Question about Sylvania Salus RT500RF
When my remote central heating thermostat is in sleep mode the boiler will occasionally ignite of its own free will What can I do to prevent this.?
I've Changed the batteries and carefully re-programmed but makes no difference
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 484 Answers
Many times the factory wiring on the boiler is set up to maintain boiler temperature with a built-in aqua-stat. The thermostat then controls the circulator pump to transfer heat from that loop to the structure. So, if this is the case, your programmable stat may just be controlling the circulator. There are many, many control AND piping configurations to boilers. Some very different than others.
Posted on Dec 16, 2014
Boiler won't ignite for hot water unless heating is on.
If this is in a RV the propane monitoring valve may require more gas flow to turn on than the water heater requires. A central heating system requires substantial gas flow so when the monitoring valve opens to fire the central heating, there is enough gas flow to also fire the water heater.
Jan 26, 2016 | Water Water Heaters
My Baxi Combi 80e boiler turns the heating on randomly. With the wall thermostat turned down and even with the boil switched to hot water only the heating still fires up when unwanted.
If the thermostat wire run passes anywhere through, beside or inside any metal surfaces and the wires touch any of the metal its the same as if you turn the stat to on. I've seen this a few times. Easiet way to detect it, if its inside the house is at night in the dark. Look around when its doing this you may see the small spark when it goes on. Otherwise you will need to inspect the entire run from the stat to the untis, etc.
Jun 23, 2014 | Heating & Cooling
How do I set the thermostat on my powermax 155 boiler so that the heating comes into action on a lower temperature
You should have a remote heat setting via a wall or on the front of the boiler dependant upon how it is set up. If in doubt as a Central heating engineer to install a remote one you can have next to you wherever you are in the house.
Sep 30, 2013 | Heating & Cooling
Central Heating\which combi boiler?
HI right first i would look at a worcester greenstar combl
best you can get and you have full back up from worcester leave all rads with stats as they are i think you will have to remove one , the that would be the bath room also the greenstar comes with a clock bulit in these are on the worcester bosch web site i have been a gas fitter fot 30 years and this what i would go with a really good combi, you can also get awire less room thermostat for this hope this helps
Feb 01, 2010 | Desa International CBN30T Central Heating...
Bosch Worcester boiler, central heating not working
boiler may need more pressure in system pressurise to middle of green between 0.5 bar and 1.0 bar
Feb 22, 2009 | Bosch Logixx WFT 2806 Front Load...
Thermostat not firing central heating
the stat works using a bi metalic strip so that click you here is making a contact and telling the boiler to call for heating so if you getting no click you need a new room stat. Replace with same model and note the wiring most stats only use 2/3 wires depending on system
Dec 08, 2008 | Dayton Electric Heater
COMBI BOILER /CENTRAL HEATING
the boiler should modulate to controll the radiator temperature but the central heating will go off whilst you are drawing hot water
Nov 13, 2008 | Water Heaters
Heating & Cooling Logo
183 people viewed this question
Top Sylvania Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
Are you a Sylvania Heating and Cooling Expert? Answer questions, earn points and help others
