How do i remove coins from pump - Washing Machines
  • 32 Answers
F you know they are in the pump, you also know where the pump is. Now some machines have a simple clip or clamp arrangement to access the impeller. Others have to have a few screws removed. Either way it is a simple matter to fix but.................you must disconnect the power cord from the socket while you are under the covers!!!!!!!!!!!!!! Remember, water and power and stupidity do not mix well.
Just remember the reverse sequence to put it back together. Do make sure that the coins are not caught in the filter. Some front loaders have a strange access to the filter under a flap in the drum.
If this is working as it should, the coins should not get to the pump. If the filter is broken, get a new one.
Posted on Dec 14, 2014
I found coins in pump and removed but still not draining correctly
If all obstructions are removed, and still doesn't drain, replace pump.
Sep 05, 2017 | Whirlpool Cabrio WTW6600SBT Top Load...
Tip
Washer Repair Boise - Whirlpool Cabrio Pump
I've replace many pumps on the whirlpool Cabrio and most of these washer pump failures could have been prevented by removing coins from pockets. Many times coins will make there way to the outer tub and get sucked right into the pump to create a rattling sound. That rattling sound you hear is the impeller spinning against the coin. Since the impeller is plastic, it doesn't take long for the impeller to wear down. Just a tip, please remove coins from pockets. You'll save money and time :->.
A tip from Western Appliance Repair
Washer Repair Boise
on Oct 12, 2010 | Washing Machines
Error code 20
Is it an E20 error code? The E20 error code is usually something clogging the pump system follow these steps to check. From the bottom and back panel you can access the drain hose/pump/coin catch. With a pair of pliers you can remove the clamp holding smaller end of the rubber coin catch to the tub, with a Phillips screw driver you can remove the larger clamp of the rubber coin catch to the tub. From the back panel you again use your pliers to remove the clamp to the drain line, and finally with a Philips screw driver remove the two screws holding the pump to the bottom of the washer. Oh yes, do not forget to unplug the wire from the pump. Now pull the pump out with the black rubber boot still attached. Mark the orientation of the pump to the boot with a sharpie pen, and remove the last clamp. Now look inside the black rubber boot and gently remove the plastic basket inside and remove any thing that does not belong, reassemble ant test.
Nov 25, 2013 | Frigidaire Washing Machines
Coins end up in the drain pump and take out the impeller fins. I replaced the pump but heard more coins in the pump. Took the pump out removed the coins and reinstalled the pump and works great. How do i...
try and check your clothes before putting them into the machine. and ensure all pockets are clear of debri before starting the wash, i dont think there is a screen device or filter hose that you could get to help so my first suggestion is the best one i have, best regards
Oct 30, 2013 | Samsung WF337AA Front Load Washer
How to remove coin and debri from tub of whirlpool cabrio 6800
Go on utube and search for this issue. It will show you how to disassemble the machine and get to the problem spot. Easy to do just did it last week. Stupid design flaw
May 26, 2012 | Whirlpool Cabrio WTW6300SB
Will not drain and stops but does not give an error code.
Check any pump filter and outlet hose for blockages, if all is ok check pump.
I hope I have been of help but please do not hesitate to ask if you have any further questions.
I appreciate your vote if you appreciate my reply and remember, even if you don't vote for me a please and thank you goes a long way
Mar 06, 2011 | Maytag Neptune Washer
I have coins down in the tub causing loud noises during drain. What is the best way to get them out?
I have the same problem with my Cabrio, coins sneak into the ejector pump. They make a heck of a racket when the machine drains.
You need to:
1) Disconnect the plug and the hoses.
2) Tip the machine forward, it's easier to work on. Put the styrofoam shipping ring back in the tub, it keeps things from rattling around.
3) Take the back off.
4) The ejector pump is at the bottom right (as seen from the front.) You need to remove the discharge hose, it's held on by a spring clamp. I've found that vise grips work well for this. Slide the clamp up the hose, then pull the hose off.
5) Remove the clamp from the front of the pump in the same way.
6) Remove the pump. It's held by 3 screws, then pull the pump off the input hose. Tip the pump down, the coin should fall right out.
7) Put the hoses back on before screwing the pump back in. The hoses have an index mark that match up on the pump so you can't put them on crooked.
8) Put the back on.
9) Wonder why Whirlpool left a space big enough for coins to drop through, and really search the pockets when you do the wash.
Sep 19, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
I have a Maytag Neptune TL washer that won't drain. I took the front panel off and detached the hose from the pump and there were several coins in there. I removed the coins, reattached everything and...
For the FAV6800A or FAV9800A tumbler removal.
The Service manual has the procedure starting on page 37 for the tumbler removal.
It’s not difficult to remove the manual doesn’t call out the Torx driver size required for tumbler removal. You will need a number 20 Torx driver to remove the Torx screw for tumbler removal. I would get a long Number 20 Torx driver for this. See page 37 of the Service Manual for tumbler removal. Looks worse than it is.
The Service Manual for reference. Sears Parts Direct for reference.
When I did a recent Outer Tub Bearing replacement I found $1.78 in coins after removing the wash basket. Gotta check those pockets....:)
I have a post around somewhere of my diy Sump Screen I put in my FAV6800AW to protect the drain pump impeller from coins and other stuff from breaking the impeller or causing clogs. I'll look for the post or repost the pic's.........D*ick
Sep 11, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Washer doesn't drain just buzzes
Most likely you have a coin stuck in the drain pump. Mine did the same thing, and we removed the drain pump, then removed the coin and it began working again. Just be sure to check all pockets for coins as this is a big problem with the Cabrio washers.
Oct 11, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
A loudgrinding that sounds like gravel is in washing machine
I have had this same problem, coins get in the discharge and recurculation pumps. Tip it on its front side remove pumps 3 screws each, unplug wires remove 4 phillips screws and remove black housing off pump and clean,reassemble. Don't forget to check outer drum for more coins.
Nov 17, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Washing Machines Logo
44 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
