Question about Cell Phones
How to connect Nokia 0979 bluetooth to Samsung note3 phone. In this bluetooth there is no volume control swith.
  • 88 Answers
Hi . Make sure that both of the devices have bluetooth turned on. An be visable On any of them press scan and the other should show up in the area .click on the phone you just scanned and there should be a option to type in a code no. Then on other do the same and type in a code of 4 digits and put the same code in the second device and press connect
I hope that this helps
Posted on Dec 14, 2014
Raysagem
  • 1017 Answers
SOURCE: Samsung E900 Bluetooth Pin Code???
You don't need a pin usually, type in 0000 it should work.
Posted on Jan 01, 2008
  • 48 Answers
SOURCE: Bluetooth connection
You will need a sim card in the samsung before it will work, the nokia E65 doesnt need a sim for the phone to work so move your sim into the samsung & it should transfer them over for you via bluetooth.
Posted on Feb 10, 2008
SOURCE: Nokia 1100 phone when i connect the charger only i
The problem with your phone is battery, the battery on your phone can no longer hold charges, that is why it switches on when you connect the charger.
I would advice you get a new battery on your phone and make sure you charge the new battery for at least 4-5 hours before you start using it. doing this will solve the problem on your phone and charging the battery before usage will help preserve the life span of the battery.
Take care.
Posted on Jul 19, 2010
  • 323 Answers
SOURCE: bluetooth is not swithed on.when
hi
there must be some software problem or your phone will be affected from virus. kindly format the phone and try it.. if you still have same problem. then there must be some hardware fault in your mobile.. kindly contact your service and ask the solution .. this will fix your problem..
thank you
Posted on Dec 20, 2010
vanherringto
  • 1738 Answers
SOURCE: My Bluetooth device (CE 0979)
Turn off the Bluetooth device and turn off your phone. Turn your phone back On. In your phone go to Bluetooth and remove permission for the device. Re-start your phone. Turn your phone back on and pair your device. The passcode is probably 0000 (four zeros). Once paired it should work properly.
(Note: Make sure your Bluetooth device is fully charged before attempting to pair it.)
Posted on Feb 05, 2011
I have a Schwinn Blue Tunes Bike Speaker. It pairs to my Samsung galaxy S4 through Bluetooth with no problem. I am able to control my spotify account with no problem using the device. I am able to play,...
It seems many people use only the term "paired" when talking about CONNECTING two Bluetooth devices. Connecting two Bluetooth devices means first "pairing" them and then "connecting" them. Pairing is a one time process done only the first time you try to connect the devices. It is like the two devices getting to know about each other. Next step is to actually connect the two and this process is done the first time after the pairing and then every time you want to use the speaker from your phone. When you open the Bluetooth tab on your phone's Settings menu you will see the names of all the Bluetooth devices it has been paired with previously and a "Paired" word next to it. If you want to use the device/speaker, tap on the name and it will CONNECT to it. You will see the word "Connected" instead of "Paired". Now you should have the music that you play on the phone coming out through the speaker. If you still can't hear the music over the speaker after a successful connection, turn up the volume on your phone (and on your speaker, if it has its own volume controls).
Feb 08, 2015 | Samsung Radio Communications
Can I pair a sacool blue tooth to my Samsung galaxy note3
If your device has a blue tooth icon in the settings, then it should be able to connect to any Bluetooth device.
Apr 27, 2014 | Cell Phones
My Bluetooth device (CE 0979) has just stopped working. Green light flashes non-stop. How do I get it going again?
Feb 05, 2011 | Nokia E51 Cellular Phone
How can i connect bluetooth ce0681 to nokia n95
All these given solutions are not catering your problem unfortunately; because your problem seems to be the following "You are not at all able to find your bluetooth headset from your phone, pairing is a far off thing" right?
So, here is the simple solution that no one has given here and on other sites (I myself was confused, but finally found it out):
1. Turn bluetooth of your Mobile on.
2. Put it into "shown to all" mode.3. Now pick your bluetooth device, and simultaneously click on the multifunction key (The middle one that blinks) and the "+" volume key for around 6 seconds or more; you'll see that blue blinking light will become static (and it means that your bluetooth device is now "Searchable" by your phone).
4. Start "Pair new device search" from your Mobile, and your Phone will find the bluetooth device.5. It will ask you for a passcode, just enter 0000.6. Pair both devices now.7. The static blue light (Which became static when you pressed the middle multifunction key and "+" volume key together for some seconds) will now start blinking again (in a 3 sec interval approximately).
Your handsfree is now connected, do a test call and confirm.
In case you find any volume problem, then know that the default volume after connecting a bluetooth handsfree is at low level, so just increase it using your Phone's volume keys/ controls and it shall be all fine.
Vote up if it helps, it is the genuine solution of this problem though; I tested it several times. :)
PS: I'm writing this while logging off in haste, pardon any spell/ typo mistakes. :P
Jan 21, 2011 | Nokia N95 Cellular Phone
I have bluetooth hed set but not connected to nokia n72
swith on the bluetooth on both phone and on headset.... paior bothdevices........
Oct 18, 2010 | Nokia N72 Cellular Phone
How to connect a bluetooth headset with nokia5230?
You need to switch on the bluetooth in both device then search the device in your phone ,same time while you searching in your phone press the button repeatedly in your bluetooth headset.Then device will found in the phone and connect it.
Thanks Fixya team
Sep 29, 2010 | Nokia 5230 Cell Phone
How do I connect my phone to bluetooth
Open the menu, check settings- connectivity- in sub menu - bluetooth must be swithed ON.
Now have it detected in any bluetooth device , send a passkey or have it accepted to communicate , transfer files .
Sep 29, 2010 | Samsung Cell Phones
Can't hear anything in my bluetooth headset, mic is working
Hi--First, make sure your "mute" function is off.  Try holding both volume buttons at the same time for a second or two.  If that doesn't help, while you're having a conversation, either with or without bluetooth, make sure your phone's volume is turned up.  On a lot of phones the volume button will control both ringer and conversation volumes, but turning it up without the phone in use only affects the ringer volume.  My husband thought there was something wrong with his bluetooth until we noticed his phone volume was set too low--not as noticeable on handset, but bluetooth apparently needs volume up pretty high!
Sep 29, 2008 | HTC Touch P3450 Smartphone
Cell Phones Logo
47 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
