Question about Eclipse Audio Players & Recorders
Error screen 0x50000011 wont play just shows this screen
180g2 model screen displays error listed above does not register when plugged to computer or come on if not attached to the computer tried to charge it just shows the error message
ThaMp3Doctor
  • 8596 Answers
SOURCE: Phillips GoGear SA5125/37 wont power up
The freezing at 87% suggests hardware malfunction, but you can try all of the "soft" fixes to be sure -
Triple Reset for GoGear:
Disconnect the Go Gear from computer. Press the reset pinhole until the player turns off. Hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard. If this pop-up does not appear, reset the player again WHILE connected to the computer. Open the Philips Device Manager, and go to Repair Tab. Reset the player one more time while connected to computer. Follow the repair instructions.
After repair is complete, upgrade the firmware for this player.
Will erase all the songs, but you should be good to go again.
-Tha Mp3 Doctor
Posted on Jun 12, 2008
SOURCE: frozen or dead
Thanks for the suggestion! I had the same problem and the reset button on the side (same side as power button) turned it off, I pushed the button and it came right back on, said it was rebuilding the library, and returned to normal.
Posted on Jun 22, 2008
  • 5 Answers
SOURCE: MES60V suddenly stopped charging.
Download, and install the firmware. It should work after that. It might of formatted the storage partition of the device, but you can resync it after you update the firmware on the device. You can get the firmware here: Gigabeat S Firmware.
Posted on Apr 04, 2009
  • 52 Answers
SOURCE: ipod wont charge or add songs.
If your using a ipod touch then i can help
Posted on Jun 27, 2009
SOURCE: I bought Transcend MP860 last
This is a common problem with these players (first link). My MP860 failed in this way (insufficient voltage etc message)
I made a rig with laboratory PSU (several amp output) connected to USB socket and I know that that the problem has nothing to do with voltage (voltage was stable 5V - tested also higher up to 5.5V)
For a while a trick with holding the volume up button worked for me. (see second link) But once I discharged the battery to a too low level and the trick did not work anymore.
My conclusion is that that message indicates Li-ion battery degradation and charger circuit/FW declines to charge it showing misleading message. (battery made by Foxlink)
I tore my the player open and rigged charge circuit and get it working again. Photo: http://farm6.static.flickr.com/5063/5683361395_d59bef8142_b.jpg
Few suggestions: 1. Never allow the battery to be fully discharged. Charge at any opportunity you have. 2. Once you get the Insufficient input voltage message try trick with holding volume adjustment. 3. If 1., 2. failed rip it open and make charging circuit or replace battery. 4. Do not buy Transcend MP3 players. (?)
http://ec.transcendusa.com/forum/viewtitle.asp?BoardID=42&TitleID=915&Page=1
http://www.mouthshut.com/review/Transcend-MP-860-rnlstlqtln
Posted on May 03, 2011
When i plug in my Eclipse mp3, its coming up as err_no=0x50000004. What can I do to fix this?
This is caused from the player losing its format. When you plug it in clear that message and then go to the computer screen that shows all the drives and see if it is listed there. If it is, you can right click on the icon for it and select properties, you can then restore defaults on it and it should be fine. You then can reinstall the music and it should play.
Aug 12, 2015 | Eclipse 180g2 4gb mp3 music/vid
How do you switch on the Eclipse 180g2 mp3 player
RTM page 6 :>)
Power On/Off
To power the player on, set the power switch to the ON position, or press and hold the
PLAY button for 5 seconds, until you see the Eclipse screens. To power the player off,
press and hold the PLAY button for 5 seconds, or until the device powers off, then set the
power switch to the OFF position.
http://www.eclipsemp3.com/180G2.pdf
May 02, 2015 | Eclipse 180g2 4gb mp3 music/vid
System error #1 Panasonic kxtg2770
1)On handset, press MENU, 0, 0, 1.
Handset display shows as follows.
*Skip this step when handset already shows as above.
2) On base unit, press LOCATOR for 3 sec until CHARGE LED flashes.
3) On handset, press OK button. Then wait until the handset display changes as follows.
If you receive an error message indicating the maximum number of handsets have been registered, you will need to deregister the handset from the base unit, then try to register again.
*If this does not work, your unit is defective. Please send your unit for service.
Panasonic Services Company Customer Servicenter
Suite B 4900 George McVay Drive
McAllen, TX 7850
McAllen, TX 7850
1) Press FUNCTION on handset. Then, using the Navigator key, press Down (V) 4 times, Right (>) 1 time, Down (V) 7 times, Right (>) 2 times.
2) On base unit, press MUTE. (MUTE LED flashes.)
Dec 04, 2010 | Panasonic KX-TG2770 Phone System w/...
TE-2200 show E12 help me please!
The error list does not include 12 for this model. are you sure it is 12? what is the description that shows on the display when you get the error?
Jul 15, 2010 | Casio Parts Cash Register PC Desktop
Re-registering the Handset is not working
The solution is this - unplug the base unit then plug it back in. After that it worked fine.
Jun 22, 2008 | Panasonic KX-TG2356 Cordless Phone
Screen wont show photos
  1. cannot show a play list,what should i do....
  2. even if i try to make my own play list but theres always a problem nor always had an error
  3. i cannot use or i wont have my own play list
  4. what should i do in this case
  5. what was the 1st step that i going to do
  6. can you help me about my problem?
  7. thats all....
Dec 22, 2007 | Canon PowerShot A520 Digital Camera
74 people viewed this question
Top Eclipse Audio Players & Recorders Experts
Oloyede Monsuru
juanmireles1
Are you an Eclipse Audio Player and Recorder Expert? Answer questions, earn points and help others
