Question about Refrigerators
Fridge freezer, fridge alarm and lights not working
Lights and alarm does not work on the fridge, changed bulbs, freezer is fine.
    Champion:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 215 Answers
Look for fuse location in manual
Posted on Dec 14, 2014
The freezer light doesn't come on but we tested the bulb elsewhere and it works.
Moisture can contribute to a bit of rusting at the point where contact is made between bulb and socket. Unplug fridge. Use a small piece of fine-grit sandpaper on the socket where the bulb will connect and then spray a tiny amount of WD40 to the socket. Let it dry for a few minutes. Replug your fridge and screw in the bulb. This works for fridge lights too and I've noticed whenever I have something like a cut melon in the fridge which causes condensation then my bulbs will go out and I have to do this sand and spray thing.
Sep 09, 2014 | Kenmore 26.7 cu. ft. French-Door...
Fridge light bulb
Not sure how the light socket only has 6V supply? The bulb for this fridge is a pretty standard 15 Watt/230V SES lamp. If you are sure the current lamp is OK I would suggest the door lamp switch has issues. Try pressing and releasing the door switch manually and check that it functions ok without getting stuck or any sluggish movement. This action in itself may fix the problem.
Jan 18, 2014 | Miele KFN8462S Bottom Freezer Refrigerator
I have a Whirlpool side by side fridge freezer with ice maker and water dispenser which is about 3 years old. Model number I think is WSC5533. Recently I had an interior lamp bulb blow in the fridge which...
HI,
You may have a failing door switch which is causing this problem, if you remove the bulb and close the door, the the red light out? If so, its possible you bulb is fine, you door switch has failed.
I hope this helps
Jul 26, 2011 | Whirlpool Refrigerators
I have a Samsung refrigerator Model RT52EAMS which is 5 years old. It is working fine except that the light in the refrigerator is no longer working. The light in the freezer is still working well. How...
Please check the door switch and the bulb holders, in some cases it can be due to loose connection or a faulty switch on the door, The failure of the bulb is another issue but the main subject is how you can check and remove the bulb.
Please check on the link below for tips and spares:
http://www.espares.co.uk/advice/fridges-and-freezers/a/2/280/common-fridge-and-freezer-faults.html?k=#nolight
Jul 19, 2011 | Samsung Refrigerators
No light in refer but works in freezer
Check the door switch to see if is working and try another light bulb or try the light bulb somewhere else to see if the light bulb is good. Check to if vent holes coming from the feezer are blocked by something in the fridge. This will make it feel like your fridge is not working.
John
Sep 28, 2009 | Smeg FAB32 Bottom Freezer Refrigerator
Fridge Light - you posted
Your bulb is shorted out internally. Try another bulb. Please post as as helpful if so.TY
Jan 10, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Fridge and Freezer not cold, compressor not coming on
these are 2 different things.check the light switch. also check cold-control, defrost timer, relay on compressor.
May 24, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Zanussi zk73/46ef freezer working fridge is warm
if this is an air blown cabinet defrost it for 48hrs leave the doors open then try it. hope this helps
Feb 09, 2008 | Refrigerators
FREEZER SECTION WORKING OK, FRIDGE SECTION NOT WORKING
Check the vents of your fridge side if present, if no air then may be your blower not working or some ice formation that blocks the air(try defrosting). Check also your vents for obstruction or overloaded with stocks.
Jan 22, 2008 | Freezers
 if posible try turning off over night, if its ok when you start it back up after 24hours, defrost not happening, ice builds up air flow is restricted
Oct 18, 2007 | Whirlpool ED2FHEXN Side by Side...
Refrigerators Logo
62 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
