Question about Worx (16") 3.5 HP Electric Chain Saw - WG303
Oil is not pumping out to the chain
Either pump is not working or is clogged
    Sergeant:
  • 340 Answers
Hi Katt the chainsaw doesn't have a pump as such. What you will need to do is run the saw and spray some oil onto the chain manually to remove the blockage. Failing that take the chain assembly off and clean all around the cogs at the back with a soft brush.
Posted on Dec 15, 2014
Lost oil pressure in a 1999 540i and timing chain noise
from the book the oil pump is driven by a chain from the crankshaft. It is very possible that the oil pump has come loose and thrown/broken the pump chain. It will require a sump removal to check it out. recheck the oil level as what you read may have been a froth level . there is no reason for extra oil unless it was overfilled to start with or there is water contamination ( white /grey oil)
Nov 29, 2013 | 1997 BMW 318
Husqvarna not pumping oil
Check the oil lines to make sure none of them are clogged and that the oil holes in the bar aren't clogged.
Oct 25, 2011 | Husqvarna , No.455 Rancher, 20" Gas -...
My Poulan Pro chain saw (model # PP4620 AVHD) doesot move B&C oil from the oil reservoir to the chain. How can I repair this?
If the ports where the oil comes out aren't clogged, you will have to order a oil pump and then take apart the saw from right underneath the bar. The oil pump is run by a worm gear that strips easily.
Aug 22, 2011 | Poulan Pro Chain Saw 46cc 20"
Bar not recieving oil
The problem is related to the internal oil pump. The followings are the possibilities:
  • Clogged line from the oil reservoir to the pump.
  • Clogged line between the oil pump and the chainsaw bar orifice.
  • Faulty oil pump itself (common in well used/old device).
Hope it helps.
Jul 28, 2010 | Stihl 16" Chainsaw Bar Chain Saw 018 025...
1993 buick lesabre my oil pump stopped pumping oil in the engine. Where is the oil pump located? do I need to adjust the timing chain?
Oil pumps on these do not go bad. The oil pressure sensor could be bad giving you a false reading. If not the only other thing could be is a clogged up oil pickup screen inside the oil pan. also get a delco pf47 filter
Dec 28, 2009 | 1993 Buick LeSabre
How to change the oil pump
Before you change the pump, take it apart and look inside it could just be clogged with saw dust. If its anything like a chain saw it will only be clogged for this is a drip system I believe and not a pumped kind of system. Take a look before doing anything else. Good luck!
Oct 19, 2009 | Garden
What is the most likely cause of oiler not working
Several causes exist. Most likely are:
1) Clogged oil-hole in bar.
2) Clogged strainer in oil tank. (part # 530056533)
3) Unhooked pickup hose in oil tank. (part # 530038373)
4) Faulty oil pump. (part # 530071259)
Of course, check oil level and use proper bar&chain lube.
Hope this helps,
Dolf-
Oct 16, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Chain oiler inop
this is a common problem and requires replacement of the pump. remove the bar and chain, the pump comes loose with a few screws. under it you'll see the filter which could be clogged, but not usually as contaminants are not likely to enter the tank. Small engine shops can order the new pump for you, hope this helps
Dec 22, 2008 | Husqvarna Chain Saw 20" Bar
Husqvarna chain saw oiler
My Husky 36 did this. The oil pump drive gear was stripped and had to be replace. It's located under the flywheel/sprocket so you have to pull that. I couldn't find info on how to do that so had a local shop repair it for $70! Parts are cheap, labor is not.
Oct 22, 2008 | Husqvarna Chain Saw 20" Bar
Worx (16") 3.5 HP Electric Chain Saw - WG303 Logo
174 people viewed this question
Top Worx Garden Experts
Tim Whalen
Wayne McNeil
john milligan
Are you a Worx Garden Expert? Answer questions, earn points and help others
