TV will not hold an installation, channels are saved as long as TV is left on, all channels are lost when switched off!!is it a simple repair?
Several installations, it is not a new TV
    Top Expert:
  • Televison & ... Master
  • 74,377 Answers
Try a hard reset to this set, and check. If it do not help you, the main system control memory IC to your TV is faulty; and should be replaced. To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight; will be better. This procedure will make it a hard reset.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Posted on Dec 14, 2014
I lost all the tv channels on channel master cm-7000 model and do not understand how to get them back?
First look at the indicator lamp on the front left side.
If it is:
off - check the power cord is plugged into a working outlet.
Amber - the unit is in standby, press the on button (left most), it should turn green
Green - the unit is in operate mode, check the antenna and cable connection.
Red - when power is applied, it will be red for up to 30 seconds. If it remains red, the unit is defective. This is a common problem due to several capacitors on the power supply and logic board that have gone bad. The unit is repairable by replacing these capacitors.
Jun 05, 2010 | Digi Channel Master/tal to Analog...
AOC L24H898 LCD TV
Do you have power surge or failure issues with your electricity? Try plugging your TV into an uninterruptable power supply (UPS) to get line conditioning and the continuous power.
Otherwise, I'd guess there is something else causing memory failures (bad chip or something).
I hope this helps.
Apr 21, 2010 | AOC L24H898 24 in. LCD TV
I am in Los Angeles,Ca. Converter box signal problem
Just go to walmart and buy a good digital antena.Should work great.Just rescan all ur channels again.
Mar 11, 2010 | Digi Sansonic FT-300A tal To Analog TV...
I have a Dynatron DYN100Z remote I need to set it for a Symphonic TV . It has worked on this TV before. I lost the code.
1. Turn your TV ON.2. Hold down "Code Search" until the red light turns on. 3. Click the (+) Channel button once each second, until the TV responds by flipping a channel. 4. One the channel changes, press the, "ENTER" button. 5. Code is saved!
Jan 07, 2010 | Televison & Video
Digital channels lost on DVD recorder
I'm delighted to report that all is now working.
I turned the recorder off at the mains electricity supply, left it off for several hours, switched it back on, searched for new digital channels, and it found them all :-)
I had tried this before, but only left it disconnected for a few minutes, and clearly that wasn't enough.
Sep 08, 2009 | Panasonic Televison & Video
Panasonic plasma won't change channel or volume
Also had the same problem with our Panasonic 50" Plasma...could not change the channel or the volume (with the remote control nor with the actual TV controls). Before I called for repair, I UNPLUGGED the TV and then plugged it back after a minute. I was surprised....the TV started working again. (Switching the TV on and off is not sufficient). I could change channels and volume, etc. So this saved me a repair this time. Might be worth trying this solution. Wouldn't hurt one bit, but rather save you a repair fee.
Aug 26, 2009 | Televison & Video
Lost all digital channels - Sony KDL-52W3100
Use ur original remote of the tv u want setup to the DTV box go menu switch cable back to air
reseption.Set tv channel 3 hook up the DTV box and rescan the channels u have it.
Aug 15, 2009 | Televison & Video
Can only receive cable channels 2 through 13;
Turn the unit off, push the setup button 3 times. Press the seek left/right to switch between cable / antenna tuner modes. When cable is selected, press the channel up/down to switch between cable modes. When the unit turns back on, it will rescan for channels.
Aug 04, 2009 | Audiovox VE1020 10.2 in. TV/DVD Combo
I have tuned in my video to my tv but I cannot get the tv station
I had a similar problem. After a nearby lightning strike I lost video to the TV. When the SA-HE100 source switch was set to DVD or TV I lost the TV picture. In my system configuration I send composite video (yellow jacks) to the SA-HE100 from the DVD player, VCR and satellite receiver. From the "TV Monitor Out" jack (yellow jack) the video goes to an RF modulator then is sent to the TV as RF channel 3. At first it seemed the modulator was defective but plugging in another identical modulator damaged the second unit also. This made me look at the amp as the culprit. Curiously, the amp would pass through VCR video without a problem but I didn't know it because of the damaged RF modulator. Whenever the amp source switch was set to DVD or TV the amp would put -4.75V DC on the "TV Monitor Out" jack thereby damaging the connected RF modulator. The repair is relatively simple. The only special skill required is you will need to be able to desolder a 14 pin DIP IC. The damaged component on my amp was IC364 mounted on the board that holds the yellow video jacks. The IC is a JRC 2279D, a 3 input/2 output video switch available from Digikey p/n NJM2279D-ND, $1.50 each.
May 09, 2009 | Panasonic SA-HE100 Receiver
Lost channels on proscan tv
Press the menu button on your remote.  That should give you the main menu where you can go into add/delete channels and do an autoscan to only save channels that are good.
Mar 04, 2009 | Proscan 26LA30Q 26 in. LCD Television
Televison & Video Logo
26 people viewed this question
Top Televison & Video Experts
Electro Med Services...
