Question about Ovens
How do I replace an old Drayton RT2 room stat (live, neutral, Earth) with a new Drayton RTS8
Current connections, on RT2 are live to T3, Neutral to T1, Earth to earth point
5 Suggested Answers
VtToolMan
  • 704 Answers
SOURCE: I am just about to disconnect our old oven and
You may need to get a wire connector to install on the ground (earth) wire, so it can be connected to the terminal connection point on the new oven.
If one wasn't provided with the oven, some do this as a service, just look at the ground terminal or in the bag with the instructions, etc. for one. If not, you should be able to purchase one, you'll just need to get one that fits the wire, so knowing the gauge of the wire (either Awg or Kcmil size) will make this easier to get the right connector size.
I recommend that a ring terminal be used, so in the event that the fastening screw might loosen, the ring terminal will not fall off the contact point, whereas a fork terminal could and can come off much more easily.
Not having more detailed info about the brand and where you're located, makes further possible solutions difficult to provide, since Fixya doesn't require requestors to provide any info on what country they're in, etc.
Nonetheless, I hope you find this Very Helpful and best regards!
Posted on Aug 19, 2009
SOURCE: we are having a neff
hi there i'm a qualified electrician and the answer to your question is simple, if the manufacturer has marked the terminals for connection the follow those markings. not all connections are the same on every model of oven. hope this helps you with your problem
Posted on Oct 16, 2010
barkencoa
  • 3463 Answers
SOURCE: I have just purchased a new electric cooker. The
Hi.
Live goes to live as normal earth to earth as normal, and the neutral is probably a comonj terminal, in other words it probably has a lnk joining the 2 neutrals together.
Posted on Nov 09, 2010
BElectric
  • 1140 Answers
SOURCE: Ive taken element out to replace with new but have
Hello Ian,
You can put the live and neutral on either of the outer terminals terminal. It really doesn't matter. It's the same principle as not needing to screw in a bayonet light bulb a certain way round. As long as the circuit is complete, it will work correctly.
To put it in the simplest terms, attach the earth wire to the shorter centre terminal with the live and neutral wires on the two outer terminals and job's a good 'un.
Hope this helps. If you need further assistance, please let me know.
Regards,
BElectric
Posted on Apr 18, 2011
Testimonial: "Did think that might be the case but was a bit timid in case I blew the house up Many thanks"
Live wire connection has 3 connectors for 3 phase. Do I put in all there bridges when connecting to single phase
Your question is not mate. What do you exactly want to do? If I understand that you have a single phase apparatus you wanted to connect it from a three phase box. If that is the case, then you have three options:
1. If the wires are new colour coded ones then you have to take your neutral wire from the blue wire and the live from any of the other three.
2- for old colour codes , take the neutral from the black wire and the live from any of the other three.
3- finally. Connect the neutral from the black or blue and the live from any of the other three red ones if the wires are in a conduit or trunking. I hope this answers your questions. Good luck
Jan 13, 2015 | Ovens
How to connect wiring
Six one of one, half a dozen of the other; its "neutral."
Aug 22, 2014 | Ovens
My terim cooker has 3 wires - black, blue and brown. Do you know which is live, negative and earth?
green or green and yellow is the ground (earth), blue is neutral, black and brown are both lives. this is the standard european wire color code since 2004. If it is older than that, black was used as a neutral, and blue as a live. very confusing.
Jul 21, 2011 | Ovens
Ive taken element out to replace with new but have forgotten the way the wires went back.there are three spade connections the earth is obvious but not the live and neutral
Hello Ian,
Regards,
BElectric
Apr 18, 2011 | Belling XOU252 Electric Single Oven
I have received an EGO 50.52076.070 energy regulator as a replacement for an old Diamond H 31ER1HT, included was a wiring diagram showing the following connections for the replacement, P1 : Line. ...
Unfortunately the EGO 50.52076.070 is not the correct replacement for a Diamond H 31ER1HT as it does not have a live pilot connection.
Regards Murv...
Dec 16, 2010 | Ovens
I have just purchased a new electric cooker. The old one had three terminals in the back, one each for live, neutral and earth. The new one has three marked live, two marked neutral and one marked earth. I...
Hi.
Nov 09, 2010 | New World 70TC Electric Single Oven
We are having a neff oven U15M62NOGB fitted. The wires in the booklet are earth on the left, live in the middle and neutral on the right. Is this correct as the neutral and live are the other way round on...
Yes, the installation instructions are correct. The wiring from your old oven isn't relevant.
Your query is a little confusing though. The new oven should have a power cable attached to it for connection to the mains supply. This should be on a separate circuit from your sockets and connected to an isolator switch. The wires in the power cable are colour coded to ensure that they are correctly polarised when connecting to the mains supply. I'm assuming you're in the UK as you list a GB model number, therefore, it should have a BROWN wire for LIVE, BLUE for NEUTRAL and GREEN/YELLOW for EARTH.
If your house wiring uses the old red (live) and black (neutral) colour coding, then you just need to ensure that the brown (live) wire from the oven lead is connected where the red wire from the supply is terminated. The blue (neutral) wire should be connected where the black wire is terminated and the green/yellow (earth) wire should be connected where the green wire is terminated.
Internally, the oven probably uses red cable for live and black for neutal, but you really shouldn't need to be doing anything with the internal wiring to install the oven.
You say you are having it fitted. Any competent installer would know (or check) the correct wiring order even if the instructions were missing. If you are installing it yourself, be sure are certain you understand what to do before attempting this and double-check the power for the oven circuit is off before you start.
Please rate this solution if you find it helpful. Thanks.
Oct 16, 2010 | Neff B1421 Electric Single Oven
Neff oven internal wiring colours
red is positive and black is neutral normally on these ovens, dont recall seeing blue and lilac.
Apr 15, 2009 | Neff B1421 Electric Single Oven
Installation guide - bosch hbn131250b
1. The screws seem to need a small hex screwdriver, but I managed to get my normal electrical screwdriver to fit - they are not too tight.
2. The wiring is straightforward - there is an earth position with no wire from the oven attached, marked with the standard earth sign, that should connect to your yellow/green wire. The other two connectors have either a blue (neutral) or a brown (live) wire attached to them - they should connect to your black (neutral in old money) or red (live) wires
Jan 27, 2008 | Ovens
Ovens Logo
54 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
