Question about Kenmore Refrigerators
How do I remove ice and water dispenser from a Kenmore Elite refrigerator model 795.72043.110?
  • Kenmore Master
  • 744 Answers
Hello Nelson;
My name is Peter. I am a retired field service refrigeration technician.
Most of the components to be removed are secure with plastic pop out tabs. Look under the bottom of the front cover, there may be a screw on each side in addition to plastic tabs. With a small flat head screw driver pop the cover off. Be careful these tabs are easily broken. Ground yourself by touching something metal. Static electricity will knock out a control board.
Go into the following website. Type in your model number. You will get an exploded view of your dispenser. Water Filters Lawn Garden Appliance Parts
Posted on Dec 14, 2014
Kenmore Elite side by side 106.4442 603. Out of power for 24 hrs and after that the ice dispenser doesn't work properly. It makes ice and dispenses water but no ice is coming out. Could it be a frozen...
During the power outage im sure some of the ice melted and then refroze into a big block in the ice bucket did you remove the ice bucket and empty all the ice from it?
Aug 24, 2011 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
No water coming from water dispenser.
It is possible the water control valve for that dispenser has failed and will not open. This happens a lot for those and the ice maker valves. All you need is the model number for your refrigerator and that will look like this for Kenmore. 213.564897 for example. and I will help you find the correct part number. Sea Breeze
Nov 24, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
I have a kenmore elite model number 795. my ice dispencer only gives crushed ice even though its set to cube
1st i would remove all ice out of bin, clean outBIN with warm water under sink. put ice back in do not throw away for testing purposes. if worked then a cube may have been caught in bucket chopper improperly . if didnt change anything could be a bad crusher solenoid. in home service could run you 90-145 dollars depending where you live. if you do it yourself crusher dispenser solenoid will run about 30-50 DOLLARS. hope this helps
Sep 16, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore Elite refrigerator ice and water dispensers not working
check for a child lockout button it will look like a tiny padlock ,press and hold for 3 sec.(could be the freezer door light switch)
Jul 24, 2009 | Refrigerators
Hi, i have a kenmore elite side/side w/ice maker and water disp
take a blow dryer( nothing else) and put it on high.
you can have some trapped ice or even some food. get a flashlight and take a look. use tongs to remove anything!
Mar 18, 2009 | Refrigerators
Replacing water fitting assembly
water dispenser continues to run too long after removing glass
Oct 23, 2008 | Refrigerators
Ice and water dispenser lock light stays on and comes back on quickly after pushing and holding. No water or ice dispensed while light on. Kenmore Elite 23.1 ft side by side refrigerator
I resolved the problem on my Kenmore Elite model 106.55616400 by removing the drip tray, taking out two screws that hold the panel, and disconnecting and reconnecting the wires from the panel to the board. Unplugging the refrigerator did not work.
May 28, 2008 | Kenmore 25.1 Side-By-Side Refrigerator...
Kenmore elite (106.53606202) ice maker will not dispense ice
When you push the ice dispensing lever, you should be able to hear the micro-switch clicking. If no click, the switch is faulty. The auger motor which is activated by the lever could also be faulty. This is the motor that causes the auger in the ice bucket to rotate one way for crushed ice and the other way for cubes. The auger could also be jammed. Try switching between crushed and cubes to unjam the auger. Empty the ice bucket and start again.
Nov 02, 2007 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
New Kenmore Elite ice dispenser not working but water is
Should be no longer than 24hrs. Is the freezer good and cold.. has to reach a certain temp before icemaker activates. Might take little longer if you put a lot of warm things in freezer or refrig. when you made the change. Is there any water or ice in the icemaker itself? Water may not be getting to icemaker call them back out if it dont work soon thats what warrantys for :0)
Sep 02, 2007 | Whirlpool ED2FHEXN Side by Side...
Refrigerators Logo
76 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
jackdo2
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
