Question about Electrical Supplies
Need a wiring diagram for fuel injector harness for 1987 F-150 4.9 inline 6 motor
Wiring diagram for 1987 Ford F-150
  • 2,720 Answers
Hello Chuck Burdine,
Your answer (close 1988) awaits at the bottom... When I don't have an answer... I wait out the world... until I find it...
(consequently I have a couple of beautiful cars 20 years waiting for proper attention (yeah... stubborn)).
Maybe this will help.. BBB Industries (below: bbbind.com)
I found your UNANSWERED question...misplaced in wiring...
Loving house and cars... (both: I don't care).
I thought this one might finally deserve an answer...
My VERY BEST RECOMMENDATION FOR YOUR vehicle's
reference documents are the $100- $150 (new paper bound volumes... much cheaper on CD... but I don't like them,)
FACTORY+WORKSHOP+MANUAL... (Volume 3 (electrical)).
I used to have an awesome master mechanic... AND the worlds foremost parts authority (from Cirimele Ford (Oakland, Ca.))...
In 1970... before restoring '65 Mustangs was popular... these guys helped me pull ALL the right PARTS &Techniques.
AFTER that I had to buy the books...!!!
Hope this helps you... 34 Technical service bulletins, and exquisite circuit drawings!!
http://www.bbbind.com/free_tsb.html
also look at:
CHILTON BOOKS 26664 Repair Manual Ford F150 F250 F350 Super Duty Bronco 87...
https://www.tzarmedia.com/signup?ad_domain=ads.ad-center.com&ad_path=%2Fsmart_ad%2Fdisplay&prod=2&ref=5044641&q=1987%20Ford%20F150%20Truck%20Wiring%20Diagram&seed=3410948014&utm_source=bocdoo.com&utm_medium=referral&placement=http%3A%2F%2Fbocdoo.com%2Fdownload%2F1987-ford-f150-truck-wiring-diagram.pdf&adserver=0.18.4-rc1&sf=eone&m=books&sfv=11&_sign=6489ea2c7e86986d18e01f555e247d26&_signt=1460064133
87 ford pickup wiring volume 3 Bing images
Posted on Apr 07, 2016
What are the fuel injector wire colors for a ford escape 2008 3.0L v6 4wheel drive?
Okay, you know each injector has a power wire, and a ground wire that goes into the pcm? All of the power wires to all six injectors is a green wire with a red stripe.
The ground wire colors are as follows:
inj 1: green wire/blue stripe.
Inj 2: gray wire/yellow stripe
Inj 3: violet wire/gray stripe
Inj 4: yellow wire/orange stripe
Inj 5: brown wire
Inj 6: green wire/white stripe
I should note that the wiring diagram I am looking at shows this diagram as from a 2008 model manufactured during 2nd quarter of the year 2008. If your injector wire colors are different than as listed above, there may have been production changes during the year. But the power wires to all six injectors would still have the same color wire. You could figure it out that way: in other words, looking at the injector harness, same wire color to all six is the power wire, all the odd colors are the ground wire for that injector. Hope this makes sense to you. Good luck.
Feb 03, 2015 | Ford Cars & Trucks
Cleaning injectors on 4.9 ford inline six
You can have them professionally cleaned, but I have made a wiring harness with an injector plug from old harness, sealed pushbutton switch, and battery clips. Remove injectors, one at a time hook up and breifly energise injector and use carb cleaner to back flush injector. This will clean the screen filter and usually restore normal operation. CAUTION carb cleaner spray is flammable so all wiring and switch must be no sparks.
Jan 28, 2015 | Ford Cars & Trucks
Wiring diagram for injector harness for 1987 Ford f-150 4.9 inline 6 engine
http://www.autozone.com/repairinfo/repairguide/repairGuideContent.jsp?pageId=0996b43f8038ecd6
Dec 06, 2014 | 1987 Ford F 150
Fuel injector diagram
old post
no engine stated, ?? which one? 4AFE or 7Afe (TOY ENGINE)
the harness will not allow cross wiring injectors
how did you do that?
the #1 injector is on #1 cylinder
and on #1 fuel rail port.
the #1 cylinder on inline engines, the crank pulley end.
if you need wire colors, we can do that too.
or log in to mitchells DIY and read. that.
here is the 7aFE wires
B-O is 12vdc power key on, the ECU fires the 4 on right.
23865545-flsdwf0rx41rbdaez4cmhnol-2-0.jpg end old post day.
Mar 19, 2014 | 1993 Geo Prizm
Where is the ground wire on 87 535i fuel injector
There are many Ground Wires.. Adding another Ground is the easiest thing to do...
Apr 10, 2013 | Cars & Trucks
Fuel injectors
there are three bolts holding the fuel injector rack down. remove them and they should all come up with it. before doing so, releave the fuel presure from the system. unplug the injectors and install the new ones with new seals. make sure the injectors are all seated properly and reinstall the three retaining bolts. good luck
Nov 27, 2011 | 1988 Ford F 150
1996 ford full size bronco, 302 engine, starts and runs fine, under power it bucks and misses and has no power. let off gas and is ok again. A test shows a misfire on the #4 cylinder. The plugs, wires and...
Is this a 4.9L engine? An inline 6? My database doesn't show a 4.9L in that model year. It does show that engine in 95.
Did you visually check for spark at number 4 cylinder?
For 95-- 4.9L--fuel pressure--50--60 psi. Use a gage and check proper fuel pressure. Also, see if fuel pressure will hold for a bit with everything off.
Fuel--spark--compression. Some ford makes and models, ford can disable the fuel injector, if misfire is detected. I only mention this because, swapping injectors may not be conclusive? You can check for fuel injector pulse, anyway.
How long since over-all tune-up? You did get a new fuel filter, if inline filter, correct?
Jul 28, 2017 | 1996 Ford Bronco
I have an 89 Jeep Wagoneer inline 6. Its not
You got the ignition cover, what you need to do an cylinder compression test and also check your injector for voltage while engine running hook test light to battery pos on neg and neg on pos, at injector harness check for pulsation, if you have pulsation elec. system ok, if good compression bad injector.if bad compression piston ring's or valve's.
Dec 08, 2009 | 1989 Jeep Grand Wagoneer
Trying to find online: Injector Wiring Harness Diagram
Give this a shot.
http://pdfdatabase.com/index.php?q=ford+6+0+fuel+injector+diagram&filetype=0
They were the only place I could find that had the files, but I didn't download since I don't currently have the software to view .rar files, and didn't care to download it (also free).
If that doesn't work, you might have luck asking on www.thedieselgarage.com or www.oilburners.net . Good luck
Nov 07, 2009 | 2004 Ford F350
1998 ford motor swap 8cyl to a six inline
Unfortunately, You will need to Change it all. None of the V8 Components will Transfer to the Inline 6. Please Rate My Response! Thanks!
Feb 02, 2009 | 1998 Ford F150 Regular Cab
Electrical Supplies Logo
745 people viewed this question
Top Electrical Supplies Experts
ken skalski
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
