Question about Alpine CDA9812RB CD Player
Alpine cda 9812 rb cd player
Hi there, i have the alpine cda 9812 rb head unit, now i have connected it and everything, but the front two speakers don't seem to want to work at all ? i was just wondering what the problem could be ? i connected a friends alpine systme which has the exact same connection to test the speakers and when i put his in the speakers were perfectly fine ? i was just wondering if you can kindly tell me what the problem is and also how i can get it fixed and maybe how much ? kindly please get back to me a,s,a,p either way thanks alot bye !
Re: alpine cda 9812 rb cd player - Alpine CDA9812RB CD Player Car Audio Receivers
Have u checked the fader
Posted on Mar 02, 2009
0 characters
3 Points
Hi there I have alpine cda 9856 cd player and it turns on and does every normal however it won't output and sound on either radio or cd. I have checked for any bad connections and can't seem t
Did you make sure you have no shorted or grounded speakers or speaker wires? Make sure you don't have a bad speaker also. If everything checks out, you may have a bad internal output ic.
Jan 15, 2013 | Alpine CDA-9856 CD Player
Replace my citreon c4 head unit
what year is your car?newer cars 1999 and up the radio wiring harness goes thru the ecm (electronic control module).if that head unit is not supported it wont work a bad case senario the head unit could damage the ecm.
Nov 03, 2007 | Alpine CDA-9847 CD Player
KCA- 420i and an alpine 9854r Can't change the volume for Ipod
There is a small switch on the unit's housing, switch it to "Norm" position.
May 08, 2009 | Alpine CDA-9847 CD Player
No sound from my 9855 alpine
There is an option in the unit itself to turn off the internal amplifier. If you push the 'menu' button, then go to the setup/settings menu, and then i believe it was under the 'general settings' tab. there's a option called INT IC or something. Make sure that is turned on.
Dec 12, 2008 | Alpine CDA-9855 CD Player
Alpine cda-9807 no voice when cd plays.
Try to set the cd function to settings! or menu, maybe you have not fair settings in your unit!
Sep 23, 2008 | Alpine CDA-9807 CD Player
make sure that the acc and ground are hooked up right. acc has to be 12v. if you hooked it up to any other wire it will work until you(turn it up) draw more power than the wire you have it connected to can produce. or you have speakers that are faulty or too big for the alpine head unit.
Sep 18, 2008 | Alpine CDA-9813 CD Player
Hooking up an MP3 to Alpine CDA-9805 head unit
ok when you look at the front of your system there is a button that has a (F) on it press and hold tell stuff comes on the screen then just keep pressing it tell you get to AUX off you should get it from there hope this helps
Jul 23, 2008 | Alpine CDA-9805 CD Player
How to wire a stereo system
Connect the 2 gage to the battery thru at least s 50 amp fuse, then connect the capacitor in line before the amps. Then run the 2 gage to a connector/splitter block and run 4 gage leads to each amp. You also will need at least 4 gage ground leads from each amp to a body grounded bolt or screw. You need to run a quality set of speaker leads from the head unit to the amps. The speakers will need separate leads from the amp to each speaker.You will need to try some different combinations to get the sound and bass you want. You want to be able to fade from front to rear and control everything thru the head unit.
Use a hole saw to cut a 2 to 3 inch diameter hole in the side of the speaker box for a port to get a better punch from the sub.
Hope this helps some....
Nov 03, 2007 | Alpine CDA-7863 CD Player
Alpine CDA9812RB CD Player Logo
429 people viewed this question
Top Alpine Car Audio Receivers Experts
xxxxxx xxx
Jose Velazquez
Jose Velazquez
Jeff Turcotte
Jeff Turcotte
Are you an Alpine Car Audio Receiver Expert? Answer questions, earn points and help others
