Question about Halonet 99-05 BMW E46 3-SERIES 2/4/5DR, CONVERTIBLE: 318i, 318is, 318ti, 320i, 323i,
I got a 1999 bmw keeps over heating I tried bleeding it but it still over heating
I tried bleeding it
BMW R1150rt Rear brakes
keep bleeding ,fill tank if low. ,Air in line not good
Jan 31, 2013 | 2004 BMW R 1150 RT (ABS)
I bought a UK spec E39 528i last year with an over heating problem (new head had been fitted)but still over heating.I bleed the water system and drove home just short of a 100 miles with no problem.Next...
remove the colas and repair or change it because the colas is not straight that's while there's pressure in pipes and inside water system .. the CO2 is going to mixed with water
Mar 19, 2011 | 1999 BMW 5 Series
Bmw 318i. Car was overheating although coolant full. Bled radiator and now its ok but now heaters inside car blows cold. any ideas i can try please
Sounds like the thermostat has stayed closed you will need to change it as it will blow the head gasket, very common on this model.
Also when you bled it though you may have left some air in the system this would also stop the heating working, they can be a pain to bleed through keep sqeezing the water hoses as you are bleeding it through and do not bleed it from the lower part of the radiator as it will be hard to get the air out as air will stay at the top, you should bleed from the top.
Jan 20, 2010 | 1999 BMW 323 Series
Thermostat change
check that system has been bled, bleed screw is on top of plastic expansion tank, try back flushing the system with heating controls on full hot
Dec 08, 2009 | 1994 BMW 3 Series
How do you bleed da fuel from 2000 bmw 320
the system does not require bleeding
Jul 10, 2009 | 1999 BMW 5 Series
1999 Silverado brake bleeding issue
I am trying to vacuum bleed my brakes. I replaced the pads and have no pedal at all. I cant draw any fluid through the bleeder nipple at all. Please help me out.
May 21, 2009 | 1999 Chevrolet Silverado 1500
No heat
did you bleed the air out of the system ?
Nov 24, 2008 | 1999 BMW 323 Series
Coolant level
One of two things, it is either leaking out somewhere, which you should be able to see puddles on the ground or while its running open the hood to see if its leaking out on your motor, hopefully its only a radiator hope or something, this is the cheapest fix. 2. It's burning out internally in your engine, if this is the case you should notice white smoke out of your tailpipe, bad news is if this is the case, its going to get pricey fast because that would indicate a bad head gasket or cracked head.
Oct 03, 2008 | 1999 BMW 318 ti
My car is overheating and the heater is blowing cold air
Try bleeding it.  It takes more than one time to bleed a bimmer's system.  No heat from the heater simply means that water have not made it through your heater core yet (mostly air).  But on the other hand, you mentioned air escaping out of the radiator cap.  I'm doing research for my own for the same cause.  Someone mentioned earlier that it's a symptoms of bad head gasket.  I'm still searching that.
BigSarge
Jul 28, 2008 | 1999 BMW 318 ti
Halonet 99-05 BMW E46 3-SERIES 2/4/5DR, CONVERTIBLE: 318i, 318is, 318ti, 320i, 323i, Logo
155 people viewed this question
Top Halonet Scuba Diving & Snorkeling Experts
Tom Chichester
Bill Boyd
micky dee
Are you a Halonet Scuba Diving and Snorkeling Expert? Answer questions, earn points and help others
