Question about Philips HSB3280/F7 Micro Hi-Fi Soundbar System Refurbished
My Philips HSB3270/F7 sound bar no longer has a display when powered on and makes no noise, If I could at least figure out how to reset it to factory defaults I could eliminate the 'young help
Checking connections, bypass remote and do at unit, the blue light shows when powered on, so has power, but nothing on display. We barely use the unit so it shouldn't be worn out. There is no online info on this one.
    Master:
  • Philips Master
  • 487 Answers
Get in touch with Philips at: http://www.support.philips.com/support/contact/contact_page.jsp?userCountry=ca&userLanguage=en
Posted on May 07, 2015
easyq
  • 144 Answers
SOURCE: Philips Home Theatre System - no sound or power light on sub woof
reset the device to factory settings, it is written in your manual how to do this. If that doesnot work, unplug the powersocket for about 30minutes, it will cause an internal reset which might solve it.
Edgar
Posted on Jan 29, 2009
ginko
  • 19396 Answers
SOURCE: How can I reset my Philips Soundbar system
You just remove batteries , unplug all cables, then put everything back together. This will reset the unit to factory settings.
Posted on May 15, 2009
  • 547 Answers
SOURCE: ipod docks to philips sound bar, but produces no sound...
Check the iPod dock connector for dust or pocket-lint. Use compressed air to blow it out if there's debris in there.
Then check the sound bar's connector to make sure the universal dock connector is clean and doesn't have any damage to the connector.
Posted on Jan 14, 2010
SOURCE: Philips Home Theater - Annoying high pitch sound while on standby
I have the same problem with the same model, so obviously it's not a single-unit problem. My only solution, since taking it back isn't feasible at this point, is to have a DVD on play-pause so that it's not on standby. Waste of energy, so I don't do it all the time, only when I'm sitting in the room late at night making the high-pitched noise hard to ignore.
Posted on May 06, 2010
micromatikal
  • 2777 Answers
SOURCE: my philips dvd player hts3371d/f7 does not power
Well it's definitely either a failing power supply or a capacitor on a board somewhere that has gone bad. Trying to say which one remotely is like trying to pick which light-bulb failed on the front of a casino without looking at it. You are going to want to take apart the machine and inspect each cap one by one to inspect for damage. If you can't find anything then you will need to look into replacing the power supply.
Thanks
Tim
Posted on Oct 06, 2010
Hi, my Philips TV 46PFL3608/f7 ds1 turns on, shows philips logo and turns off. I need advice what I should change. PSU, mainboard or somethink else ?
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.
Jul 06, 2016 | Philips Televison & Video
Tip
INITIALIZING AND POWER SUPPLY CIRCUIT
PHILIPS HTS3251B/F7 - HTS3051BV/F7
HOW TO INITIALIZE THE BLU-RAY DISC HOME THEATER
[HTS3251B/F7]
To put the program back at the factory-default, initialize the BD player as the following procedure.
Note: By initializing, network is reset to disconnected state and "Network Service Disclaimer" appears on the screen.
1. Turn the power on.
2. Remove the disc on the tray and close the tray.
3. Press [1], [2], [3], [4], and [INFO] buttons on the remote control unit in that order. (All VFD lights)
4. Press [ STOP ] button on the remote control unit.
http://electro-medical.blogspot.in/
google.com/+AjinGopakumar
on Feb 21, 2015 | Philips Televison & Video
My Phillips 46PFL3908/F7 LCD TV will not turn on
May 14, 2016 | Philips 46PFL3908/F7 46-Inch 1080p 60Hz...
Philips 42PFL3704D/F7. Why does it keep restarting?
Philips 42pfl3704d/f7 power reset when HDMI, USB, or cable ...
www.badcaps.net > ... > Troubleshooting TVs and Video Sources
Oct 9, 2012 - 5 posts - ‎2 authors
Philips 42pfl3704d/f7 power reset when HDMI, USB, or cable attached ... or Cable TV to unit the power resets, philips screen comes on and keeps on resetting. ... I tried a cable to the tv without the box and I do get picture.
Philips 42PFL3704D/F7 42-Inch 1080p LCD HDTV
www.amazon.com/Philips-42PFL3704D-F7.../B001LP...
Amazon.com, Inc.
Rating: 3.3 - ‎50 reviews
Amazon.com: Philips 42PFL3704D/F7 42-Inch 1080p LCD HDTV: Electronics. ... Will do all I can to prevent others from getting ripped off by Philips. ... came up every few weeks and would take an hour or so of reset before working properly.
Visit the support page for your Philips LCD TV 42PFL3704D ...
www.philips.ca > philips > Televisions > 3000 series
PhilipsFind support for your LCD TV 42PFL3704D/F7. ... How do I output sound from myPhilips TV to external audio devices such as Home Theaters, Soundbars, AV ...
42" Philips 42PFL3704D/F7 LCD TV WON'T COME ON - A
Dec 29, 2015 | Televison & Video
I have a Phillips sound bar with subwoofer. Model # htl2151/f7. The light is illuminated for power but will not change source and has no sound at all. Please help
Do a reset to this set, and check. There are two types of reset to TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight; will be better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done
Nov 03, 2014 | Televison & Video
Philips TV troubleshooting
Sounds like a main board fault. Please contact the authorized service center for Philips. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
Feb 05, 2014 | Televison & Video
I need the cox remote code for philips sound bar css 2123/f7
I too need this code, if such a code exists. I have found several that control the mute and volume, but none so far control power.
Jul 19, 2012 | Televison & Video
My philips 191EL LED monitor was not functioning the menu buttons but have a display and in use while plug on, however, at below portion of the screen appears the word SmartImage on and SmartImage off. Is...
simply long press input and power touch buttons to reset the ic program and it will be ok be sure to wait 5-10 seconds note: be sure the led has display input and powered on with the problem your encounting thanks ok
Jun 10, 2011 | Philips Computers & Internet
Philips HSB3280/F7 Micro Hi-Fi Soundbar System Refurbished Logo
251 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
