Bought a replacement remote RCM 8080 for easy touch TV but it won't work
    Top Expert:
  • Televison & ... Master
  • 75,581 Answers
If the remote control you've bought is its original replacement [number]; it should work with the TV without any problem. If not; the infrared sensor inside the TV should be checked and replaced.
If it is a universal remote control; you have to set it up with its set-up code; said to your TV brand.
If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Posted on Dec 14, 2014
Bought a new replacement remote for my magnavox and it won't work??
It should be synchronized with TV using setup code. If you wish to get more details, check this site. Pull up previous posts there. Setup code list and setup proceedings to many popular brand remote controls are given. Three digit, four digit, five digits and two-digit code list are there. Check the site with patience. Surely you'll get a solution to your problem. Search the site by 'Timeslide' option. It will make search easy. Or, type in the brand name to your device into its search box, and press "Enter"
Apr 06, 2013 | Magnavox RC2033603/01 REMOTE CONTROL PART...
Cobolt 3 in 1 jumbo remote control
have u checked wether is is supported or not????
it may not be supported.............
Sep 18, 2008 | Televison & Video
LG 52LG50 TV remote stopped working
If the standby light on the TV blinks, as any remote control handset is pressed, means, the circuit between infrared sensor inside the TV and main system control section has the fault. If infrared sensor inside your TV were faulty, this will not happen. Here infrared sensor inside the TV and remote control, are working properly.
the fault is with the main system control circuit itself. To make this more confirm, just replace the infrared sensor inside your TV. It is an easy to get component, and won't cost more too. It can be bought from most of the electronic spare part selling shops at your town. There are so many types of infrared sensors are there in the market. You have to make sure, which type is used in your TV. This part can be located just behind the infrared sensor window at the front panel of the TV. In fact, you have to open the TV to access it, as it will be directly soldered to the front panel control circuit board. For your reference, I hereby includes the images of some types of it. Just see, it is a three solder terminal component, easy to get, and easy to fit. If the fault still occur even after replacing this component, surely the main system control IC and its memory IC section circuit should be troubleshooted. This is really a skilled work.
8_10_2012_9_36_09_am.jpg8_10_2012_9_36_20_am.jpg8_10_2012_9_36_37_am.jpg8_10_2012_9_37_02_am.jpg
Aug 09, 2012 | LG Televison & Video
Logik remote control won't work
It sound that your remote control need serivce. In most cases, claning it will rectfy the problem. You can get more details about how to reapair,test or clean the remote control by entering this site "Electro-help". Search for it in Google.
May 02, 2012 | Televison & Video
Remote to tv doesn't work
Hello
Check the remote first for its infrared emission. If it is OK, the infrared sensor inside your tV is faulty. It should be replaced with same type and number. It can be located just behind the infrared window at the front panel of your Tv. You ahve to open your TV ot access it. It will have three solder terminals, and will look somehat brownish black in colour. Will look like this.
Nov 14, 2011 | Televison & Video
My remote won't work and I used to be able to change the channel on the TV but even that dosn't work. I checked the cords. Changed the batteries;
Hello
First check its battery contacts for any rust or dirt accumulated on it. If so, contacts of battery will not touch properly, and the unit will fail to work. The second reason for malfunction is due to the infrared sensor inside your tV. If it is faulty, the set won't respond to infrared signal generated by the remote control. If so, eventhough remote control works properly, the set won't work with it.
Remote sensor comes just behind the infrared window at the bottom front panel of your TV. It is a replacable part and not so costly too. It is a three terninal component will look brownish black in colour. It will looke like this.
gopakumarg43_77.jpgThe procedure to check the remote control for its perfect working is described at a tip I've given and published by Fixya on Google. Type "gopakumarg43" on google search box, and get into my profiles. There you can see 'Tips and How To's" line, click on it. You can read it there. OK.
Sep 23, 2011 | Philips Magnavox 20MT133S 20" TV
Universal remote (GE 24116) that i purchased to replace the lost remove control for my sanyo 42 inch tv won't work. the arrow buttons don't work in the menu which is the only reason I bought the...
Hi, You need a code to match with your TV remote. The codes for the Ge universal remote for Sanyo are 0049 0097 0110 0004 0268 0012 0108 0180. You will have to try each code seperately untill you get one that works. Good luck.
Sep 09, 2011 | Sanyo 42 in. LCD TV
Remote control setup
try 8080, 8081 or 8092. code works with the Sony RM-EZ4 universal remote
Dec 26, 2008 | Durabrand BH1304D 13" TV
Akai 32" LCD TV/DVD Combo- universal remote
just replace the infrared diode of your remote control in you dont know how to do that..ask the tecnician to change in infrered diode in your remote control
Feb 04, 2008 | Akai LCT3201AD 32 in. LCD Television
Televison & Video Logo
301 people viewed this question
Top Televison & Video Experts
