What does f18 mean - Washing Machines
  • 56 Answers
The F18 code means there is a water pump issue causing it not to pump. It could be a blockage.
Posted on Dec 14, 2014
Error code F18
F18 error code means that the filter is blocked.
Look around for a propeller shaped part, it should be able to spin freely. If not, remove the debris so that it is unblocked.
Hope this helps (remember to rate and comment this answer).
May 14, 2011 | Bosch Axxis+ WFR 2460 Front Load Washer
Hi I have got bosh logixx 8 1400 express and it is showing F18 on the display with an very annoying boop noise. Could u please help me in sorting out this . thanks
Error F18 means that the filter is blocked.
Hope this helps
to solve it.
Apr 18, 2011 | Bosch Exxcel WFO 2264 Front Load Washer
Error message F18 what does that mean? i lost the manual... michael
F18 (usually!) means there's some issue with drainage. If the washer doesn't drain properly within a specific amount of time, you'll get the F18 error. A common fix is to remove the panel covering your drain and examine it for any sort of debris that may be obstructing it - plastic, lint, loose change, etc.
Mar 05, 2011 | Washing Machines
What is error code F18 please?
F18 means the filter is blocked. Look around for a propeller shaped part - it should be able to spin freely. If not, remove the debris so that it is unblocked. Good luck!
Feb 28, 2011 | Bosch Exxcel WFO 2264 Front Load Washer
I was washing today and at the end of every wash tere was a code of f18 flashing on my screen .what should i do
F18 means pump is blocked or broken, clean filter first, no result change then you have to change the pump.
I also had this problem - the machine was full of water and it flashed up F18. I had to drain the water out of the machine using the small pipe located next to the drain filter. There was loads of water to drain out. I used my oven roasting tray which was perfect for the job. Then I undid the screwcap filter. There was a lot of really black water that came out, along with about two pounds worth of coins.
Jan 06, 2011 | Bosch Exxcel WFX 2467 Front Load Washer
My washing maschine says F18. What does that mean?
If you let me know the Make of the machine, I can tell you exactly what F18 code is and what needs to be done to repair it.
Dec 31, 2010 | Washing Machines
Hotpoint Ultima WD865. Showing Error Code F-18. Please advise.
hi, i turned on my wd865 machine and it starts fine and sounds the same but its displayinf f 18. but it doesnt continue the wash in the usual way . what does f18 mean ? please help :)
Mar 21, 2010 | Hotpoint Washing Machines
What do I do when My machine shows F18 as an indicator of a problem
I also had this problem - the machine was full of water and it flashed up F18. I had to drain the water out of the machine using the small pipe located next to the drain filter. There was loads of water to drain out. I used my oven roasting tray which was perfect for the job. Then I undid the screwcap filter. There was a lot of really black water that came out, along with about two pounds worth of coins and some hairgrips. Now my machine works perfectly !
thank u
rate me
Aug 23, 2009 | Bosch Washing Machines
Bosh Washing Machine F18 fault
Sep 01, 2008 | Bosch Logixx WFT 2806 Front Load...
Washing Machines Logo
56 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
