Question about Bosch HDS181-01 18-Volt Cordless Compact Tough 1/2-Inch Hammer Drill
BOSCH 1/2 IN 18 VOLT CORDLESS HAMMER DRILL - Bosch HDS181-01 18-Volt Cordless Compact Tough 1/2-Inch Hammer Drill
  • 101 Answers
SOURCE: Broken Forward/Reverse Switch on Bosch Model 1198VSR Hammer Drill
Yes .. should find it here http://www.toolpartsdirect.com/bosch-tool-parts.html
Hope this is Helpful ! Thanks
Posted on Dec 16, 2008
SOURCE: bosch 18volt brute force cordless drill how do i remove chuck
Put the screw back in the chuck, tighten it up then back it out 1 turn. Take a punch, put it in the chuck and give it a quick hit with a hammer. That should do the trick.
Posted on Jan 31, 2009
comax
  • 154 Answers
SOURCE: Bosch 11247 Hammer drill works
Usually replacing the o-rings on the piston, striker and Impact bolt will solve any hammering issues. That is considering there is no damage to the mechanical parts in the hammer mechanism.
Posted on Apr 13, 2009
smjdragonfly
  • 79 Answers
SOURCE: Bosch VSR 1199 hammer drill keeps slipping in hammer mode
Inside there is a little plastic shaft, where the selector hooks to. They have had problems over the years stripping. Replacement part is still plastic. Yay! You may need a bearing puller or find some way to get the clutch off the shaft. Lemme know. Please rate me
Posted on Jun 18, 2009
  • 211 Answers
SOURCE: Bosch GBH 2-20 SE hammer drill stopped working
hi
check the cord and the switch to have continuity,the wires,the brushes,the rotor and stator.
regards savumihai71
Posted on Dec 16, 2009
Will only run in very short bursts useless
Battery is no good and will not charge properly. Replace it.
Nov 11, 2015 | Bosch HDS181-01 18-Volt Cordless Compact...
My new bosch cordless drill chuck doesn,t have a screw in it how do i remove the chuck ?
Dear Fred,
Please go to Replacement Parts in the link provided below. Too replace and remove your drill chuck on a cordless drill.
How to Remove Drill Chuck
Fare Well
Feb 07, 2015 | Bosch 13618 - 2G 18V Brute Tough Cordless...
Broken drill bit stuck inside drill
if you open chuck all the way the drill bit should just fall out
Dec 11, 2013 | Bosch 13624 24V Cordless Hammer Drills
Bosch drill dosent work even when i charged it only used about three times
Hi , try and find proof of purchase ( receipt/credit card statement ) and contact your local Bosch service centre ,in most cases it will be repaired under warranty .
Hope this helps
Mar 12, 2010 | Bosch 13624 24V Cordless Hammer Drills
My 24v cordless drill is working ok but the switch on the side of drill for turning hammer on and off is missing. what spare parts do i need to get. would it just be the switch hopefully nothing else fell...
In order to switch from hammer to non hammer on the 13624 there is a ring on the clutch near the chuck. The button on the side is for switching from forward to reverse. The part number you will need is 2601099112. This is something that happens quite often on these drills and you may consider getting two. They are less that 5 dollars each.
Jun 18, 2009 | Bosch 13624 24V Cordless Hammer Drills
Bosch 18volt brute force cordless drill how do i remove chuck
Jan 31, 2009 | Bosch 33614-2g 14.4v Brute Tough 1/2"...
Bosch HDS181-01 18-Volt Cordless Compact Tough 1/2-Inch Hammer Drill Logo
397 people viewed this question
Top Bosch Air Tools & Compressors Experts
John Trevino
Jim Goldsmith
Jim Goldsmith
Are you a Bosch Air Tool and Compressor Expert? Answer questions, earn points and help others
