Question about Ryobi Bs902 Bs903 9" Band Saw Replacement Belt
How do i fix the power switch on my ryobi and how is it connected
I tried putting the wires together but don't think I have them put on there correctly
    New Friend:
    Problem Solver:
  • 5 Answers
Get anew switch, and connect the same as the original switch was connected.
Posted on Dec 25, 2014
My ryobi bst10 table saw stopped working. The switch appears fine. I am wondering if the overload protector could be a problem. The little button seems loose?
I'm having the same problem only mine is bran new and has only been turned in one time when I put it together it worked then now the switch is lose and does not make a clicking sound what is wrong with mine
Aug 22, 2012 | Ryobi Saws
My amp will turn on and even when I have the guitar and amp connected no sound comes from the amp. I don't know what to try to fix it, so I have left it alone, testing it every once in a while (it...
Possibly a loose connection, or bad solder connection. unplug it from power.
If you think you are up to it geta soldering iron and some solder, and a screwdriver, and take the amp part out. be careful of the speaker wires. put some tape on each one and label them so you know where to put them back. after you got it out you might have to take some more screws out to get the board off of the chasis, so you can see under it. this is where all the components are soldered to the board. maybe use a magnifying glass. touch up anything that looks questionable.
do all over. you don't need to know what everything does if you just go all over. careful not to cause any shorts. you might see something that obviously needs to be fixed. you have found a problem. you can't fix something if you don't find a problem. do all over anyway if you think you still have to.
Put it back well enough to test it. then put it all the way back together, or continue to look for a problem, or take it to someone, like me!
Good luck
PLEASE RATE THIS ANSWER
Aug 23, 2011 | Marshall MG15DFX 15 Watt Compact 2...
Bike cuts out when i put it in gear,,,,,,,,,,,,1990 xt 600
Might be a problem with your side stand switch, if the bike thinks the stand is down then every time you put it into gear it's going to cut out. Try manually operating the switch. You can also disconnect the side stand switch and connect the wires on the loom side directly together in case the switch itself is faulty and can't close the circuit to allow starting.
Feb 21, 2011 | 1990 Yamaha XT 600 E
This unit comes with a Four Conductor Cable to hook up power in. How are these four conductors hooked to power?
Disconnect the battery. Connect the green wire to the Negative terminal.Put a 20a fuse inline on the black wire and connect to Negative terminal.Put a 20a fuse inline on the red wire and connect to Positive terminal.
Put a 1a fuse on the yellow wire and connect to ignition switch - if you don't want to use the Ignition Sense feature, connect the yellow wire to Positive terminal.Re-connect the battery and test.
Nov 11, 2010 | Motorola VC5090-MA0QM0GH6WR Wireless...
We just bought a house and the living room has a light fixture and there is a dimmer switch that controls it. I removed the light fixture and installed a ceiling fan but the fan barely moves and the light...
You're correct. The dimmer switch was not made for that fan.
The Green is ground > so you're right there too. I assume other plugs nearby are working when dimmer is on. Check that to make sure.
By your description, I assume there is NOT another switch or dimmer that connects to same light. If so, you need a 3-way switch and the following instructions are void.
I suspect when you wired the new fan, that you saw the red and small black wires in the ceiling box. Did you connect the fan and light to those wires? If so, the following information will help you wire the switch.
Your incoming Hot line is probably the larger black wire that connects to Dimmer black >>> this wire will connect to either screw on the new switch
To test Hot wire for sure: Take out dimmer and mark wires for identification. Separate wires. Turn on power and test each wire to bare ground. Tape tester leads to wood sticks so hands are away from power. You'll be fine. Tester lights up on Hot wire.
Next: The smaller black and a red wires are a toss up.
Here's how I would proceed. Connect the black Hot to either screw on switch. Connect red wire to other screw. Put wire nut over small black. Turn on power. Flip switch. Check both lights and fan to see which works with red wire.
Next reverse the toss up wires. Put wire nut over red. Connect small black to switch. Check both lights and fan.
If red and small black control the light & fan, then connect them together on the same screw, and you're done.
If you want to control the fan and light separately, buy double switch, and then Hot connects to dark-colored screw on one side of switch, and red and small black connect to two different screws on opposite side of switch.
Oct 04, 2010 | Solar 10 Eagle Almond Commercial Double...
My 2000 Durango electrical/wiring problems...
The power lock problem is definately the electric lock actuator in the door. Replace it.
The power window problem could be the switch or the motor.
Put a test light on the motor connections. Operate the power window switch up and down. If the light works both directions, then replace the motor. If the light only lights one direction, then replace the switch... and you still might have to replace the motor afterward so do not think that replacing the switch is absolute. They sometimes fail together.
Mar 21, 2010 | 2000 Dodge Durango
Pwer led,resetsw,hdd led,pwer sw
It appears your board is made by Jetway.
Heres your link for the manual:-
http://www.jetway.com.tw/jw/downloadshow.asp?productid=V266B#
You can also download drivers et,c. from the same site.
Please don,t forget to rate the Post.
Best wishes mike @Compurepair
Mar 29, 2008 | Intel Motherboard
Ryobi Bs902 Bs903 9" Band Saw Replacement Belt Logo
98 people viewed this question
Top Ryobi Saws Experts
enb54
Level 1 Expert
Jim Thurston
Are you a Ryobi Saw Expert? Answer questions, earn points and help others
