Unplug machine
Close both hot and cold water valves at the wall
Get a 5 gallon bucket, disconnect the hot water hose at the machine and place the end of the hose in the bucket
Slowly open the hot water valve to see that hot water flows through the hose
If no water flows from the hose:
close the valve, remove the hose from the valve and slowly open the valve to see that water comes out, if yes, check the hose for screens at both ends and clean or replace them, if no water came out of the valve, get a plumber
If water flows from the hose:
Check to see that it gets hot
If not hot get a plumber
If hot, close valve and check for a screen in the male port on the machine where the hose goes, clean or replace it..
If any screens were replaced or cleaned during this test, remove the cold water hose and do all the same to it, cleaning and or replacing them also, and then reconnect both hoses, open both valves, plug the machine in, and retest to see if you have hot water now
If still no hot, you may call a repair specialist or acquire a repair manual pdf online and test the water inlet solenoid, the water temp switch, and the timer
Note if it is the timer, placing it in a different cycle usually produces different results, so try that, if the solenoid you'll need the proper tools and the skill to disassemble and reassemble your machine, so you may want to call a repair tech
Need more help, or parts try visit the link sight
Search Over 2 1 Million Appliance Parts
