SOURCE: radio wiring color codes
u need the colors of the radio or the car wires.... here are the car wires and the radio are below that. I suggest however gettiing a wiring kit..They are around 8 dollars and well worth the money. It makes is so easy to connect a radio.
RADIO 12V|orange + at radio
RADIO GROUND Black
RADIO SWITCH yellow
POWER ANTENNA dk. green at radio LF SPEAKER tan - gray at radio or LF speaker
RF SPEAKER lt. grn - dk. grn at radio or RF speaker LR SPEAKER brown - yellow at radio or LR speaker
RR SPEAKER dk. blu - lt. blu at radio or RR speaker
Radio wiring
constant power yellow
switched power red
power antenna/amp turn on blue
illumination is orange
all speakers the one with the black stripe is the negative connection.
right rear is purple
left rear is green
left front is white
right front is grey
hope that helps ya...
SOURCE: Locked renault clio 2001 cd/radio player!
to enter your code when the cd player displays error leave cd player switched on and after 20 mins or so i will display 0000 then you will be able to enter your code this happens when some 1 has entered the wrong code
SOURCE: hyundai cd player security code
take your registration and photo id to the dealer and ask if they will give you the code. they should do this free of charge. best of luck
SOURCE: Safe mode in Audi Symphony radio
hold rbds and pscan till you see numbers then use the radio memory buttons to control the number you want to put in after the numbers are put in hold rbds pscan again till u see it says safe and radio works.
SOURCE: Need Toyota radio security code
Oribeeboy is spot on for a 100 series Landcruiser - last 3 VIN numbers.
Let's say the last 3 VIN Nos were 264
Turn the ignition key so that the radio displays "SEC"
then: press "TUNE"and press No1 button on the radio at same time
then: press No1 button 2 times
then: press No2 button 6 times
then press No3 button 4 times
Finally hold the "SCAN" button to confirm the code. The radio will then turn itself off. You can then turn it on in the normal way.
(Hopefully!)
