Question about AEG Microwave Ovens
Crunch tray for AEG micromat_duo
Looked on line
2 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: aeg micromat duo crunch microwave oven, all
That is not that hard to fix and you can easily buy the parts yourselfonline...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
heatman101
Posted on Nov 12, 2010
Aeg micromat 153e
You rather have a bad turntable motor or a stripped turntable coupling.
Jun 22, 2014 | AEG Microwave Ovens
Aeg micromat duo crunch microwave oven, all functioning but not heating anything
heatman101
Nov 11, 2010 | GE Microwave Ovens
Micromat oven removal from built in cabinet
Usually the screws are on the side behind the door so you must first open it. If your oven fits well and does not move it is possible that there are no screws.
Sep 09, 2009 | Microwave Ovens
I have a AEG built-in microwave oven that im trying to uninstall from the cabinet but cant seem to find the means to remove the mounting frame that is fixed to the face of the kitchen cabinet.
1st: Dont listen to the so called gurus at FixYa. As the guru there was telling me that the frame was glued to the cabinet. If I would have followed his recommendation Id be buying new cabinets as well as a new mounting frame. FixYa should credit me my fee paid.
The solution: For the built-in cabinet AEG microwave oven, it is required to use the AEG mounting kit. The AEG mounting face frame uses for screws, one at each corner concealed by small black plastic caps that blend in perfectly with the contour of the mounting face frame. If you look closely towards the inside of each corner you'll see a very small slot in the cap that will allow you to put a small flat head screw driver into the slot to work the cap out. Once the four caps are removed use a phillips screw driver to remove the screws that fix the mounting face frame to the cabinet.
Aug 28, 2009 | AEG Microwave Ovens
My AEG Micromat_Combi microwave has started coming up with an E14 error message, have you any ideas please.
The motor opening some air valve is probably stuck. See "AEG “micromat_combi 635” halts with error E14. What to do?" at http://appliancewiz.com/questions/47/aeg-micromatcombi-635-halts-with-error-e14-what-to-do for some images and instructions.
Oct 31, 2008 | AEG Microwave Ovens
Hi. I pressed the 'quickstart' button on my micromat 900 w microwave and used it for 10 seconds. On pressing the 'door open' button, the display panel is showing '1' rather than the cooking time or the...
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for maybe an hour. Then let us know if the hard reset does not fix it.
It may be a problem with a door switch or door switch mount.
Sep 28, 2008 | AEG Microwave Ovens
ENLIGHTENMENT ON AN ERROR CODE
The first thing to try is a "hard reset". Unplug it from the power line for a few minutes, plug it back in, set the clock, then try again.
Otherwise, your best bet is to contact AEG customer service here:
http://www.aeg-electrolux.co.uk/node137.asp
I'd bet that customer service will not know the meaning of the code (if it's not in your owner's manual) and they will steer you to a service center.
The service center will probably not tell you what the code means, preferring instead to repair it for you.
Good luck.
We're happy to help and we appreciate your thoughtful rating of our answer.
May 26, 2008 | AEG MCC663 Microwave Oven
Microwave Ovens Logo
35 people viewed this question
Top AEG Microwave Ovens Experts
William Miller
William Miller
Kazim ERGUNEY
Kazim ERGUNEY
Raj Patel
Are you an AEG Microwave Oven Expert? Answer questions, earn points and help others
