Press the top or bottom of the circular dial button to select HIGH, MIDDLE, LOW or OFF .... while SPEAKER has not been pressed and a document is not loaded in the feeder.
The ringer will ring once at the selected level.
Dear Sir .
Currently your mobile ringing tone is set at low ringing volume level.Thats why you are facing this problem.To increase your ring tone sound follow these step :
Select Menu > Settings > Tone settings and from the available
options:
Select Ringing volume . Set Ringing volume to level 2 or above, your phone rings with the volume ascending from level 1 to the level for incoming calls.
I hope this will works for you.
Regards.
Rizwan.
The ring tone volume on the X1 is not very loud you will just have to choose a loud ring tone that will catch your attention. Have you tried putting both the phone and ring tone volume up by pressing the speaker symbol at the to of the screen and putting both sliders up full.
Solution: Contact local phone company to check the telephone wall jack for low ring voltage.
Ring-in Voltage
Facsimile equipment?(fax machines), like other telephone anwering devices, require ring voltage at a telephone jack to answer automatically.? The ring voltage is one of the services provided by the local phone company.
Low ring-in voltage can cause short bursts of ring tones at the phone jack.
Callers may hear one or two ring back tones and then ringing will stop and nothing else will be heard.
Inside the home, the called party will hear a brief ring and then nothing else will be heard. If the telephone handset is lifted, the caller may be on the other end.
To check if the fax will not answer due to low ring-in voltage, do the following:
Disconnect the fax at the telephone wall jack.
If an answering machine is available, connect it directly to the telephone jack. If an answering machine is not available, connect a telephone to the telephone jack.
Dial the fax line and see if the answering machine answers the call, listen for uncommon ring tones inside the home or check for similar symptoms as described above. If any of the above symptoms occur, please contact your local telephone company.
I think i can help you. The problem I'm having is that the alarm tone is too brief an too low. So brief that it doesn't come close to waking me up. Try this, Have someone send you a ring tone or some thing u want to wake up to. Within the message there is an option that will let u save the sound in your documents or ring tone folder. Try both. An hopefully when you set your alarm tone it will allow you to set the music, sound you just saved. If that doesn't work the HTC website has a trouble shooting section. I think it addresses this problem. Good luck i hope this helps
