle wot should I do to be able to get this to work again if some one can help me please
May 06, 2012 | Vacuums
Shark SV736R motorized brush won't rotate
The 2 metal pins of the motorized brush are not in contact with the vacuum cleaner. or the Motorized brush is clogged up. You have mentioned that it is cleaned, but still give a thorough inspection. For the metal pins, firmly insert the motorized brush into the air-intake nozzle. This will connect the motorized nozzle to the unit power supply.
Oct 21, 2011 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Gaggia Steam Nozzle
There is a sit where you can get the parts for the gaggia it is at WholeLatteLove.
Jan 04, 2009 | Gaggia Classic Espresso Machine
No steam coming out of heating nozzle for Wega
Remove the nozzle on the end of the steam wand, them open valve to see if the steam wand works, if yes use a paper clip to clear holes on nozzle, if no remove steam wand where it is connected to the valve then open wand(steam will be spraying be careful). If you have steam there then clean wand and nozzle.
Dec 16, 2008 | Wega Mininova EPU Espresso Machine
Steam Nozzle
I've only had it fly off once.  I think I didn't put it all the way on.  Also make sure you clean the nozzle every time you use the steamer.  Milk will clog the nozzle otherwise.  My maker is right beside the sink and I rinse the nozzle immediately after steaming milk.  I also run it through the dishwasher at least weekly.  (This isn't a substitute for immediate clearing of the nozzle.)   A clogged nozzle will always blow off the end.
Aug 12, 2008 | Krups XP4030 Espresso Machine
Coffee Makers & Espresso Machines Logo
51 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
