Question about Airvac Vacuums
I have an airvac 525 that came with my new home. Need to know how to take care of it
  • 53 Answers
Change the bag when it is full.
After a couple months, use a cleaning cloth and run it through each vacuum point.
Not much else to do.
Posted on Dec 19, 2014
My airvac av2500 powerhead does not work. I bought a replacement and the replacement doesn't work either.
Test the wiring in your hose to insure the power head is getting the proper voltage.
Jan 09, 2017 | Airvac Vacuums
Airvac wont turn off
the on and off switch is bad
Jul 15, 2012 | Vacuums
No suction from wall outlet. Power to powerhead. Breaker has not been tripped. Manual mode works on cannister in garage. AirVac VM458.
I had the same exact problem and it took about 4 months to find out the problem. I had a paper clip stuck to one of the orifice in the hall way of my house and that is what I had experienced. The other thing is to check the entire tube system because maybe a mouse or rat has chewed into it. It has all to do with the electrical wire throughout the system. Good Luck
Jan 06, 2011 | M&S Systems AirVac AVP1200 Platinum Series...
I just inherited an AirVac AV400. It won't turn on. What do I try? GrampaBigJohn
there is a reset button on it some where near the power switch so I would look for it as it most likely is that simple. good luck!
Oct 07, 2010 | M&S Systems Bagless Central Vacuum
AirVac ZX6000 won't turn off!
There is a relay board inside your unit which is most likely bad. If you have the make and model, you can contact me and I can order the board for you(pending your mechanical abilities). If not, contact your local central vacuum installation company. www.thevacdudes.com
Apr 21, 2009 | M&S Systems AirVac AVP1200 Platinum Series...
Central vac pipe stuffed with pine needles from XMAS!
You can use a Tornado Cloth to clean out your central vacuum piping. Its the simplest and most cost-effective maintenance routine you can do.
You can purchase them from here
http://www.thinkvacuums.com/new.htm#Maintenance
Jan 18, 2009 | M&S Systems AirVac AVP1200 Platinum Series...
Vac running and won't shut off
The first thing I would do is to disconnect the low voltage wires from the unit. Does the unit continue to run? If so, it's probably an internal relay sticking in the unit. You can fix this yourself is you are handy, but I suggest calling your local dealer if you have any doubt. If the unit doesn't continue running, than you most likely have a short in low voltage wiring in your house. Check your inlet valves first by removing the screws and looking behind the faceplates. If you have inlets that are powered with 110v for you power nozzle (Supervalves, or Electravalves), be very careful as you could be exposed to 110vac. Check your vacpans too, if you have any. The wires should not be touching anywhere. If the two wires touch, the machine should come on. Good Luck!!
Dec 19, 2008 | M&S Systems AirVac AVP1200 Platinum Series...
Vacuums Logo
64 people viewed this question
Top Airvac Vacuums Experts
Are you an Airvac Vacuum Expert? Answer questions, earn points and help others
