Question about Zanussi Refrigerators
Alarm does not come on when the fridge door is left open on frigde freezer
Alarm does not come on on my fridge freezer
    Champion:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 215 Answers
Alarm probably frozen, leave door open to let heat in to melt ice, the remove device.
Posted on Dec 14, 2014
My Miele Fridge Freezer Keeps Beeping Although there is no issue, how do i remove the alarm?
I bet the light is also staying on inside even if the door is closed. There is a switch inside that turn the light on and off when the door is open. If the (Door Switch) is working then the light inside should shut off when the door is closed to save energy. It also tell the computer the door has been shut in case you forget then it will notify you. The switch may not be working. Look for a door with on ebay or sears. Need your model number and brand of the unit.
Sep 20, 2016 | Miele KFN8762SDED Bottom Freezer...
Refrigerator section stopped cooling, but the freezer section still works.
Hi. There is a valve in the top corner of the frigde that controls the cold Air to flow from the freezer to cool the fridge. This valve called a damper closes when the door is opened. You have to depress the door switch and listen for the fan in the freezer to switch on then feel for cold air to flow into the fridge compartment. The fan could have failed or the damper valve could be stuck closed.
Jun 05, 2016 | Maytag MFF2258VE
Beeping alarm every 6 hours like most posts here, top of fridge not getting cold enough10C ... but
beeping alarm every 6 hours like most
posts here top of frigde not getting cold
enough10...but
Jul 13, 2013 | Fisher and Paykel Active Smart E522B...
I need to repair my GE profile refrigerator
The first thing you need to determine is if the compressor is coming on. If it isn't then the problem is in the lower section, PCB, start relay or capacitor or compressor. If the compressor does come on, then it sounds like your main board is the problem.
Jan 19, 2012 | GE Profile Stainless Bottom-Freezer...
Alarm sounds on fridge, not cooling
is it a bottom mount machine,freezer on the bottom?if the door doesn't close all the way and the alarm is on this could be your problem,the warm air gets in and freezes up the air ducts.look on the ceiling of the freezer and on the lite,if there's ice or like snow there the door was left open.also check the inside back wall of the freezer,touch it and see if there's any ice or like snow on the inside back wall,you could have a defrost problem or like i said before the door could be stuck open,look for frozen water droplets on your food packages or on the ceiling of the freezer,if so shut down the machine,pull out the food in the freezer and with a hair dryer heat the back inside wall of the freezer for like 15 to 30 minutes,turn it on,if you can feel cold air blowing into the fridge section you should be fine,you might have a package or i've seen people install the door draw in backwards and the alarm will go off because the door isn't closing correctly.let me know what you find and where the alarm is coming from,the freezer or the fridge side.good luck and happy holidays to you.
Dec 23, 2011 | Refrigerators
Water dispenser isn't working and door alarm isn't sounding when door is left open
Easy one. The fridge computer has crashed. Remove and reapply electricity to fridge (via the circuit breaker).
Jan 12, 2011 | General Electric Profile PGCS1PJX Bottom...
Alarm no longer sounds when fridge door is open
Chances are that you will have to replace the buzzer. That part is available at Sears Direct. J
May 28, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
I have a Kuppersbush fridge/freezer (freezer in the bottom), model IKE 459-4-4T, and the fridge is not cooling. The freezer is working fine.
you need to check the evaporator fans and see if they are running. when the unit is in the cooling mode open the door and hold the switch in both the freezer and frigde and listen for the fan if you do not here it one or both need to bee replaced make sure there is no ice build up that would block the air flow.i hope this helps.good luck
Jan 22, 2010 | Refrigerators
Can't get alarm to turn off while temperature stabilizes
My wife solved it for me :-) You turn the alarm off with a switch at the bottom. The alarm turns off, but the light stays red for another 4 hours. After that the red light goes off too, and you can turn the switch back on without the alarm going off, if the freezer is back to operating temp.
Aug 06, 2009 | Frigidaire Upright Freezer FFU12F2H
Whirlpool 20RB D4 Fridge Freezer clicking
Hi the reason for your noise coming from the fridge freezer is the plastic that is used in the design of your product is of a low quailty which reacts to the temp change and then as they get cold again they start to crack inside the frigde! Nothing to worrry about........
Hope this helps.....
Dec 23, 2008 | Freezers
Refrigerators Logo
110 people viewed this question
Top Zanussi Refrigerators Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Jason Harris
Jason Harris
Are you a Zanussi Refrigerator Expert? Answer questions, earn points and help others
